Show your shop made mobile bases
Jayman17
Seattle, Wa
Hi all, I would like to see examples of shop made mobile bases for tools or cabinets/workbenches.
I want to fab some mobile bases preferably out of steel so I can get some practice on my welder. I also want to make the bases with casters that are mounted alongside the base instead of under it. I am trying to avoid adding that much extra height.
I'm not really sure of a solid design where the casters are mounted on the side of the base.
Feel free to post a photo of any mobile bases that you have made, especially those made of steel. Extra attention to the area where the casters meet the base would be appreciated!
Thank you...
Jay
lilredex
Toronto
Here are some..
J
Jayman17
Seattle, Wa
Lilredex, thanks for the photos. The ones with the casters offset up into the base or side mounted is what I was talking about.
Looks like the clamp rack just has some plate welded to the top of angle that you used to mount your casters to.
:beer:
Jay
lilredex
Toronto
Yes, that is how it was done. Here it is again turned around. Notice that the wheels on this end are on a pivoting beam.....automatically keeps it from rocking on rough terrain. I do all of them this way except those on three wheels.
shoot summ
Still a work in progress, hope to finish this up now that the weather has cooled down a bit.
rsanter
visalia ca
Some bases I have made
J
Jayman17
Seattle, Wa
I have built this and other mobile bases for most of my shop machines. The handle is transferable. The handle works like an inverted fifth wheel.
Isbcornbinder, I was just thinking of something like this today. Very smart design! Thank you
Shootsum, wow did you actually repurpose a pallet jack into a mobile base? That looks heavy duty. Thanks
Rsanter, thanks for the photos. I like the offset mount of the casters
Jay
Oregon rock crusher
West of Salem
Here are a few. I put a lot of stuff on wheels or casters just for the ease of movement it allows. A lot of them have jack screws or other means of stabilizing the machine for use. Ed.
J
Jayman17
Seattle, Wa
Ed, really good ideas there, thanks for responding. Simple materials used as well. :thumbup:
Jay
tarmy
Nor Cal
Here are a couple. Most of my portable bases are custom cabinets built with a structure to support the tool...
J
Jayman17
Seattle, Wa
Tarmy, that is an awesome set up you have for your table saw. Nice saw too. :pimpflash
Is that drill press a floor model? I am working on something similar to that for a dp I have. Thanks for posting
Jay
tarmy
Nor Cal
Jay
Thanks...
Yes the DP is a floor standing unit. I actually cut about 6 inches out of the stand tube to get it where it was most comfortable for me to use. The bottom is full of metal cut offs from projects and weighs another 100 plus lbs...so nice and stable.
That saw and DP have what I install on all power equipment...which is a BIG STOP switch. The DP is where I can smack it with my head if something ever gets away and I am afraid to let go!
dreamingmuscle
Tryon Oklahoma
I put most of my stuff on HF furniture dollies.
Between the two sizes offered I've only had to cut up one to make it work better. And took the wheels off another when the dolly would have made the gladiator cabinet too tall.
It's cheaper to buy the dollies then it is to buy the casters by them selves.
That said I'm not trying to move anything real heavy like a lathe or mill. But 95% percent of my shop is on wheels.
MushCreek
Upstate South Carolina
I don't like power tools that can roll in use. My Ridgid Table saw has a pretty nice mobile base that retracts when the saw is in use. I posted on here a little while back about a pair of table movers I made to move our 250 lb.maple farm table around the room. I used lift casters, which I never knew existed. If I were to make a mobile base, that's what I would use. Since I made two table lifts, I only used two lift casters and two regular casters on each one.
icecactus
Nice job on the sliding table. I have the Exaktor ex26x. I was thinking of dong basically exactly what you did. I have longer rails though so its a bit more challenging with the 3rd leg. I also cant keep mine permanently attached for storage reasons as its too deep.
ACtC-3c4i4IBoKra6JWzPqS3yhDygZWby7VKUYPrsDrr_1_tT3O33v15byb4ZKk6Umf18b6_Da2ViaJXIiJyqIGYrt4vQOthoJgFv18Z_gpiET2Y8Ypv_JvXYT3rHjxQN0Q-EBbi2hzRy_GOWxR-maW8_2diVQ=w800-no-tmp.jpg
Here is my custom base. The right hand side pivots so its always on the ground. Unfortunately this base will most likely get cut up as I am planning on downsizing the saw so I can lift it up on pallet racking.
tarmy
Nor Cal
That looks like it makes breaking down sheet easy...nice.
I wanted a set up that was totally attached to the saw/base...look at this photo of the rear extension...it just pops up if needed. This make set up/ break down very easy and fast.
J
Jayman17
Seattle, Wa
Looks like a good solution to move that heavy table, thanks.
Jay
Gutman
ENC
isb cornbinder:
I second the 'brilliant' comment.
Would you care to show a few more pics and details? Specifically some detail of the connection point.
Although similar to a trailer dolly I have, your compact design is perfect for what I'd been searching for to help reduce footprint and improve stability.
Thanks!
Chevota Guy
Palm Springs CA
While not technically a mobile "base", this retractable caster arrangement accomplishes the same function on my 500 lb, lathe. The pipe handle is removable and stores upright on the caster board to avoid a trip hazard.
GALLERY]
GALLERY]
J
Jayman17
Seattle, Wa
isb cornbinder:
Thanks!
Gutman, I agree and thanks for asking him for more detailed photos, I was thinking the same thing.
Bggrnchevy, thanks for posting those photos. Those are some nice bases you've built. I might be copying the drill press and horizontal bs base ideas. :bounce:
GALLERY]
GALLERY]
If it makes it easy to move a 500lb lathe I'm going to call it a mobile base.
Nice job on that, thanks for posting
Jay
sberry
Brethren, Michigan
Would make 1 minor change to the handles if I was to do it again.
shoot summ
Jay
I did, took some head scratching, still have a little issue to work out when I get back on it. I narrowed the head to match the width of the Unisaw, and I took the two lift rods from each of the legs and converted it to a single lift rod in the center. Current issue is the way I connected the push rod under the Unisaw allows each of the wheels to pivot individually so it will tip back and forth, I know how I'm going to fix it, just need to tear it all apart.
DrReid
Oregon
Greetings. I’m a new GJ member and this is my first post. I just made a new drill press mobile base. It’s overbuilt, but it adds around 100 lbs. for stability and it and rolls around very smoothly. Also, third welding project. 😁
macgee
Sepulveda Pass, CA
Greetings. I’m a new GJ member and this is my first post. I just made a new drill press mobile base. It’s overbuilt, but it adds around 100 lbs. for stability and it and rolls around very smoothly. Also, third welding project. ��
Really nice job Reid, excellent first post and welcome to the GJ group. Cheers
J
Jayman17
Seattle, Wa
DrReid, very nice base you made for your DP. Thanks for posting and welcome to GJ! :beer:
Jay
Monza Harry
Windsor ON
I will welcome you as well, but I'm still a newbie myself! I tried lurking first but an issue between this site and my computer meant I seen very few pic's so I joined up, about 2 years ago I see [I thought it was like a year tops:eek: I had to go and check]
That base is real nice and as for the highlighted section above, Ha Ha Ha Ha! That is usually a much favoured approach around here! Myself included, anything worth doing is worth over doing, like it should embarrass overachievers doing! :shocking: :thumbup:
I'll add this as my contribution for now: My 30" fan was a bear to move so I added wheels, then I seen Oregon Rock Crushers drill sharpener and had to "Finish" them: If I was to do them again they would need to be further back and much wider for what I wanted. Oh and it will get some sort of handlebar! Harry
DrReid
Oregon
Thanks for the kind welcome and compliments. I patterned my DP base loosely upon a design built with wood, and I had a bunch of 1/2” plate left over from my welding table build, so I thought, why not? I should have recalled that even automobile wheel dollies aren’t built anywhere near this rugged.
bradpac
Central TX
Very nice base. Keeping it low and plenty of weight, that press will have a hard time tipping over.
DrReid
Oregon
The valanced 'fenders' are a nice touch. Did you make those?
Monza Harry
Windsor ON
Yes, I was just going to cut some plate for three sides but ORC and Doc's Machine, Don Long, and many others showing off their beautiful creative stuff really pushed me to up my game.
Renegade1LI
long island ny
Some real nice designs! Here is my TS cart tried to get as much storage & organization while keeping it mobile.
