What's good at HD under 50 bucks
JUNK-MAN
PA
So guys, I have a $50 gift card I want to spend, so what's good there, I obviously have all the basic stuff. Mostly thinking automotive tools and stuff. Thanks
ishiboo
Oshkosh, WI
Diablo consumables, Milwaukee hand tools, Bessey clamps, Klein hand tools, lots of stuff! They actually have some usable 3/4" shackles with isolators for under 9 bucks if you need them. I use them for moving **** with the tractor on occasion.
davethorik
Norka, Ohio
My local HD has a decent selection of Klein USA pliers, if you happen to need any. Aside from electrician specific, I highly recommend the 2000 series, blue handled side cutters or linemans if you've never tried them and could use a quality pair. Around $40ish. Their 203 series, yellow grip needle nose are very good as well, closer to $30. At HD they also stock the new HD 2000 series 9" side cutter, which I would like to try.
Just remember the new Kleins flash rust easily, if that matters to you. They are bare steel and do not have a coating like Channellocks so I recommend oil them when new.
tym
I recently discovered they have Wiss tin snips for around $10 each; picked up a couple. Some of my other favorites there: Mayhew chisels, Channellock stuff, Estwing hammers.
nynexit
Long Island
Brute trash cans ! I'm never going back to cheap black ones . [emoji3]
Can I try?
SE PA
A lot!
For "automotive tools and stuff" consider an online order with free shipping to store.
They have a good selection of many quality brands at reasonable prices - Knipex, Bondhus, Mayhew, Channellock, Gedore, Gearwrench, Lisle, Klein, Ridgid, Estwing, Nupla, Blackhawk, Witte, and many more.
I've placed a handful of hand tool orders this way, and every order has been completed without problem.
6PTsocket
I love Brute cans, but can't find bags to fit them. Any ideas? Hint- They don't sell any bags that fit them at HD.
What size Brute? I think they start at 5 gals. and go up to maybe 45.
Rustypigeon
USA
HD buckets...
And the "Buckethead" vacuum cleaner. Turn your buckets into a vacuum cleaner for $22. I use it for vacuuming nasty stuff in the garage.
CJ7VFR
Central New Jersey
That is great! I have never seen this in my local Home Depot stores. I am going to look the next time I go there.
Using that would make it so much easier to dump the stuff out into a larger trash can than using a bigger shop vac that is on wheels. I hate cleaning my shop vac out when it gets full. It makes a mess everywhere.
This one would also work great for hooking up to a sander, or my table saw or any portable tool that I use in the garage. Thanks for posting this!
Jim
NUTTSGT
Northern Central Ohio
Jim
That would be perfect for the car trailer. I use a 5 gallon bucket already for a trashcan, so it would be a perfect fit. Not too mention I already have a few extra 1 1/4" hose accessories.
ihateminimumwage
Not sure how I've never spotted those before, but I have $16 in credit so I might be grabbing one this week. Thanks for posting!
NUTTSGT
Typical GJ, somebody needs something and looks like atleast three other members are going to make a HD purchase because a fellow member shows a picture and suggests it.
No wonder this site costs me (and others) so much.
:beer:
Todd.Brock
Cincinnati
I’m on my way to check the PCA. I’ll let you know If they are .01
Seriously, I haven’t ever seen those either. Would be a lot easier than dragging my big *** 5 “HP” c-man through the house
Rustypigeon
USA
Does this thing ****?
It *****, but in a good way.
I have not had a time where I needed more suction than it could deliver. It has a 4 amp motor and about as much suction as the smaller shop vac type vacuums.
It is good for typical garage dirt, sawdust, car interiors and similar uses.
The hose attachment is a bit short at 4'. I am sure there are extension hoses available out there somewhere.
BMack37
Online they have full catalogs of Knipex, Witte, Gearwrench, Sunex
jd_1138
NE Ohio
Tool wise, if you don't have any ratcheting wrenches, I'd maybe grab a set. Maybe build a second set of basics for your trunk -- $10 Home Depot Homer Box toolbox, some DeWalt or Milwaukee or Husky hand tools (screwdrivers, adjustable wrench, small prybar, pliers, hammer). Or some of the name brand basics like Stanley Fat Max cat's paw/nail puller, Stanley tape measure. A metric tape measure is nice to have -- no fractions to mess with.
Or consumables -- Milwaukee/DeWalt bit/drill bit sets, Diablo reciprocating saw blades, circular saw blades
Pig_Pen
Off topic but is Apex sending Wiss overseas? I was in Home Depot two weekends ago and noticed the Wiss multi purpose snips were chicom but all of the aviation snips were still made in USA.
BMack37
Midwest does that too with some of their cutters. I think that's business as usual, ie not a recent change.
kctyphoon
Jersey/Staten Island
I wasn't very impressed with that bucket vac when I tried it in the store.. the short hose is kinda limiting too considering it's corded. I'll agree, great idea, but don't expect a full sized shop vac from it.. it's good if you can work within it's limitations.
BombShelter
State of Hockey
The BucketHead is a great $22 (plus the price of the bucket) vacuum. I use quite a few for work and throw them out when done, usually 8-24 months. I'm mostly picking up dirt, rocks and wet **** off of garage and basement floors.
They don't have a ton of suction like the larger models but they do an great job for the dirt I throw at them. I keep a few of the Home Depot Five Gallon Buckets around so I can finish the entire job and then take the buckets and dump them. You need to use the HD 5G Buckets to get the proper fit for suction. All five gallon buckets are not the same dimensions and they may have different lips.
The vacuum works great with liquid as well but sometimes the float doesn't shut it off right away so you have to be aware of rear-end blow out. The hose can be put on the exhaust and used as a blower, but again this isn't a high power unit but completely worth the price.
Jarhead0408
Who knows?
I like their Milwaukee demolition screwdriver sets. I think I've bought three sets so far. One for the shop, one for the car, and a spare set I use on contract work and in the junkyard.
jimreed2160
Tallahassee FL
I just got one of the bucket vacs and dedicated it to my oscillating spindle sander so I could free up the shopvac. Not a bad deal for less than 25 bucks.
hamma
Bought this set of German made Witte screwdrivers, same as the Matco screwdrivers sold on the trucks. Order on line and pick-up in the store.
