c. 1920's Allen "Bay State" Set No. 19
The “Allen” in this Allen "Bay State" Set No. 19…
…is Allen Manufacturing in Hartford, Conn., the company most famous for its eponymous hex keys or “Allen wrenches” used in conjunction with set or safety screws, patented (960,244) by W.G. Allen in 1910.
The "Bay State" in the name is the same as the Bay State Tool Company that supplied Sears, Roebuck & Company its first-ever socket set, the Autokit No. 1, famous for their giant CatCar decal. But it's a few ownership changes (Bay State -> Tudor Mfgr -> Bay State Pump Company) later.
I don’t own a Bay State Autokit No. 1, but Coolford does, and he posted it on GJ here.
I do own a partial Bay State Autokit No. 35 set which I found in an old Phillies cigar tin for a box.
Note that the “B. St.” on the handle of the ratchet is for Bay State, and that they changed their name to the Bay State Pump Company in 1916.
I don’t know if Allen’s use of the “Bay State” name was an attempt to allude to that type of socket set for marketing purposes, but it is certainly a possible and perhaps probable explanation. I don’t know how they got away with it, frankly. Imagine if Blackhawk had decided to call their late 1930’s through late 1940’s socket-to-handle connection technology “Snap-On” instead of “Lock-On”!
Here is a 1922 ad.
And that is only the second most interesting thing about this set.
MORE TO FOLLOW
P
The coolest thing is the ratchet wrench, ratchet head, or ratcheting mechanism, which we would call a “ratchet adaptor” today.
It can be used with the L-shaped extension or a tommy bar through a cross-drilled hole to make an L- or a T-handle.
Previously, and in disagreement with Alloy Artifacts on this point, I had given the honor of the earliest “ratchet adaptor” to Eastern Machine Screw for the H&G Ratchet Wrench, patented (1,428,840) on September 12, 1922. You can see that ratchet head in my Eastern Machine Screw H&G set write-up linked here. They beat AA-anointed Snap-on and Snap-on’s first “ratchet adaptor” (No. 6) to the patent punch by a few months (1,443,413 , January 20, 1923).
But now I suppose I have to very unexpectedly give the honor to Allen Manufacturing, which was granted patent 1,371,350 on March 15, 1921.
I will emphasize that Eastern’s inline, reversible design, which Snap-on would not duplicate until 1939, was much more sophisticated than both Snap-on’s open-geared, spring-loaded No. 6 clutch or Allen’s crude manual external cam-pin (or “dog” as the patent calls it).
MORE TO FOLLOW
P
Let’s look at the ratchet adaptor more closely.
Here is the patent, a zoom on the diagrams so you can see the individual pieces, and the description.
And here are some better views of my ratchet adaptor to go long with the patent designs.
My ratchet head is missing the cam-faced pin or “dog” that should act like a pawl against the “peripherally toothed wheel” at the bottom of that hole, recessed inside the end. It is supposed to be in that opening. That spring would supply frictional tension to the pin or dog.
When the ratchet is turned in one direction, it would push the cam-faced pin over to the next tooth, with reverse pressure forcing it against the other side of the tooth when turning the fastener. To reverse direction, the user literally pulled the pin up (away from the gear), rotated it 180*, thereby reversing the cam face on the end of the pin, and then releasing it again.
The other piece that you see mounted to the screw next to the opening is what he called a “safety catch”, meant to prevent the pin from being inadvertently completely removed or lost.
I am going to try to fabricate the pin or dog.
MORE TO FOLLOW
P
As you can see, my ratchet head is marked “PAT. APLD. FOR”.
Twertsy has a Bay State No. 19 set with a much more intact decal….
(you can actually read the branding)
…a ratchet adaptor with "PAT. 3-15-1921" marked on it…
…and more importantly, no external dog or safety catch!
I am speculating that Todd’s set is later than this one, and in ensuing years Allen must have internalized the mechanism but didn’t bother patenting that improvement. Perhaps Todd or anyone else who may have that version cold explain how the direction is reversed.
MORE TO FOLLOW
P
Here are some photos of the other pieces in the set.
And the latch.
Mike'smeatshop
I know this is an older thread but I have picked up so much here. Would the box be related with Allen, Bay State? Thanks.
P
I know this is an older thread...
Reviving dormant threads rather than starting new ones on the same topics is exactly the right thing to do.
I don't know if their production of these hex drive socket sets and tools lasted long enough to be put into steel boxes, Mike, but all the hex tools look like Allen Mfg to me. The ingenious early ratchet adapter is not an easy piece to find.
Well done.
Mike'smeatshop
Thanks. After I asked I found that even S-K made hex sockets so no marks on it, it could be anyone.
Some bay state stuff. Posted one before on 1921 sockets thread, but I'll put them both here as well.
Patrick Eubanks
Patrick Eubanks
Bay state number 2 kit. Some interesting features like the built in ******** the box. I’ll include some pics. Cool stuff.
this hardly qualifies as "vintage" at present, but it probably will soon enough, and since this is the only "Allen" thread:
Allen 19 piece 3/8" drive SAE Socket Wrench Set w/Original Steel Box
manufactured by Allen Mfg. Co., Hartford, Connecticut U.S.A.
this set includes:
11208 3/8" 12-pt std socket
11209 7/16" 12-pt std socket
1216 1/2" 12-pt std socket (* Fleet brand *)
11211 9/16" 12-pt std socket
11212 5/8" 12-pt std socket
11213 11/16" 12-pt std socket
11214 3/4" 12-pt std socket
11258 3/8" 12-pt deep-well socket
11259 7/16" 12-pt deep-well socket
11260 1/2" 12-pt deep-well socket
11261 9/16" 12-pt deep-well socket
11262 5/8" 12-pt deep-well socket
11263 11/16" 12-pt deep-well socket
11264 3/4" 12-pt deep-well socket
11910 5 inch Extension
11913 RHFT Reversible Ratchet
B1404 Universal Joint (* Williams U.S.A. *)
---- 3 inch Extension (* Mastercraft Taiwan *)
Steel Box
MR.X
So this is from a 1924 version of the book pictured. Looks like a Bay State socket set to me. The book kind of implies that these are examples of tool assortments used by Repairmen on Fords rather than official kits. This book has tons of great illustrations with explanations.
Bay State / see Allen Mfg. Co., Hartford, CT /
Bay State / Bay State "Auto-Kit" see Bay State Tool Co. /
Bay State / Bay State Pump Co., 564 East First St., Boston, MA / see Bay State Tool Co. /
* Not to be confused with:
Bay State / Bay State Tap & Die Co., Mansfield, MA / https://www.garagejournal.com/forum/threads/the-bay-state-tap-die-company.383551/ / https://progress-is-fine.blogspot.com/2015/04/vanished-tool-makers-bay-state-tap-die.html / https://www.garagejournal.com/forum/threads/vintage-bay-state-tap-die-set.166955/ /
Bay State / Bay State Tool Co., 249 Washington St., Boston, MA / see also Tudor / patent 666202 Jan 15 1901 Peter Lord & 761798 Jun 7 1904 Frederick E. Walden & 870014 Nov 5 1907 & 1371350 Mar 15 1921 & 1489696 Apr 8 1924 Solomon C. Campbell / http://alloy-artifacts.org/bay-state-tool.html / http://alloy-artifacts.org/bay-state-tool.html#history / https://www.garagejournal.com/forum/threads/c-1920s-allen-bay-state-set-no-19.426398/ https://www.garagejournal.com/forum/threads/bay-state-autokit-socket-set.341786/ /
  • 1910 Automobile Trade Directory Superior Champion Syracuse Walden Bay State ad pp 471.jpg
  • 1910 Hardware Dealers Magazine Bay State Autokit socket wrench ad pp 840.jpg
Bay State Tool Co., Boston, MA
  • 1920 Baker Hamilton & Pacific Co. catalog Allen Bay State Sedgley K & S Hexall Williams ad pp ...jpg
  • 1921 Chilton's Motor Age Vol 39 Bay State Socket Wrench Set No. 21 ad pp 16.jpg
Patrick Eubanks
Ok I have one for you guys to chew on. I picked this box up at an estate sale this weekend. It completely had me stumped so I started digging. The box was obviously pre 1920 and looked somewhat Walden (ish)
I looked for a separate Bay state in Worcester Mass. As it turns out the only Bay state mfg. ever in Worcester was the same bay state tool co. From Boston. I dug like crazy to see if the ever produced pipe threading equipment or such. No they didn’t.
After a little more digging I discovered that their primary designer early on was none other than Mr. Walden himself. When the were bought in 1906 their manufacturing was moved to Worcester with their headquarters still in Boston. After closer examination it appears as if this was an early catch all tool box. Part of the remaining label has rule and the word Stone which would line up with the tools they were producing at the time.
Anyway I’m almost convinced I’m right. Check out the size of this box. Anyone else ever seen anything like it?
P
Great find! Cool box. I've never seen it before, but regardless of its original use, it would be cool to keep Bay State related orphans and strays in it. Or just empty, for display. As a business entity, they had a dizzying array of names and addresses, and Worcester was one of them.
Patrick Eubanks
And of course now I want all the stray tools. Does it ever end
P
Here's a no. 20 set
Love the speeder! Guess how many pieces are in your set without counting. Guess how many pieces are in the No. 19 set, which doesn't have the speeder, without counting. That was a lot of design work to put the same set - now with a speeder - in a new box! :)
Here's a funny news story from 1857..........
Snerk. Like a horse in a China shop. I looked up John Gilpin, a reference I didn't understand. I thought it was going to be a famous racehorse. It's the name of a draper in England who was taken for a similar wild ride in a famous comic ballad from 1784.
Sbusmech
Texas
Here is a 1922 ad.
MORE TO FOLLOW
Great find! I'm jelly.
Allen Mfg. Co., Hartford, Connecticut model 603 11-piece Hex Wrench Set
The 603 set appears in a 1945 "Radio Craft" magazine advertisement and in the 1945 Allen catalog
Allen 19 pc 3/8" drive SAE Socket Wrench Set
