Left hand threads thread- Where & On what have you found them?
creativecars
Indiana- where horse and buggies still roam
I bring up this thread because I was changing out a flipper handle on a toilet this morning and didn't realize it had left hand threads until after I destroyed the plastic threads.
It was a good thing they were plastic because I would have hated to break the tank being ignorant.
Anyway my question to you is where and on what have you found left hand threads?
Toilet- flush lever
Bicycles- left pedal
Some old Chrysler- wheel studs
joe_padavano
Northern VA
The toilet handle used LH threads to prevent having the nut loosen up every time you flush the toilet. This is usually why LH threads are used, so a little common sense goes a long way before the need to get destructive.
GM cars prior to the 1963 model year used LH lugs on the LH side of the car. Even the front spindle nut is LH thread. Many have been broken by gorillas in tire stores.
larry_g
oregon
Lead screws on a lot of machines.
Some arbors.
Rod ends
Left handed drill bits.
Many adjustable links, such as the third link on a 3-point hitch.
A Yankee screwdriver has both.
lg
no neat sig line
stikman56
Powerstroke fan clutch, idler pulley on a Detroit series 60, left side wheel on an older mopar, left side wheel on a Willys pickup, screw on a drill chuck, bunch of other stuff I'm sure that I have forgotten.....
Unhdsm
Vermont
I can’t believe no one mentioned lawn mower blades.
Also one end of a dual motor spa pump.
PWC Repair
Arkansas
Old camper wheel lugs, flywheels on powersports, boat props, jet pumps, various power drive equipment, etc.
finn
The UP, God's country
Right side wheel lugs on an F600, some serpentine tensioners.
Generally I check anything that rotates, prior to fitting a wrench to it, for oddball threads. I’ve been surprised enough times in the past that checking threads is sop.
pancho400cid
Austin, TX
There once was a whale named Moby ****,
who was cursed at birth with a cork-screw *****.
In every ocean he did hunt,
to find a whale with a cork-screw c _ _ t.
At last he found her, but he soon dropped dead…
Son-of-a-*****!!!
Left-hand thread!!!
Bluedodge
Michigan (not the Detroit part)
Drill chucks, one side of any bench grinder, nut on my mitre saw.
I had an old 60's Plymouth that had left handed threads on passenger side (?) lug nuts. That was a learning experience - had never heard of such a thing as I pulled and pulled on the lug wrench....
Ctkelly
Iowa
Bunch of parts at work on a rotary liner. Since it rotates counter clockwise that means quite a few of the parts have to have left hand threads.
RPH
Michigan Thumb
1970’s Husqvarna motorcycles on the primary sprocket. Brother had the corner garage use the impact on it when it wouldn’t come off. Then he learned about left hand threads.
ER70S-2
Ring gear bolts on late model GM differentials (G8, GTO, Camaro, and probably others).
coljar
Belpre, Ohio
Several years ago, I made a front spring puller for my classic Mini. I needed a lenght of left hand metric threaded rod and believe it or not, a mom & pop fastener outfit in the town across the river had what I needed. I don't figure I'll ever find a use for the last 20inch piece.
The nut on the left-hand side of my "Powr-Kraft" grinding arbor.
Crankshaft snout on the Briggs & Stratton 5S engine on my 1955 Toro "Sportlawn" mower.
Crankshaft snout on a Jonsereds chainsaw. Unfortunately the guy at the shop didn't know that it was left-hand thread and snapped off the end of the crank trying to remove the flywheel with an impact gun. Trashed a perfectly good saw.
The business end of a FS80 Stihl weed-whacker uses an 8mm x 1.25 x 40mm left-hand thread bolt (Grade 8, no less) to hold the cutting device onto the hub. When you drop it in the tall grass and lose it it's $9.62 + shipping and lead time is two weeks.
MadMark
New York City
Son-of-a-*****!!!
Left-hand thread!!!
that made my day
PassnThru
Bowling Green KY
A common theme is anything heavy that turns on a shaft. It depends on which way the shaft is turning.
The oddest place I have found left hand threads is on this - yes, the orange cap where you put the water in. It gets the kids every time :bounce:
  • 1_123125_122981_2156581_2169644_2170032_04supersoakersneak.jpg.CROP.original-original.jpg
Larey
Fussa, Japan
One end of pitch links on helicopters or tilt-rotor aircraft. Sorry just sounds better then the already mentioned rod ends.
