The Ancient and Independent Order of Oddfellows (Adjustables, that is...)
INTRO...
Two weeks ago I found an antique “FITZ-ALL” adjustable wrench at the flea market and just last week I found a “H and E” (pronounced “Handy”). Those finds got me thinking categorically about these types of wrenches as a collecting niche unto itself, and that sent me rummaging around through my various cubbies and drawers and bins.
Here is a group shot of all the wrenches I own that have an adjustable, dynamic jaw that isn’t moved by a typical thumb-screw attached to a threaded rod or a worm-gear attached to a worm-drive..., as all more common screw, monkey, auto, and pipe wrenches have.
Here’s a little chart I made out of that photo to quickly ID the wrenches.
And here are some profiles - in age before beauty order - of each wrench…
Baxter patent 84,605 (1868)
These Double Open End wrenches were made and sold initially by the inventor out of Newark, NJ, and then Tower & Lyon, Greene, Tweed & Co, E. C. Stearns, and many others as the rights were licensed out. It is an ingenious design. The wrench is made of two halves, mortised, and joined together by a left- and right-hand screw-rod. The halves do not move independently of each other, they move synchronously in opposite directions like machinists’ parallels. Further GJ reading here.
Boynton patent 364,749 (1887)
These adjustable “Alligator” type wrenches, with one pipe and one nut jaw, were made and sold by the Campbell Printing Press & Mfg Company, NY, NY. Tightening that wedge-shaped nut on the threaded rod literally forces the jaws of this wrench shut. Loosening the wedge-nut has no effect on the jaws, which must be manually re-opened. For further reading, see additional photos and information posted in a prior GJ thread linked here.
Tripp patent 587,624 (1897)
This combination adjustable wrench, alligator wrench, spoke ****** grip, and screwdriver tool was made and sold as the “The Best Wrench” by the Best Wrench Company of Chicago and also placed by Sears, Roebuck & Co into the toolkits they supplied with their deluxe bicycles. It opens and closes using lever action. The capacity is 1/16" to 1-1/4”. Further GJ reading here.
Taylor patent D48,996 (1916), Larson patents 1,602,620 (1926), 1,830,033 (1931)
Made initially by Cochran as the “SPEEDNUT” wrench, and later, by the SPEEDNUT Wrench Corp (Chicago), Chicago Manufacturing & Distribution, and others, the jaws on these amazing wrenches are opened and closed by gravity (just turn the wrench over one way or another) and rack and pinion components inside the housing. Further GJ reading here.
Lynch & Mead patents 1,533,602 (1925), 1,735,257 (1929), 1,885,616 (1932), and 2,028,406 (1936)
These may likely be the most recognizable wrench in the lot, because the design has had innumerable modern knock-offs still being produced today in the US, Europe, and Asia. The originals were made and sold by a company called Lynchmead (a portmanteau of the last names of the inventors and original manufacturers), in Turlock, CA, then by Masterench (assuming the name of the wrench for better brand identity), and finally by Heller Brothers (and still branded “Masterench”), who knew a great idea when they saw one – buying the company, patent, and rights. It uses a simple steel leaf spring to provide tension on a dynamic jaw, which self-adjusts to the size of the nut it is grasping. Further GJ reading here.
Zilliox patent 1,639,831 (1927)
Made and sold as the “XCEL Adjustable Socket Wrench” by Park Metalware, Orchard Park, NY, (a company you may more readily recognize by their later name, Xcelite, of nut driver fame), the jaws on these wrenches are opened and closed by twisting the hollow handle left or right, turning the concealed shaft-screw inside. Further GJ reading here.
Fisher patent 1,712,427 (1929)
Made by Bonney Forge and Tool (Part No. 2550), in Allentown, PA, this adjustable socket wrench uses an internal pin-and-slot mechanism the inventor had been working on since 1923. Earlier patents used spring-bearing lugs (1,554,963) and tongue and groove (1,554,965). The two jaws will move continuously in and out when turned in either direction with a ratchet, sliding tee, flex head or any handle with a male 1/2” drive stud until it meets resistance from a nut, self-adjusting to any size from 3/8” to 9/16”. Further GJ reading here.
P
Here are the two wrenches I recently found that inspired the thread…
Fitzgerald patent 1,004,561 & 2 (1911)
These “FITZ-ALL” wrenches were made and sold by Rogers, Printz & Co, in Warren, PA, and the Standard Wrench and Tool Co., of Providence, R.I., and others. Mine is a Standard. For some unknown reason, the wrenches always bear previous Long patents 890,146 (1908) & 955,974 (1910)(see Pic 4), but they are spittin’ images of the Fitzgerald patent that gives them their name (see Pic 5). This wedge-adjust wrench works (crudely, but effectively) just as you expect it would when looking at it, reflecting its advertising slogan: “The harder you pull, the tighter it grips.”
P
Hemphill & Evans patent 1,391,179 (1921) and 1,449,386 (1923)
These magnificent nut wrenches were made and sold by the H & E Mfg Co in New Bedford, Mass., as the “HandE” (again, pronounced “Handy”), cleverly named after the first initials of the last names of the inventors and manufacturers. The “HandE” design – an outer sleeve moving two interconnected spirally-grooved shafts, one coarse and one fine – is brilliant, and this dynamic jaw slides like butter, as you would expect, by sliding that sleeve up and down the handle (See Pics 4, 5, & 6). One seriously hefty tool, too.
P
I’ve had this one for awhile, but I don’t think I’ve posted it before.
Oliver patent 1,436,049 (1922)
Made as the “Wizard” No. 102 by Wakefield Wrench Company in Worcester, Mass., this Double Open End wrench features dynamic jaws that slide and pivot into multiple opening size positions, secured in place by a rack of teeth on the fixed jaw. This is a simple, robust design that could’ve/should’ve (and maybe has?) been continued. The opening size range on the big end is 1/2” to 7/8” and on the smaller end it’s 3/16” to 7/16”. I chalked the marking so the branding and the intermediate jaw size settings would stand out more.
I know that HeelSpur has one, which was the impetus for putting it on my bucket list. His example, and more info on Wakefield and the other tools they made, linked here.
P
A few of the more prominent Odd Fellows currently on my bucket list.
Boos patent D130,015 (1941)
// Cylinder Screw-Adjust // FOUND
Bullard patent 742,389 (1903)
// Spring-Loaded Self-Adjusting Jaw //
C.E. Bonner patent 716,515 (1902) and 737,199 (1903)
// Compression Spring and Shoe //
Eifel patents 1,181,654 (1916) and 1,862,817 (1932), made by American Plierench Corporation
// Lever-Action Gear // FOUND
Gellman patent 1,451,906 (1923) made as the “Polly”
// Spring-Loaded Jaw and Rack of Teeth // FOUND
Giles patent 391,957 (1888) pipe made by Place
//Loop and Rack of Teeth//
Matthews patent D138,173 (1944) made as the Cleveland “Auto Grip”
// Pinned Hook-Jaw // FOUND
Noyer patent 854,174 (1906) made by Richards as the “Wizard”
// Worm-Drive Adjustable Jaws // ACQUIRED IN A TRADE
Robert patent 1,407,578 (1922) made by Hoe
// Spring and Hinges //
Stephens patent angle wrench 943,757 (1909)
// Static Open End, Offset Angle Ratchet Adjust //
Wakefield patent 454,893 (1891) made as Wakefield No. 3
// Lever-Action and Rack of Teeth // FOUND
P
So, no offense to Mssrs Coes, Stillson, Peterson (Crescent), and Thewes (Ridge) et al – because it’s a testament to them that their designs for monkey, screw, nut, and pipe wrenches with moving, adjustable jaws are still being mass-produced today, but what about all the alternative designs, the “better mousetraps”, the kooky contraptions, and the funky “failures” that didn’t make it past the 1920’s? Some of them were ingenious and some of them were perhaps best left on the drawing board, but all of them are interesting to me. And I know I’m not alone.
There are 1,786 different adjustable wrench patents on the Directory of American Tool and Machinery Patents (DATAMP) site. Most of those were never produced. Some of them were produced and then promptly abandoned within months. But a few of the designs were quite common in their day and actually used by mechanics before becoming obsolete. And maybe, just maybe, some of them didn’t deserve that fate.
If you feel the same way, please join me in celebrating the era of inventiveness, before standardization took all the fun out of the tool industry.
Post ‘em if you got ‘em!
And if you can, please try to provide the patent owner’s last name, the patent number and date, and the OEM and brand name, if it had one.
There is really only one hard-and-fast rule I am going to insist on here:
No Coes (or B&S, W&B, B&C, etc), Stillsons (or Trimos, etc), Crescents (or Danielson, Diamond, Utica, etc) etc Allowed!!! :)
P
Tip of the hat to you... in depth well presented post.
Thanks! If you have any weird oldies, post 'em!
There must be a History Channel special begging to be filmed called "The Tools that Built America".
Calling Ken Burns! :bounce:
EDIT: How much fun would it be to be an associate producer for something like that?!
woody:
Not sure what you mean by "stories", but if you're referring to the biographical details (born, died, wife's name, etc) about the old toolmakers that you like to look up from various sources and post, rather than the basic age, location, and patent and production details that I tend to favor posting, they're not "missed", as far as I know. If you already posted summaries of biographical information on any of the names I mentioned, feel free to link your threads in a post here. If not, and if you'd like to do some more digging on the biographical details of Mssrs. Baxter, Boynton, Fitzgerald, Lynch, Mead, Hemphill, Evans, Zilliox, Oliver, Tripp, and Fisher, fee free to post them here.
slowtwitch73
Hellgate
Till I found this site about a year ago I didn't realize guys got so into the older (better imo) hand tools.
I have fond memories of growing up with my dad's ridiculously heavy beat down old tool box from time working in gas stations and on tanks in the Marines.. I loved to paw though it and marvel at the sockets, drivers, wrenches, ball peens etc. All of it is Plumb, Proto, Bonney, Craftsman (long c and newer), Williams, etc etc... a total mish mash, but all if it old American. The Williams open ends were lovely to me back then and still are. Those tools oozed quality back then and they still do.
slowtwitch73
Hellgate
Not sure if what I have is of interest.. not that well versed. I see oddball stuff all the time in pawn shops but really most of it seems inferior in terms of design and actual usefulness outside of historical/collectors value. And I'm pretty damn well tooled up.. hate to say it, but most all the bases are covered.
crguy
SW Washington
It's the ones with odd adjusters that are usually the most interesting and valuable.
I found, and sold, this one this summer. Peterson Rapid Wrench.
P
Agreed. Hence, the whole premise of my thread. The odder the better.
Nice wrench and great example for a first post from someone else. Thanks for sharing.
If I am interpreting your photo and DATAMP correctly, that looks to be the improved patent (1,081,626, dated Dec 16, 1913), linked here, to his first patent (902,830, dated Nov 3, 1908), linked here, where he added that thumbscrew and a spring to facilitate better and more rapid movement of the wedges.
I'll have to add one to my bucket list.
HeelSpur
WV
Was this wrench supposed to have a locking toggle on it? Looks like it would have fit over the nut.
LesserSon
PA USA
Here’s that Universal Wrench I posted on the Garage Sale thread without buying it. Your diagnosis of it being ‘sprung’ was probably correct, else just too much metal loss from wear and corrosion.
I wouldn’t have bought it from that vendor even if it worked, though, because all the other tools in that booth were overpriced IMO.
bbbarracuda
I have one of the Baxter double open end wrenches you show in your first post.
It is marked Baxter's I can't find any other markings. No patent dates or anything. Does the lack of marking make it early or late in production? Guesses are always welcome. Thanks
twertsy
Reedville, VA
Some I've picked up over the years.
Top to bottom:
Reed
Gellman
Andrix
Unsure
Can't remember what this one is. G in a diamond
P
8" Helix quick adjust, Petersen Tool Co.
Top is Stainless Steel
Wow. Now THAT is one cool example, HeelSpur! And I never expected to see anything that innovative as late as 1971. (As soon as I saw the patent number beginning with a "3" I did a double-take!) Not only does it have a spiral shaft, but that turns a bevel gear, which turns another bevel gear to enable the offset head. Reminds me of the HandE with the button slide instead of the sleeve, and my "Onli-1" bevel-geared ratchet. Oddly, though, the angular head and rectangular styling of the handle of your wrench don't look like the patent diagram. (I like yours much better!) I wonder if they were all made like that, or if it means it's a later design.
It is marked Baxter's. I can't find any other markings. No patent dates or anything. Does the lack of marking make it early or late in production? Guesses are always welcome. Thanks
The conventional wisdom among online wrenching sites on these Baxter's patent wrenches are that the earliest wrenches were made by a company Baxter started himself, then by all the other companies he licensed the patent to for a fee. According to several sites (Wrenching News, MVWC, etc), the earliest was marked "W. Baxter Pat Dec 1, 1868." Yours marked "Baxter's" may be later. The "Baxter's" is reminiscent of "Baxters patent", and that is a common marking approach. My Campbell Printing Press & Mfg Co wrench upthread is marked "BOYNTON'S PATENT", the only marking on the entire wrench.
P
Nice collection, Todd! I love the Reed, which looks to be a very substantial hefty wrench! Going to have to look that one up. The Gellman is on my list. That Andrix looks like a version of the FITZ-ALL wedge-adjust design. The one you are unsure of is a Universal Wrench Co (Statham patent 1,305,628). Typical worm-gear adjust - but what qualifies it for this thread is the lever used to turn the worm-gear! I'm glad you posted it because someone on the 2018 Garage Sale thread found one and I couldn't remember the name! (The last two are fairly typical screw-wrench type bicycle wrenches though.)
Were cookin' now, fellas!
wrenchguy
NW Indiana
"The KEITH WRENCH". Someone on Tooltalk looked up the info 4me years back. Only marking i could find very light stamped KEITH WRENCH.
REED No.18 found maybe 20 years back, squirreled away and forgot in 1 of my 3 truck toolboxes. Ain't been looked up.
P
Wish I knew where to find a 6" Gellman :).
Haha! Calling all Todds! (See, this thread is paying dividends to you already!) :beer:
Please post the patent info on the Winner lever-action wrenches if you have it. I am not familiar with that one.
All,
See Post #6 for more info on HeelSpur's Boos wrenches, and Todd's and HeelSpur's Gellman "Polly"s.
P
Here's a 10" LarcoMatic.
Coincidentally, 3baygarage just found a Larcaloy, also made by Larco Mfg, which is the company that bought out Cochran in 1921. I think that was J.V. Larson's company, and that they became SPEEDNUT Corp. (taking the brand name for the wrench). The Larson patent (1,830,033) is what put the thumb-operated spring-clip on the wrench head to lock it in place. What's the patent number on the handle? I can't read it. The SPEEDNUT thread is linked here for further reading.
P
A recent acquisition. Wedge-adjust, obviously. I thought it was going to land up being a miniature Fitz-All, but now I'm not so sure. It certainly resembles a Fitz-All in general shape and principle (see Pic 7). But there's a channel in the static jaw where the dynamic jaw is anchored with a spring (see Pic 6). The wedge provides the adjustment but the spring provides the tension. Ingenious little ******. And Fitz-Alls don't have that feature.
P
Clean-up revealed a very faint and worn marking. It looks like a three-letter logo to me. I am 100% confident in the elongated "S", and the "L". The letter in between could be a "U". Maybe something else. What do you guys see? Anybody recognize it? Thoughts?
r_olson_06
SD
Hey Lugz,
I have a very similar one to that one you posted. It even has the notches on the back if I remember correctly. I will try and grab a pic tonight if it and do a once over for OEM marks.
Sent from my XT1710-02 using The Garage Journal mobile app
r_olson_06
SD
And looks here on the opposite side of the clip. This looks for fimilar. The auction I bought them at had this one 8" and a bigger one that was either 10" or 12".IMG_20200301_172746580.jpeg
P
Very interesting! First of all, your 8-incher looks even more like the Fitz-All because of the raised edges, where as my 6-incher is flat. Also, if it's marked "HAxxxER SCxxMAN", what is the "SUL"? One of them might be the mfgr, and one of them the retailer.
I'm going to post on the 'Old World' thread up on the General Discussion board. Not holding my breath, because that thread's focus has really morphed into a celebration of brand new modern shiny or neon-handled tools.
