Seized Wilton 1750 rescued from the scrap pile - Full Restoration
MayerMR
Dallas, Texas
Hey fellas,
I recently posted another vise restoration, a little Lakeside 3'' vise, and I'd like to think I learned some lessons from that exercise in insanity...I've moved onto bigger and better things. My most recent vise restoration is definitely both of those things...bigger and better...in almost every way.
So when I was wrapping up the little Lakeside vise restoration I came across this Wilton 1750 outside under a tarp at a local antique tool store. The vise had obviously lived outside (and uncovered) for a considerably longer time than its time there at the shop and was completely seized. It was also missing the front collar. The only part on the vise that *wasn't* seized was the main screw - that said, the handle WAS completely seized and it would not move a milimeter.
Truth be told, I wasn't even sure it was a Wilton when I purchased it, but the price was right and I thought it would be a fun challenge.
After getting her home, I gave her a liberal dose of PB Blaster on and off for about a week. One night I was feeling cheeky and decided I'd go out and see how much I could get apart. I was pleasantly surprised when I was able to get every piece (minus the jaws) removed without too too much trouble.
Though it all came apart pretty easily, I was left with a ram that was well and truly *stuck*. It was about this time that I had to go on a short work trip, so I dropped the whole thing in a 3-gal bucket of Evapo-rust for the duration of my trip. I don't know exactly what I was hoping for upon my return, but getting the ram to slide on out wasn't what I came home to.
I did, however, had a slightly less rusty vise...
My next step was to figure a way to loosen that darn ram. I got to thinking and into my head popped what I thought to be a great idea...I thought..."Why not use the weight of the vise to my advantage?", as I pictured a fence post driver.
Off to Home Depot I go with my deviously brilliant plan in mind...with the result below
I don't think I need to explain the concept further, but suffice it to say that it was a grand failure. The duct tape didn't stick as well as I'd hoped...I didn't think I needed much, really just wanted the PVC pipe to act as a guide for the large dowel. But yeah, that didn't work. The dowel seemed to absorb too much of the blows even before the duct tape failed.
That said, onto Plan B...which actually worked right away...ugh
After mounting the vise on my outside gardening/painting table and setting it on its side, I used a 2'' hitch ball which fit nicely onto the ram to evenly distribute each blow. After about 3 whacks with 3lb hammer I could see movement!
A few blows later and BAM success!
So a bit of a fast forward, for the sake of everyone's patience, I proceeded to wire wheel the whole vise and ground off the slag from the PO's messy welds. Additionally, I was able to remove the jaws, though one screw did decide to twist the head off. Luckily, I was able to extract the rest of the screw with the remaining threads.
I then filled the dings and uneven surface of the anvil with JB Weld.
After filing and sanding the JB Weld down the next day, I then primed with a couple of coats of etching primer:
Then I hit it with some Rustoleum Professional Performance Enamel in Safety Blue. Word to the wise here...on the can it says that you can handle in 2-3hrs and it's fully dry in 24hrs. While that may be try if you can get the paint on in the summer and leave the piece in the sun to fully cure, but if it's not that warm out or if it's humid, then you really need to way 2-3 DAYS before it's fully dry. I'd suggest >24hrs before even handling - you really can handle the piece sooner, but you run the risk of leaving fingerprints or marring the surface.
I couldn't resist putting the vise on the base, even though I hadn't painted the top of the base yet.
In the meantime, while the paint was curing, I had thrown the remaining bits in the Evapo-rust and hit them with the wire wheel. I was amazed at how badly the rust had eaten into the main screw. I considered replacing it, but honestly, even with the missing metal, I seriously doubt it'll be a problem. I do plan to have a buddy add some metal to the shaft with his welder, I'll then grind it back flat.
PS, is Evapo-rust not some amazing stuff? Look how it cleaned up that rusty iron!
I then decided that I wanted to fabricate an endcap for the vise, even though these (apparently) didn't originally come with one from the factory. After reading around, I found another person who found that a Dorman 1 5/8'' freeze plug ($0.88) fits the hole well with a little machining.
Here it is with a coating of etching primer:
I didn't have a lathe, so turning it down to size wasn't an option for me. But I do have a belt sander. What I did was sand down the outer diameter of the main screw nut by about 1mm so it would snugly fit the ID of the freeze plug. Once mounted, I still had some interference with the end cap, I fixed this by grinding just a little off the OD of the freeze plug until it would fit without interference.
Then it was time for the final top coat to get the areas I missed when painting the bottom parts of the vise
After a quick call to Wilton (who has great customer service, btw) I received a brand new aluminum decal tag.
I also needed to procure a new collar, which I sourced on eBay. It came with a thrust washer (which isn't used on the older Wilton 1750, btw) and three new 10-32 philips screws. I didn't want to use philips again, so I picked up some stainless 10-32 allen bolts from the local Lowes.
Next up was addressing the jaws...only one of the two was actually a real jaw. The other was a piece of flat stock. In order to rectify this, I decided my money was much better spent buying new, high quality jaws from Kevin at Wilton Vise Parts. I initially ordered aluminum soft jaws, but after speaking with Kevin, he convinced me that I would be much better served with a set of his smooth jawed hardened steel jaws.
http://www.wiltonviseparts.net/5-x-3-4-x-1-2-inch-thick-smooth-wilton-vise-jaws/
These jaws were $60 shipped, while other varieties available online are in the $40 range and are of lesser quality...generally with pretty poor reviews. That said, other than purchasing these jaws from Kevin, I have no other affiliation with him...just wanted to give him a plug!
So tonight when I got home, my new jaws were waiting for me and I gotta say, whew, these are some nice jaws. Very high quality and they fit perfectly.
Now it was time to do the finishing touches!
And here she is, fully recovered from her dark times!
I'm real happy with the way she turned out. I believe it's ready for another 40 yrs of work!
Up next is a recently acquired Athol 624 1/2...luckily, this one has led a much better life...
MayerMR
Dallas, Texas
Awesome save, man that main screw was eaten up! Also looks like the screw has a serious crack through it, false alarm?
Thanks! It is pretty chewed up with rust but honestly, I think it's still strong enough even if I don't weld it back up. Also, not a crack, just the line left where it was sticking out of the evaporust on its 2nd and 3rd dip to remove the rust from the ID of the handle end. I could buff it off with a wire wheel but it's not seen so I didn't bother.
MayerMR
Dallas, Texas
Great work. That is a great looking vise. Are you keeping her or selling her to finance your next?
My intentions are to sell this vise, but she's lookin' pretty so I'm struggling with that decision right now. I think I'll admire her for a week or so then put her up on eBay once I'm able to get that main screw rewelded and strengthened. I don't think it's a problem, but I'd rather correct it than sell it with the caveat that the screw could be compromised.
I appreciate the nice words!
exmaxima1
Midwest
Looks really good, especially considering how it started out. I think I would have sanded the anvil--no JB Weld--and left it at that, but I admit it's useful for other areas. Those jaws are awesome, and the end cap turned out great as well. BTW, I recall my 1750s having factory caps, and I think only the Cadets were sans caps.
Stadger
Looks nice but I hope you will inform any potential buyer that the anvil is covered in JB Weld
DD T/A
North of ▼PL∇MB▼
That vise looks very old, but I thought all the older vises had WILTON cast/forged into the side? Is there a cutoff date/era when they started gluing decals to them?
Todd.Brock
Cincinnati
Good save ! I have a similar story that ends in a Rustoleum green similar to Grizzly tools. I was told that it was red b/c they were sold as Snap on vises in the early 80’s. But mine is a 1760ed98b54f377298a66cb7f80ed2db14b8.jpgfc078de2e214355a2540b3ad5f0eb9fd.jpg
Roberts210
Missouri
Hooray! Another near-dead Wilton saved.
I found this one on the local CL for $30.
Missing one jaw and the other had been welded to the dynamic.
Base had been welded to the body.
Took me awhile but I restored and replaced some things.
thehorse13
Jefferson County, WV
Outstanding save. Finding vises that appear near death but are solid and restorable is a very addictive hobby. I will be watching for future saves.
MayerMR
Dallas, Texas
IMO, the jaws are what really set this vise off. They are darned awesome. I'm now likely going to have to replace all the jaws on my vise restorations simply due to how much better these ones are compared to the originals. They are *really* making it tough for me to want to part with this ole gal.
You are right, I initially intended to only fill the gouges in the anvil after I had leveled it out, but mixed up a bit too much JB Weld and couldn't find anything else in my garage that I needed to have put back together forever so I went a little crazy on the anvil. I did sanded nearly all of it back down to bare metal, minus the gouges, of course. That said I will/do intend to let the next owner know (I'm thinking of putting it on eBay, so in the description) that there is JB Weld on the anvil...but I'll also note that anvils on vises really shouldn't be used anyway. Either way, I'll pass it along.
I forget the exact year right off the top of my head, but I think it was late-'70s era. The decal on this one is a new style Wilton decal, but if you google image search "Wilton 1750" you will see at least 3 other variations on the decal. I would liked to have gotten an older variant, but they aren't reproduced as far as I can tell.
Nice save! I thought about going green as well, but decided I wanted to use up some of the paint I had in my garage. Question for you; have you had any issues with durability or flaking on that paint? I've found that the Rustoleum Professional Performance Enamel is the hardest once fully cured. Kind of a pain having to wait to recoat after a week for it to fully cure else it'll wrinkle, but if you're patient I've found it's a great paint.
Man...I think that one was in even worse shape than mine. Sucker looks great now though...I bet it was a lot of work!
You aren't kidding. I love to restore old things (or refurbish if the original paint/etc. isn't too far gone), but I think I've found my new favorite thing - vises! They are pretty easy and you get to the before/after in relatively short order when compared to more complex machines. I've already got another waiting its turn!
Todd.Brock
Cincinnati
I used Rustoleum wrinkle finish. It’s not super durable. There is a green which matches the Wilton OE color and I didn’t want to wait for it. I’m not super easy on the paint so I have an excuse to repaint that hideous green
Roberts210
Missouri
Thanks MayerMR. I was hooked when I read the ad, and it said, "For sale vise. Used to be a Wilton."
Bunk
Alexandria, VA
Mayer - Nice job bringing it back to life. I like the look of a bare metal anvil on my vises.
I know exactly what you mean about the addictive nature of the repair/refurb of vises.
A year ago I owned two vises - same one I bought 20 years ago and a project that had been sitting for 5 years due to Life. Today I own 5 more.
7th Kahuna
Los Angeles, CA
Good job once again. I'm amazed how much damage the water did to the screw. I might expect that of cheap recycled steel from overseas but not from a Wilton product, regardless of COO. Did they store it outdoors, in the shade, under the bench on which they kept the salt for the water softener?
The trick with the freeze plug was cool. My dad kept talking about getting a metal lathe, fine I thought but what will we use it for. It's amazing how many little things like that plug come up. Looking forward to getting the shop complete so we can finally put it to use.
Jon_E
Southwestern Vermont
I know it would be more work and a bit of cost, but instead of the JB Weld, why not build up the anvil a bit with a welder and then machine it flat? Just curious.
MayerMR
Dallas, Texas
Yes, the water really did a number on that screw. That being said, the worst damage was in the least likely part of the shaft to have had grease to protect it and was also inside the open chamber within the dynamic jaw - so likely when not soaking up water it was likely a very humid environment for much of the time.
I agree with you regarding a lathe; while I don't have one yet, it's definitely on the list of "tools to acquire" though. It certainly would have make making the end cap that much easier.
Well I completely agree with you...but I don't have a welder, so it wasn't really a feasible option for me. I probably shouldn't have filled the anvil pits with JB Weld, as others have said, but what's done is done. I did a pretty fair job of sanding it down to where the the anvil is mostly metal, with a few areas of JB Weld. I will make sure the next owner is aware the anvil area has JB Weld in it though, and they can use it (or not use it) at their discretion.
