How to Remove RotaBroach Bit
ericlar80
California
I'm wondering how you guys remove a rotabroach bit from the shank? I used one of the larger bits the other day and had a hell of a time trying to get the bit back off again. I used the spacer nut like you are supposed to. I ended up having to use a pair of channellocks in a rag to get it off, but I'm worried that I am going to damage them.
BTW - I cut a 1-3/8" diameter hole into 1/4" mild steel plate as if it was going through wood. Pretty impressive to do that with a drill press, especially when you are used to hole saws.
E
ericlar80
California
Are you putting the flat sided washer under the broach?
I did it per the instructions, which I don't think mentioned the washer. I'll have to look again tonight when I am home.
The idea with the paracord is unique; I'll keep it in mind if it ever becomes stuck.
22george
SW Ohio
Even with the washer that comes with the rotobroach kit I still have to use vise gripsznd a rag. That goes for the smaller cutters too.
astroracer
Mid_Michigan
Use the washer "nut" to loosen the bit. I clamp the shank in a vise and then use an open ended wrench to turn the washer nut in the CCW direction. The bit should loosen up and spin off by hand. :)
Mark
Nexussian
Alaska
Thanks Astroracer, never thought of using the flats on the washer as wrench flats (got mine years before directions were available online, and with no printed directions. :shrug:
I've used small pieces of lath in a vice to grip the sides of the cutter (place the sharpened end beyond that) with the mandrel still in the drill motor and use the chuck for a handle (insert chuck key if necessary).
Showkey
"MEMBER EMERITUS"
Wausau WI
Mark
So that’s what the nuts is for...............:lol_hitti:lol_hitti:lol_hitti
22george
SW Ohio
Mark
DUHHH. So simple. Why didn't the rest of us think of it:confused:
My washer doesn't have flats, but easy enough to do.
Thanks from the rest of us for the tip:thumbup::thumbup::thumbup:
E
ericlar80
California
Mark
When you say CCW, does that mean tighten down against the arbor? I'm going to have to try this next time; thanks for the tip.
astroracer
Mid_Michigan
No, I mean to turn it the same way the broach would turn to come off the arbor. Looking at the broach end of the tool, turn the "nut" CCW to loosen the broach. This works every time for me on the larger arbor. The small arbor doesn't use the "nut" but I am thinking about making one for that purpose...
Mark
E
ericlar80
California
I did try that initially, but I felt like I was going to break the threaded shaft on the arbor since the nut essentially becomes a jam nut.
Buickspec6231
CNY
Make sure the cutter is on there good and tight before using it to cut. If you don't it gets extra tight, the same way you take a hammer to a wrench to smack a stuck nut loose. It makes coming off easier.
astroracer
Mid_Michigan
That's a good point right there... I do tighten the broach up a bit before I start cutting with it. The nut will be pretty tight after use and it usually takes one or two full revs before you can feel it loosen up. At that point the broach should just about spin off.
All of these parts are hardened so you aren't going to hurt anything by forcing the "issue" a bit... :)
Mark
ndnchf
Fredericksburg, Virginia
I really like how well they cut, but they really need to come up with a better way to remove them. I've had the washer turn without unscrewing the cutter, it just slips. I've ended up using vise grips which I hate doing.
astroracer
Mid_Michigan
That's what it's supposed to do. "Slip". It may take 3 or more full revolutions of the washer to loosen the cutter enough to spin off. Once the washer is spinning freely the cutter should spin right off. Unless you have a boogered thread on the arbor or cutter. :)
Mark
Farmallgray
Spring Mills, Pa
I just clamp the cutter in a vise with aluminum jaw caps and turn the shank with pliers.
I only have a small set and I haven't used them for a while, but I don't remember the washer or nut you guys are talking about. Anyone got pics?
E
ericlar80
California
Recently I have been clamping the shaft in a soft jaw vise. Then I turn the washer with a wrench while also turning the cutter with my hand. It makes it come off really easy. The only issue I ran into with a tight cutter was that the washer broke in half because it was brittle. I ended up making my own from a grade 8 washer and it works fine.
E
ericlar80
California
It's basically a washer that has two flat spots instead of being a full circle. You are supposed to put the washer on before the cutter.
plinker
Northern Wi
I've found if you put the large flat spring washer on opposite of the way the instructions say, the cutter comes off easier.
The washer has flats for a 3/4 wrench, I usually used either a 7/16 (IIRC) or a Vise grip 7LW locking wrench on the arbor. Sometimes channellocks if it was a smaller cutter with the shoulder (grip on the shoulder).
bobs409
Pottsville, PA
I just bought the small sets in SAE and Metric and can't believe they don't have a better way of removing these dang cutters! This is ridiculous.
Turning the flat sided washer does nothing, it just keeps spinning and does not loosen the cutter. Why didn't they put flats on the cutters or something?
This company is well known and sells expensive tools, not something I'd expect in this case. I'm just amazed on this...
I guess I'll have to clamp the damn thing in my vise to get it off! :mad:
E
ericlar80
California
While turning the washer, hold the bit and turn it too.
mikegt4
sw ohio
Today I used my newly purchased RotaBroach to drill some holes (7/8" and 1") in 3/8" hot rolled strip. Followed the directions in the box, slid the flat washer with flats on to the shank then screwed on the cutter finger tight. Drilled the holes then before removing the bit from the mill used an 11/16" wrench to turn the flat washer about a 1/4" turn which loosened the cutter. Easy peasy. I suspect that many have over tightened the cutter on to the shank, it just needs to make contact with the washer, no more than finger tight. The cutter isn't going to fall off so no need to crank it on the shank.
BTW, it drilled some very nice, clean holes.
walrus
Maine
I use Blair holcutters all the time. Knipex cobras with the holcutter chucked in drill, no issues getting them off
