Removing drill press chuck?
Jason280
I picked up a cheap HF bench top drill press, and need to remove the chuck. It doesn't have a slot on the side to drift the chuck assembly out of the head, any suggestions on how to remove it? I assume it's a tapered Morse style, but not sure. Thanks!
dr_clyde
Holland, MI
It's probably an integral spindle with a Jacobs taper on the nose. You'll need chuck removal wedges. Basically, the chuck is presssd right into the nose of the spindle.
J
Jason280
Thanks, that's kind of what I thought. How do I go about "pressing" the chuck back in place after I finish?
dr_clyde
Holland, MI
Clean both tapers with some acetone to get them nice and clean. Make sure there's no burrs. Retract the chuck jaws all the way into the body. Give it a good push on to the spindle taper. It should stick. Then take a lead hammer and give it a few firm taps to seat it.
engineer2
Chicago burbs
Any time I've tried using my drill press as a milling machine, the chuck and taper assembly fall right out, LOL.
exmaxima1
Midwest
I've never used wedges. I give the chuck a wack with a brass hammer. If it doesn't give, I leave it alone. Only one chuck ever failed to drop.
You might also try using a straight claw hammer, or a thin pry bar, as a wedge to get it off.
