Treasured Craftsman RHFT ratchets
b.well
NY
Hello. First I would like to thank everyone for their posts that have helped me understand the quality/history of many tools.
I've seen at least 4 patent versions of the treasured Craftsman RHFT ratchets.
=V= patent pending (1967?)
-V- patents... -1967 (1967-1971?)
-V- patents... -1971 (1971-19xx?)
-V- all patents (19xx-1986?)
When was the 1971 stamp used? What years? My guesses are above in ().
Would this also mean the =V= version was produced by Moore?
I have read the RHFT was released in 1970. I've also read they were available via catalog through 2008. Not sure how that plays out with =V= years ending ~1967 and -V- years ending ~1986.
Please help! Thank you!!
Lesserstore
Texas
While I haven't studied ratchets much, here's what I can tell you.
I'll start with the easiest question: RHFT ratchets after 1986 were not V series, they were marked with other codes, but I don't know what codes.
As for the issue of being introduced in 1970, it probably was sold before that time in sales testing areas, then introduced to all stores/ catalog in 1970.
-V- was first used (on sockets at least) by Easco in 1972.
That's all I can tell you. Someone else will have to answer the harder stuff.
b.well
NY
thehorse13. thanks for the link I have watched a few of his videos but he does not get into dates tied to the letters/numbers stamped in (series, patents,....). He just gives the general range the tools were available.
d42jeep. thanks for the link. I have not seen that one. I haven't dug into it yet. Tried to on my mobile but is quite large. Will let you know what I find.
my thinking on the general v dates/mfgs are:
=V= Moore Drop Forge, ca. 1946 - 1967
-V- Easco, ca. 1968 - 1986
that's why I Propose =V= was manufactured by Moore, and -V- was manufactured by Easco. With that said I also believe dates aren't 100% accurate and their could be some carryover from generation to generation.
If anyone is in the know......please post :)
b.well
NY
d42jeep. doh. from the type study, "The RHFT ratchets could very well be some of the best and most popular ratchets ever offered by Sears/Craftsman. Unfortunately they’re not within the scope of this Type Study?
Jim C.
d42jeep. doh. from the type study, "The RHFT ratchets could very well be some of the best and most popular ratchets ever offered by Sears/Craftsman. Unfortunately theyÂ’re not within the scope of this Type Study?
Not so fast bwell. While the type study focused on the standard 1/2, 3/8, and 1/4 raised panel (RP) Cman ratchets, what I did find was that in many instances, some of the patent numbers and manufacturers codes that were on the raised panel handles were also on the similar vintage RHFT ratchet handles. The same goes for the 3/8 RP flex head, the 1/2 RP flex head, and the 15” long RP 1/2 drive ratchet. As I recall, I wrote that because there was one knucklehead who kept posting non-pertinent **** and mucking up the thread. I was really trying not to encourage him. So, b42jeep isn’t totally off the mark. One could read the Type Study and extrapolate some of the information and apply it to other Cman ratchets of the same vintage. As a matter of fact, if you read the rest of the post that you partially quoted above, I did exactly that, and told the guy that the stamps on his RHFT ratchets were like the Type 11 RP ratchets that I wrote about in the Type Study. Maybe you should have quoted my full response. Just saying......
Jim C.
I guess you will have to go with the videos then. Just trying to help.
:thumbup:
DadsTools
With all the Craftsman stuff out there you would think that all these details would be tied down in a very granular way. Not so. After all this time, there's more detective work to do.
I've handled about 20 of these RHFT over the last several years.
1). The earliest one I've ever seen was marked =v= no model number and PAT PEND with no patent number. It also had the "flat-top" As in Craftsman. According to the catalogs, the flat-top A first appears in 1971-72, though I suspect the actual introduction was earlier.
2). Next, I've seen a -v- with the model number but still having PAT PEND
3). Next a -v- with one patent number ("and others") but no model number
4). -v- with model number, two US patent numbers + the Canadian patent issued in 1971
Numbers 2 and 3 are a prime example of the Craftsman Dating Lottery. PAT PEND should be before the patent number, but a model number should be after one without. Go figure.
Of these four types, the ones with the 1971 Canadian patent date and the two US patent numbers are far more common than the others.
The first (earliest) patent number was applied for 2-12-68 and granted 9-16-69. The second number was applied for 5-1-68 and granted 10-6-70. So based on these....
Type 1: 1968-69
Types 2 & 3: 1969-1970
Type 4: 1971 and forward
I've also seen an example that has -v- with the model number but no patent info at all. I assume this is even later than the Type 4.
Of course, this could all be meaningless, since after all, we're talking the Craftsman Dating Lottery, where anything goes, and did so on a regular basis.
Jim C.
1). The earliest one I've ever seen was marked =v= no model number and PAT PEND with no patent number. It also had the "flat-top" As in Craftsman. According to the catalogs, the flat-top A first appears in 1971-72, though I suspect the actual introduction was earlier..........
........Of course, this could all be meaningless, since after all, we're talking the Craftsman Dating Lottery, where anything goes, and did so on a regular basis.
Hey Dad, check this one out. Although the stamps are reversed on the handle, the letter “A” is pointed. I think your “Craftsman Dating Lottery” assessment has a lot of validity. Putting a timeline on these things isn’t easy.
Jim C.
b.well
NY
You guys are great!
The =V= Patent Pending set I saw had a flat top A for 1/2" and pointed top for the 3/8".
The -V- 1971 (type 4 above) is the set I recently bought and I've been trying to put some production years around them. I saw someone list the -V- 1971 as "made in 1971". Didn't buy that one...lol.
Seems we have a Type 5 and 6 RHFT as well.
Type 5: -V- with no patent info(19xx-1986)
Type 6: post -V- with no patent info (ie VVQ)(1987-2008)
I'll dig in the type study more and see if I can get some year for the move from type 4 to type 5. Do we agree this date should be before 1986?
DadsTools
Jim C.
Don't know what the Cman boys were smoking. I don't think it was crack since it wasn't around then, but there was certainly plenty of other things to smoke.
Another member, Lesserstore, recently conducted a case study on Craftsman sockets in which you posted so I know you're familiar with it. He cited the flat-top A as being introduced in the early 70s based on catalogs. But I know from my research for my vintage fishing tackle book that it was not uncommon for companies to continue using photos, descriptions and line art in their catalogs years after that particular iteration of the product was discontinued. Saved time and money when everything was laid out by hand. They reused just about anything they considered 'close enough'. The same is true in the tool industry. So the Sears catalogs can only take you so far.
Since none of us were actually there when they running the Lottery, we can only go by the artifacts and assess them according to what should be normal conventions when compared with other industries (i.e., in the case of Craftsman, PAT PEND before patent numbers, no-item numbers before item numbers, pointy-A before flat-A, etc.). This has always been a path of fuzzy logic with the Craftsman =v= and -v- stuff. Close thumbnails seem to be the best anyone could muster.
However, the patent info on these unique ratchets that also happen to correspond to the fuzzy years of transition to -v-, model numbers and flat-A may supply us with some more distinct info. Well....just maybe.:dunno: The first convention we'd have to rely on is that Sears was actually being honest when they marked the tools patent pending--that there was actually a patent application filed during that time, and not just something still on the drawing board they were planning to file. So........if their use of patent pending is to be believed, then the dates of the patent apps and issues on the two numbers in question must give us a clearer reference point than ever before.
We DO know that at some point, the pointy-A was replaced across the line with the flat-A, what year depends on who you ask. But, if my dating assessment is correct of Types 1 through 4 based on the patent markings, your pointed-A example gives us a hard date that at least some switch-over occurred during the Type 1 years of 1968-69. That is the hardest date I've ever seen for this. If they followed marketplace conventions by marking patent pending only AFTER they actually filed the patent app, then this date is 100% good. If that's the case (lots of ifs), then for the first time we can say definitively that the changeover to flat-A began during these years. That would be a first!
I think we can say that the issued patent numbers are good for their particular dates because they really couldn't use them until the patent numbers were actually issued. HOWEVER, we really can't say for sure how long of time it may have been between when the patent(s) were issued and when they started using them in the stamping. Let's assume for a moment that they wanted to mark these issued patents on the tool asap.
We do see a sort of fudging on Sears part in my Type 3 with the single patent number followed by "and others"--since they stamped ALL the patent numbers on the Type 4, I think it's safe to conclude that at the time of the Type 3, they only had one issued patent. So I think the Type 3 dates are good.
Finally, if we are going to 'type' these based on the markings, your pointy-A example represents another type. Rounding off to the closest practical years, that brings us to:
Type 1 = 1968; =v=, patent pending, no model number, pointy-A
Type 2 = 1969; same as above but with a flat-A
Type 3 = 1969-70; -v-, patent pending, model number, flat-A
Type 4 = 1969-70; -v-, one patent number "and others", no model number, flat-A
Type 5 = 1971; -v-, 3 patent numbers + 1971, model number, flat-A
Type 6 = ????; -v-. no patent info, model number, flat-A
We cannot say for certain about the chronology of Types 3 & 4 because both has features that would make one earlier than the other. But I think it's safe to bracket both in the same years.
As for Type 5 with the 1971 date, this has been by far the most common type I've seen in-person and online, so I suspect it was made for some years. Which leads me to my ???? on Type 6 dating, because I have no idea when Type 5 ended. We can say that Type 6 markings at some point became the standard markings for all -v- Cman RP wrenches and those with different codes that followed down til today.
If Sears was sincere in its patent-related markings on these ratchets, this chronology will represent the end of the 'fuzzy era' with the most precise dating to date of the transitions from pointy-A to flat-A, =v= to -v-, and no-model numbers to model numbers.
Oy!
DadsTools
You guys are great!
I've noted the type with -v- with model numbers but no patent info in my revised list above as a Type 6. I did not assign dates to it because even the 1986 ending date is uncertain to me. I also did not include and types for those markings after -v- not only because I've never seen an example myself, but know very little about the post-v era. I'll have to leave that to others to complete. I can say with some confidence that, other than the changing maker codes, we should not see any variations post-Type 6. We might then consider the list complete, the Type 6 being the final variation. We might then extend the list by citing Type 6 with various newer codes as suffixes, like Type 6vv, 6vvq, etc.
b.well
NY
I was getting a bit twisted on the RHFT part numbers.
Mine are these and I thought they were the only RHFT models (non flex)
43178 1/4
43788 3/8
44978 1/2
I kept seeing 43781 listed next to the 43788 in repair kits; or 43781 being the only RHFT listed in a repair kit list (don't need one just thinking not a bad idea to have one). Comparing pictures of the two the only difference I see is with the quick release mechanism. The 43788 pushes the socket out. The 43781 only releases the ball (does not push out the center of the drive tang). Is that accurate/consistent for each model?
Also the only 43781 I have seen are only -V- no patents, with model number. So seemingly came later, then coexisted, but have not confirmed that yet.
Maybe the important USA repair kit message here is: if you want your 43788/43781 to have the push out center get kit 44683; and if you do not then get kit 43436.
b.well
NY
Thanks for the detailed posts Dad! I was writing my previous post at the same time as you and didn't see your new posts until after. I like your updated 6 types. I'll keep trying to reveal the date behind the ????
DadsTools
43178 1/4
43788 3/8
44978 1/2
I know there are differences in the rhft model numbers, but never associated them with the type of quick release, never actually paid attention to it. I have an old note in a drawer listing the different model numbers of each size:
1/4" = 43178, 43187
3/8" = 43781, 43788
1/2" = 44977, 44978
3/8" Flex = 42792, 42794
1/2" Flex = 44973, 44983
My note indicates that these are differences in dates, but I'm not so sure. It may be as you say that one has a quick-release ram while the other does not. I only have two rhfts in my possession at the moment (I generally sell these off when I find them, but keep photos of them). Have a 1/2" Type 5 44978 with ram, and a 1/4" Type 6 43187 with no ram. Looking at some of my remaining photos, I see:
1/4 T5 43178 w/ram
1/4 same as above
1/4 same as above
3/8 T5 43788 w/ram
3/8 same as above
1/2 T4 w/ram (no model number)
1/2 T5 44978 w/ram
There's a bunch of these rats on eBay where you can check them out too. I think you may have a point with the ram vs no-ram model numbers. That would certainly be another part of a rhft study. I'm not sure the ram should be used as a criteria for typing, just an explanation of what the two different numbers for each size actually represents.
Good catch!
And please keep us posted!
Jim C.
Here’s one with the =V= manufacturer’s code and a flat top letter “A”. Notice that it also has the new ratchet decal on it like the decal on the example I posted earlier with the pointed letter “A”. I’m not trying to confuse anyone or cloud the dates, but rather illustrate how difficult it can be trying to put dates on Cman tools.
Jim C.
DadsTools
Jim C.
Indeed. Fortunately, we have this variation covered with Type 2. There was probably no need to update the stickers themselves, so they used what's on hand.
b.well's post has caused a re-examination of these early rhft =v= and -v- ratchets, and the appear to be giving us an insight into more accurate dating for these transitional years than we've had before. I find it encouraging. The patent markings are the key, as they provide us with hard external references from the USPTO itself.
b.well
NY
I see a =V= patent pending where the 1/2" has flat top "A" and the 3/8" from the same set has the pointy "A".
Jim, what drive size is your flat top?
Did the 1/2" RHFT ever have a pointy "A"?
I am suggesting maybe Type 1 and Type 2 (in our 6 type list) are just drive size specific differences.
Here are a couple -v- flat top a examples
Jim C.
The pointed letter “A” I posted is a 3/8” drive, and the flat top letter “A” is a 1/2” drive. I don’t know for sure if the 1/2” drive was ever produced with a pointed A, particularly with the new ratchet decal on the handle. I do know that the 1/4” drive was also produced with a pointed letter “A”. Those examples with the =V= and “patent pending” stamp alone aren’t very common. For type study purposes, those are most likely the earliest versions, or what I’d call Type 1 ratchets.
Jim C.
DadsTools
It's possible the pointy-A and the flat-A might be drive-specific. But assuming all three sizes were released at the same time, we'd expect to find the same A variations across the board. Just because the few of us participating in this thread have never seen a 1/2" pointy-A rhft by no means conclude it doesn't exist. We are talking Craftsman v here where anything goes, and just when someone thinks they've got it figured out, a new artifact is found that throws the whole scheme out. We do know that shortly before this, the pointy-A was used through the entire line regardless to ratchet size, so we have no reason at this time to conclude the flat-A was introduced drive-specifically.
One could argue that including the pointy- vs flat-A in these Types is getting too granular. But the question as to when the one A transitioned into the other has been a source of frustration for some collectors, so if there's any way we can continue to incorporate that into the Types it would be a great help.
Jim C.
The best way to determine when various tools were theoretically offered by Sears is to go through the old catalogs. If the drive sizes were not all offered at the same time, the catalogs would likely be the best way to find that out. When researching ratchets for the Cman RP teardrop ratchet Type Study, I can definitely remember seeing model overlap and the delayed introduction of a particular drive size when the other sizes were listed as being available. That was mostly characteristic of the first three Types and I think I mentioned those instances as I presented the material. Unfortunately studying the catalogs from year to year is probably the way to go. It’s tedious work, but it improves accuracy. I wanna say that the first 1/4” RHFT was introduced a year or so after the introduction of the first 1/2” and 3/8” versions.
Jim C.
b.well
NY
Oldtuleguy. Based on the 6 types Dad and I agreed on (mostly Dad:). Looks like you have a nice set of Type 4. I reposted the types below.
If anyone owns a RHFT -V- Type 5 (1971) or Type 6 (no patent info) please let us know your best guess at the year it was new; either when you bought it new, or if the year was passed down to you with the tool.
Thank you!
Jim C.
Here’s an example of a Type 6, 3/8” drive.
Jim C.
b.well
NY
With RHFT Type5 1971 believed to be the most common it's thought to be sold this way for many years. If I follow JimC's type study, the TD -V- had no patents for Type9a (1972). I guess unlikely the patents were dropped on the RHFT in the same year, although I did see a guy on ebay claim that :).
DadsTools
Jim C.
You are right that the catalogs can sometimes be the only reference point we have. But you are also right that they're are not perfect. I remember not too long ago going through 1940s Sears catalogs trying to determine when the older style ratchets gave way to the "egg head" Moore ratchets. I remember a particular catalog where both were depicted in the same drive-size sets on different pages! I bet if you ordered any particular set there was no way to say for certain which ratchet version you'd actually get. Withing the next catalog year or so, they finally got that cleaned up so all photos showed the latest ratchet. This is just characteristic of the old pre-computer days when they had to make an assessment as per time or expense whether to create new art for a catalog or simply re-use the art on hand.
Other factors are involved too that make the Craftsman Dating Lottery such an absorbing mud-hole to play in. One is time of catalog release. A Spring/Summer catalog was probably compiled and printed in the last part of the previous year. Let's take the Type 1 rhft marked patent pending. The patent app was filed on 2-12-68. Would that item be in the Spring/Summer 1968 catalog? Probably not, unless they ran a last minute supplement or had later printings where it was added. It would likely be in the Fall/Winter though. Does that mean it wasn't being produced? By no means. Sears had the greatest retail tool distribution in the country. It could be selling tons of them off the store pegboards before they ever appeared in the catalogs. Point is, when a tool was first depicted in a catalog is not a sure bet that it wasn't being made and sold before then.
However, the patent markings on these rhft provide an uncommon external reference for dating, USPTO being of a higher integrity than even the catalogs. Such a hard reference is almost unique in the annals of Craftsman. These markings then become the most-probable reliable dating reference we have. We also know for a fact that there was ultimately a complete changeover in the line from the pointy-A to the flat-A. The early ratchets circa 1968 showing both style As but also with the patent pending marks virtually guarantees the changeover began to occur during the brief time. Can we say for sure that the change went across the entire line at the same time? No...we have NOS, existing dies, different production run schedules, etc. Such precision would be virtually impossible (and unnecessary) to determine that today. Can we say that 68 to 69 was the year when Sears 'officially' released the change? Most probably. Since, because of the pending mark, we know for certain that none of these 'pending' ratchets were NOS from previous years. In this very rare instance we have a reference superior to the catalogs.
For now, based on the available evidence we have on hand, we have every reason to suspect that the changeover from pointy-A to flat-A occurred in all three rhft drive sizes, making two types across the line. The ONLY reason we could suspect that the first releases had one A or the other based on drive size is merely speculative based on the fact that none of us few participants have ever personally seen one. I myself have introduced artifacts in this forum that were initially met with skepticism based solely on the fact that none of the 'experts' had ever seen one, therefore it cannot possibly be genuine. Several of these were eventually validated with research (and luck). The 'experts' were mistaken. I personally believe that until we find definitive proof, we should proceed with the most-probable premise that all three drive sizes were initially released with pointy-As.
DadsTools
We need to be cautious about drawing too many parallels between the TD and rhft ratchets. Some of my perspective also comes from my years in sales and marketing, which becomes a factor in the way I look at artifacts. I think it's important to keep in mind that the rhft was not perceived or promoted as just another standard ratchet. The fact that Sears plastered every conceivable patent number on the handles (even squeezing them onto the 1/4) is the evidence that these were very special, the cat's meow (or equivalent). They were blowing the trumpet loudly on this. I would suspect they would have kept all those patent numbers on the handles until such a time when they felt it no longer was producing the same kind of marketing advantage (people do grow callous to something they've seen over and over again). At some point, the advantage of a simpler stamp that also made the tool markings uniform across the line would have outweighed maintaining the patent numbers stamp.With all that writing, extra care had to be made to insure they were centered correctly on the tool, otherwise it would made the tool look defective (I believe this was the reason they marked the smallest RP end wrenches with a --v-- during the same time the larger wrenches had the =v= mark...this was covered in another older thread). So I don't think we can assume the simpler stamping based on the TD. One thing's for sure--there's an awful lot of these rhft ratchets around with the patent numbers, seemingly in excess of all the other markings, so it's safe to assume they were made for some years.
I guess the the “doh” was deserved if not appreciated. I checked through my Craftsman stuff to get rid of and this was sitting in there with the rest.
b.well
NY
d42jeep. that's the hot topic item. how long was that 1971 stamp used? Know what year yours is from?
Jim C.
Dad,
I think your educated guesses are probably sound. When I put together the RP Type Study, I relied on the catalogs for a lot of information. I know itÂ’s long, and boring, but if you read the Type Study posts, I frequently mention that the dates of production/availability are a little bit soft. In many of the nomenclature lines, when I wrote the approximate dates of production/availability, I was sure to add “(+/-)” because I knew the catalogs were not going to be entirely accurate. But I will say, the catalogs mostly kept my guesses within a reasonable time frame. The other thing I did was look at tool sets on eBay that included ratchets. There’s a small handful of sellers that have NOS sets and tools for sale. When I’d come across one of those sets, I’d look at the stamps on the ratchets, copy down or ask the seller for the set number and then go to the catalogs to see when the sets were available. I know it’s not a perfect answer, but I did try to narrow down the dates. Besides identifying and then collecting all the Types, trying to put dates on them was the hardest part of the project.
Jim C.
Jim C.
Thank you!
Do you have this one on the list? It reads: -v-, model #, four US patent #s, flat top A.
b.well
NY
Jim
Your type study is definitely more detailed than ours :)
I have never seen a sears catalog. I do not think I have seen RHFT like you posted with 4 patents. I would probably generalize Type 4 to cover yours as well as I believe it would be in the same timeline. Or one could prefer yours be the new Type 5 and the latter types become 6 and 7 respectively.
Jim C.
Hey Don,
Here’s the 3/8” version.
Jim C.
Jim C.
Jim
You see, this is what happens when you try to put a Type Study together. I did the EXACT same thing. In my haste to publish my results, I missed stuff. I’d post what I thought was a complete body of information, and almost immediately someone would point out that I missed one. So what I thought I could do in a few months, actually took me a few years. Identifying ALL the types, and then acquiring them takes time, and if you want to show the readers what you’re talking about, then it takes money too. If you really want to pick fly sh*t out of pepper, then you start getting into tooth counts, internal mechanisms, cosmetic changes, etc. I actually posted something new in the RP Type Study just yesterday. It never ends. You’re off to a good start, but if you want to do it right, start looking at RHFT ratchets on eBay EVERY day. It’s a great place to see what’s out there. You need to identify ALL the iterations and drive sizes that exist with this family of ratchets. It takes TIME. Once you have that figured out, you can start trying to put them in order, determine date ranges per type, etc.
Jim C.
b.well
NY
Not RHFT but it is a Craftsman thumbwheel ratchet. Any idea what generation this littly guy is from? Model 94378. No series marking. No USA marking.
b.well
NY
The current 6 types just address the RHFT V series. Meaning =V= and -V- only. I am agreeable to adding type 7 to include post V series. I do not think we will get more granular with post V than that.
Lesserstore
Texas
These were made in Taiwan by Stanley from 1982-91 but I don't know when the flex stubby was introduced. They were unmarked with a coo too hide that fact. They were made as a cheaper alternative to the quick release ratchets.
