Upgrading hex keys (Allen wrenches)
larry_g
oregon
Those would be nice until you damage either end. On a key made from bent hex stock you can repair the worn end or the broken ball end by just grinding is shorter. I'll stick with my Bondus.
lg
no neat sig line
FuzzyTiger
Canada
lg
no neat sig line
I know that's one of the 'design features' of standard hex keys.. But honestly does anyone ever use it?
Actually on that note, I find hex keys to be pretty worthless in the first place. I immediately toss them in the garbage. Hex drivers and sockets are much more useful and easy to use.
But as far as hex keys go - those Swiss PB ones are probably the most thoughtfully designed ones I've seen. The ball end on the long end makes perfect sense along with the standard end on the short side and knurling along the length.
matt_i
I like the multi-color which I think was excellently piloted also by PB Swiss.
But, now Bondhus has sets along the same lines for mortal money, the coating is not as durable (seen some German OEM techs with well-used PB sets and they look fantastic) but its definitely a helpful visual aid.
CentenIJ
I agree. I sometimes found it baffling how some people will spend more than $20 for a set of hex keys and/or have multiple sets of them. They do have they’re place but I rather get a nice set of hex sockets. Just my opinion though, I rarely use mine so I might be missing something.
FuzzyTiger
Canada
I find it baffling that anyone would spend any money on them. You get them for free with every random thing you buy and then you immediately toss them because it's a garbage tool. I like my hands too much to put them through using them.
A socket + ratchet is better in every way. And you can probably get a full set of sockets + a ratchet for the price of those PB Swiss keys as nice as they are. Now... I did happen to spy some PB Swiss sockets... And those are pretty exciting.
justintendo
pennsylvania
there are a few times ive had to use hex keys, as nothing else will fit because of clearance. certainly enough to not throw them away.
many of my t-handles have been reground..not the L-keys so much.
T
tanukiboy
Japan
I guess my use case is probably a bit different from that of a lot of folks here at Garage Journal. Those PB Swiss hex keys are mainly used for assembling, disassembling, and adjusting my photographic gear. They are great for camera/flash accessories, tripods, and things like that.
Notgrownup
Snow Hill NC
Most of what I use is Torx on the Harley, but yes a good set of hex and torx sockets and the small driver inserts work well and easily identifiable
acer66
Western North Carolina
I constantly use them working on my bicycles so I have spend more than $20 on them.
Also have a set in my tool bag at my job because I have no need for ratchets and I need to travel light.
But I will take a look at the hex sockets since they will feed my tool addiction.:beer:
RoundedNut
driveway
I agree with some others in thinking it "suboptimal" ;) to have high end bent metal sticks. They're cheap enough to toss into ikea furniture kits and only used by people who don't have any tools.
I first started using a hand me down Xcelite Series 99 hex blade set in the 70's and never thought hex was any different than other fastener drives like Robertson or Torx.
I accept the existence of the madness however, since Philips and slot drives also continue to be used.
1982fxr
Phoenix
I prefer sockets but use allen wrenches a lot because of clearance issues.
I wouldn't compare the junk they throw in with furniture to a decent set of Eklind, Bondhus or whatever.
That's like saying I bought a 300 piece tool kit for $9.99 and it has a ratchet therefore all ratchets are junk.
M6erfan
'Merica!
Sometimes a hex key is the best tool for the job. Off hand I'm thinking about (some) 2 stroke intake manifolds that won't allow a typical ratchet in due to obstruction. Hex keys were about the only tool for the job. But with the wide availability of small bit drivers, they're pretty much what I use these days. My hex keys don't see much use anymore, but I'm glad I have them when I need them.
Those PB Swiss keys in the OP are super nice.
measuredtwice
USA
YES! Allen drive sockets and Allen wrenches. Do you want to start it, or should I? ;)
I am surprised this thread has been as active and popular as it has been.
If I understood correctly, the OP in that topic wanted to discuss sockets as well as keys.
I've accumulated keys from Allen USA, Eklind USA, Bondhus USA, Wera and others. I don't know about now but back when I bought them, they were often inexpensive. At local brick and mortar stores, they were often clearanced. The Wera hex-plus set is around $6 regular price. It's the short set.
If there's clearance, I prefer to use bits and a bit holder or bit ratchet. I've been happy with the USA-made bits that I picked up at Menards for $9 (after 11% off).
This USA-made set for $10 (or less after 11% off) is a good deal. --> https://garagejournal.com/forum/showthread.php?t=437221 I use them with my ratcheting screwdriver.
Also check out Wera's Hex-plus
bob15
Northeasten, CT
At my old job, yes, I would grind down the key as it would get rounded out (on both my socket and keys). Also had applications where a stubby key was needed, so you made your own.
Ralf11
PB Swiss for the quality & colors, the geographic proximity to the OP's German car (Porsche 912).
Bondhus for cost (I dunno maybe he has a Polo engine in his 912). Always ask yourself: what does this hex key have that makes it worth the cost delta over Bondhus?
I like my Snappy hex socket pretty well but dunno if there are better ones. Dunno what Hazet has for hex sockets.
I DO KNOW that he wants a set of the ring grip type from Ko-ken. There is a thread on here somewhere about them - I am likely the OP asking about them. I got them and they look real nice - only in 3/8" tho. IIRC Wera makes them in 1/4" drive. he only needs certain (DIN) sizes of anything for a Porsche.
Then there are the bit ratchet sets, and the close clearance bit ratchet sets...
abt12
I use a color coded set of Wera keys for L hex wrenches, and the Bondhus T handled set when I have clearance. I use Wera drivers at work a lot, but I have a much harder time judging torque with those for assembly. The Bondhus T wrenches definitely don't last forever but they're not bad for the money.
Renegade1LI
long island ny
Hex keys like screwdrivers, have a set of good quality in every tool box and don’t really think about them, they’re just there when you need them.i always check eBay first for nos like these craftsman usa keys,20$ For both, one from hd are probably just as good, i just like to find usa stuff first.
speed bump
Butte Montana
I like Bondhus and Elkind hex keys. I treat hex keys like consumables, use them until the tips start rounding, cut them down or throw them away. Once I start seeing gaps in sets I order replacements. I'm not sure a fancy set makes any more sense than the plain jane ones.
Sockets are nice but once I am more than 5 ft away from the tool box that is a lot more to carry versus just grabbing a set of hex keys.
racinfarmer
Minnesota/Utah
I have a 2.5' long tube named the "Tube of Persuasion" that I put over hex keys to break stuff loose.
I can't do that with my t-handles and I don't always want to wreck a hex socket if it is questionable.
Use this method all the time.
Legion Prime
Leelenau County MI
Yup, the Bondhus 2x ball end hex keys made pulling and reinstalling the harley intakes this summer way WAY less laborious than they looked like they'd be. In fact I liked them so much and they're so inexpensive I preemptively ordered a metric set as a just in case.
Yup, I have a tiny Blue Point angled handle 1/4" bit ratchet with a hex bit I chopped both ends off of so I could do the VW/Audi window block recall without doing anything more than pulling the door panel. Also needed a 1/4" hex maybe 3/16's of an inch long for something I was working on this summer. Only needed enough to fit in the fastener and slip a wrench over. Damned if I can remember what it was but I've still got the stub in a magnetic tray in my toolbox. LOL When it comes to cheap & effective, hex keys can't be beat.
larry_g
oregon
As an industrial maintenance tech working in the high tech manufacturing arena I can say that 75% of our fasteners were socket head screws. So I have a bit different point of view than te auto mechanic. At one time I counted 17 different sets of tools for turning Allen screws. These ran from the basic hex keys to ratchet sets, T-handles, socket drivers, and a few more forms. The basic set of hex keys were the goto tool and always in my pocket. Over the years many of the L keys were modified to fit the job at hand. We had custom extenders to add leverage when needed.
So my comment in post two is based on MY experience. If you need some special formed, fancy finish, or something else then go for it. My experience of 25+ years carrying tools for hex fasteners says it's hard to beat the basic L-key for everyday use. I would say the L-key in my work life was akin to the basic combo wrench and socket set are the basis of the a good tool kit to repair a vehicle.
lg
no neat sig line
shalamo
I’m a machine builder so I can definitely see those being handy everyday. We use sae and metric Allen’s on everything and sockets don’t fit between a lot of assemblies. I’ve looking for something like that.
shalamo
Amen.
MushCreek
Upstate South Carolina
The best I've found are Wera Hex-Plus. As a mold maker, we use hex keys almost exclusively as the socket head cap screws are ubiquitous in injection molds. We routinely use pipe cheaters on them, all day, every day. We do use hex sockets with impact guns for the bigger ones. When I was the boss, I gave them to all of the guys because they work a lot better for not stripping out the heads on the cap screws.
Wyoming09
Wyoming, MI
lg
no neat sig line
This.
While the keys in the OP are very nice they really would only be good for times when clearance isn't an issue. I have a box of modified hex keys that that have been reground or cut off in order to gain access.
Qualitytools
SOCAL
I purchased a set of the WERA HEX PLUS in order to get to a fastener buried near the starter on my BMW to replace a faulty crank position sensor, because I was afraid to damage the fastener and the ulternative was not good. I was very impressed with their fit and finish and was able to undertake the task at hand with success.
In fact I purchased a set of WERA HEX PLUS bits to compliment the L keys for those times where access needs a bit of ingenuity
designer485
Orange County, CA
I'm really intrigued by these:
https://www.parktool.com/product/sl...t-thh-1?category=Hex & Torx® Compatible Tools
Anyone use them or a similar set? I dig Park Tool for their contributions to the biking community, but I'm curious who the OEM is for those.
I reached out to them a while back and the COO is Taiwan. For this style hex wrench, I think ones from Beta, PB Swiss or USAG are nicer. People seem to praise the ones from Silca as well but I don't know the COO of those.
