Welding table build
z-edition 006
Norway
Diy welding/fabrication table
I’m going to build a welding table to use in my garage. Here are a few details of my plan: Paint it red to match my toolbox, 5″ casters to make it mobile. The table top is 60″ x 30″ x 1/2″, two toolboxes to put under the table. I come back with more details later, when i get the last items i need before i can start building the table.
I hope you guys like pictures, because i will post a lot when the build goes on.
Sorry about the mess in my garage, one day it will be very nice and clean here:)
Z
z-edition 006
Norway
Here is the two toolboxxes i will use under the table top.
Dragoonmc
Re: Diy welding/fabrication table
Make sure your casters have good lock mechanisms or you may be chasing that weld piece
Z
z-edition 006
Norway
It looks like you're off to a very good start.
Please share some more details about your plan.
Glenn
My plan is to make it height adjustable, extendable on one side and make a base for my metal cutting saw on the other side.
Today i got some M24 thread bars for adjusting the height and level the welding table. In my drawing you can see the principal on how to adjust the table.
The base for the toolboxxes are finished.
Z
z-edition 006
Norway
I have now cut all the legs to the correct lengt, and working with the mechanism to adjusting the legs.
Z
z-edition 006
Norway
Some progress, i can now adjust the height up or down by turning the nut.
Z
z-edition 006
Norway
Z
z-edition 006
Norway
I have now started to putting the frame together.
Z
z-edition 006
Norway
Duker
Livingston, TX
I think I am going to have to borrow that leg design for a downdraft sanding table I want to build in my list of future projects! Table is looking good!
Sent from my iPad using Tapatalk Pro
Z
z-edition 006
Norway
Just bottow the leg design. I think i got this idea from another member on this forum. I have already borrowed a lot of your welding table design, i hope that's ok. I think your welding table is one of the best diy out there.
Z
z-edition 006
Norway
I put some 4″ all steel whells this time, that’s because i had some clearance issues with the 5″ option.
Duker
Livingston, TX
Hey thank you for the comments and I am flattered. I did the same thing incorporating ideas I found here and other sites.
Z
z-edition 006
Norway
Starts to look like a welding/work table now. I still have a lot things to do before the table is 100% done.
Z
z-edition 006
Norway
Here i have made 3 supporters for dubble power outlets, and storrage for angle grinder and clamps.
rattle_snake
Chandler, AZ
How do you adjust height once the table is complete? Where/how to turn the nuts on the threaded rod? I'm assuming it lifts only the top of the table.
Z
z-edition 006
Norway
I will use a 36mm socket to adjust the table. First i have to drill a hole thru the table top, then put the socket inn the hole. This way i kan adjust all the table legs as i want. I can show you later in the build.
A little update on my table. I’m working on the bace for the metal cutting saw, this is what i did today:
Z
z-edition 006
Norway
Just finished the adjustable base for the saw. Here are some pictures:
Z
z-edition 006
Norway
