Jack Stand Recommendations
cls89
Southeast Michigan
Looking to be some simple 3 ton jack stands. This would be to work on a sedan and a compact car.
I purchased a nice Daytona floor jack from HF. I don't want to buy their aluminum stands. I prefer steel. I'm looking to spend around $50-60 for a pair of stands. Any Recommendations?
f4 plt
Take a look at Jack point Jack stands American made , sturdy and unique design makes them perfect for modern vehicles with limited jacking points
Bacon!
Depends on what features you need, specifically if you must work on uneven ground or soft ground, even asphalt then you want a larger base with flat feet on them.
If you don't need these things then I'd just get a $30 pair of Torins or really any name brand, not generic including not Harbor Freight.
Some people feel a safety pin is important. I have sets with and without and would pay a little more for the feature but not a lot - I inspect my stands before use and have never had a failure where it would have mattered. It is extremely difficult to accidentally bump a (non-defective) jack stand hard enough to release it while it has significant (corner of a vehicle level of) weight on it. Almost impossible, that's why there's a shear pin on that type of jack stand.
macs_rock
Idaho
Another vote for the ESCO 3-tons. They get fairly short if you're only trying to take a wheel off, and fairly tall for getting underneath when you need it.
71goldss
Northern Calif
I have a pair of the Strongway double locking jack stands from Northern Tool. Loving them so far! Mine are 6 ton, but are also available in 3 ton. Very affordable also! I’ve been considering switching out all of my current 3 ton stands to these.
wwk68
Midwest
Looks like the 3 tons are back ordered online and not available for me locally. Must have had a run on them. I could buy up, but my largest vehicle is a 99 Chevy Silverado 1500. I'm assuming much larger vehicles require the 6 ton.
drtyler
These are very nice, but cost a lot more than $60 per pair.
The Sears Craftsman 4-ton stands that were heavier duty have always worked for me, but I am not sure if they are available anymore.
It looks like sears no longer carries them (or any Craftsman branded jack stands). However, the OTC stands look similar and generally have a good reputation. I would probably go that route (Zoro with 20% coupon will get a 6 Ton set OTC S06 for close to the price you are looking for).
charbar
Midwest
Are most 3 ton jack stands even tall enough to get a 1/2 ton pickup off the ground? (assuming you are on the frame and trying to get the front wheels off the ground)
I think anything name brand is going to be fine. I have OTCs, some CarQuest ones, some no name el cheapos, and a set of 3 ton Craftsmans. They all look about identical and never had an issue with any of them.
wwk68
Midwest
Good question. I've never owned any jack stands, and just recently have been on the hunt for stands and a floor jack. Hope somebody chimes in to set me straight.
Los_Control
West Texas
I advise against 3 ton. They look like they will do the job, they really are small though.
I have a dodge minivan, in order to lay on my creeper under the car, I have to raise them all the way up.
I am currently changing the starter on my 1991 silvarado 1/2 ton.
I have 2 4x4 blocks side by side, the jack stand on them and still raised to highest position. This allows me to get under it on the creeper.
A few months ago, there was a recall on Harbor freight 3 ton jack stands, turns out the ratchet lock sometimes would not lock and drop.
A month later it turned out the same stands were sold to many retailers and you needed to check the model # on your stand.
For this reason alone, I would prefer to leave the stands in the lowest position if possible. The 3 ton are just to short imho.
I only have 2, I need 4. Next time in town will pickup some 6 ton from tractor supply.
Then later 2 more 6 ton and set the 3 ton aside. Also the 6 ton never had a recall I know of.
IndyGarage
Indy
Napa has a decent pair of 6 ton stands for $50 and 3 ton for $30
I find the 3 ton to too short a lot of the time under pick ups and SUV's.
https://www.napaonline.com/en/p/BK_...and&impressionRank=7&keywordInput=jack+stands
Personally I'd look at whatever they are selling at Harbor Freight. After all their recent jack stand problems, I'm sure whatever they are selling now is much improved.
Bacon!
The Northern Tool Strongways are made by Torin. You might check ebay for them or the Torins, as Northern Tool has an ebay storefront and I once got a good deal on the 6 ton Strongway on ebay, around $32 delivered after an $8 off ebay coupon.
It is not really a matter of needing more tonnage. Rather I would get the tallest stands that are still short enough at their lowest height to fit under your vehicle at the desired locations once jacked up.
This also means, all else equal, that they'll have a higher max lift height which can be VERY useful for working under the vehicle. A few more inches clearance can mean a lot in what kind of contortions you have to do or amount of leverage you can get without as much fuss, and the larger base footprint means more stability.
I don't know about your '99 Chevy, but some newer trucks and SUVs can benefit from taller than the average 3 ton stands... but along with that, if you don't have a high lift jack, you may not get the full range out of a 6 ton set, unless you put an extension on the saddle to get more lift.
I have both 3 and 6 ton and only get out the 3 if the 6 won't fit. So in other words, get both... or jack up your vehicles and measure what'll fit where you want placement.
71goldss
Northern Calif
It seems to be somewhat common for the Strongways to have a 2-3 week ship time. Went through the same thing when ordering my 6-tons last year. For me, the three week wait was even more worth it once examining them in person!
Crabman
Alexandria, VA/Dameron, MD
If you do an Amazon search in all departments for three ton jack stands and look down the left side and click "used" you can often find a deal on a return with a trashed box or whatever.
wwk68
Midwest
Wow, thanks to Los and Bacon.....great info. Definitely will go with 6 ton, realizing I may need to invest in smaller ones for our smaller vehicles.
Can anyone vouch for ProLift? These look pretty good.
https://www.amazon.com/dp/B074R17GL4/?tag=atomicindus08-20
bmcneil
NE Nevada
I have a couple sets of the Torin 6ton double locks and they have been awesome. Great height to them and with the double lock, I don't worry about them somehow dropping the car on me.
I agree on the 3 ton being to too small height wise, I have a pair of 2 ton and 3 ton that I keep around for supporting the axle when I'm working on suspension stuff.
BM
wwk68
Midwest
Someone mentioned earlier that Torin makes the Strongway jacks (sold at Northern Tool), but I see the Big Red's are double the price for the same tonnage. Anyone think there's that much difference in quality? Or is Torin just a brand name that's trusted?
oldldh
Fairhope, AL
Long time --- No post...Old folks are continuing to fall apart...
Oldman's Wisdom --- If three tons is good, then six tons is twice as good...
Sunex 1006 Rev.B 6 ton Jack Stands are well worth the money...
I received two of them, and a 3.5 ton Floor Jack, for free, to evaluate from Team Sunex...The jack is comparable to my neighbor's "Tool Truck" brand, at one third the cost...He liked the jack stands so much he tried to steal the two test stands...After a good pummel, I convinced him to buy some...He did, four of them...
An internet search will turn them up at less than $ 70.00 a pair...($ 62.54 from www.carid.com )
Not too shabby a deal...For well constructed, heavy duty jack stands...
Bacon!
There's no quality difference, the Strongway are just the last generation design with slightly different shaped A-frame. Apparently Torin did this so they could sell to 3rd party rebranders but still try to maintain a premium for their name.
The price difference wasn't that much the last time I priced them, though if going by Amazon prices, that's highly volatile, can fluctuate up and down a lot.
Right now I'm seeing the Strongways on NT for $53. I'm seeing the Torins on Amazon for $110, but that's a far higher price than I have ever seen them before! Normally they were closer to $60, pre-covid.
I know Torin makes them because when I received my Strongway, a shear pin was broken and I called the customer support phone # and Torin answered. ;)
jonesg
northern Maine/
I have those, too short for a pickup , I use mine for a volvo station wagon.
Use plywood foot pads on asphalt because the feet are sharp.
Most jacks are safe until you start wrenching with a breaker bar.
Muckin_Slusher
Abitibi
I've got the princess auto 12 tons. Reasonable price when one sale, which is often.
I wouldn't use them on anything near their "rating" but I like their height and stability. Usually they're set about halfway up unless they're under a straight axle.
If you want more height from smaller stands weld them on some old steelie rims.
HenryAZ
MEMBER EMERITUS
South Congress AZ
Another vote for ESCO, shop around and you can get them at a good price.
ESCO here, too. I prefer the pin type vs the ratcheting type. I did replace the silly little (undersized) linch pin that keeps the main pin from shifting off with a wire lock clevis pin that at least fits the hole. I also don't like linch pins because the ring can open up at times, and this is more true with the smaller ones (as is provided with the jack stand), because of the light retaining spring .
e36jon
San Francisco CA
https://www.garagejournal.com/forum/showpost.php?p=8362930&postcount=43
I detailed my purchase a while back in another thread, above. I bought these for ~$65 on Amazon and have really liked them. They're rated for 6,000 lbs for the pair. My favorite part is the threaded top pad, so that I snug the stand up to the car instead of trying to align the stands so that I can lower the car onto them.
BlakeTheCarGuy
Roanoke Virginia
I’ve got a Craftsman set at home from Sears they are 3 ton I believe and they do fine. They don’t have a pin they have a bar you pull to adjust them. I use those at home sometimes with my Daytona Jack. I mainly use my homemade Jack stands that another mechanic made way back in the 1950s and 60s made from Model T Ford axle housings. Some have the pin some don’t he made them all himself and I bought them at his estate sale they are very strong and durable. I think there is 5 pairs in total. I fully trust those because of their weight. At work in the rare times we use a Jack or Jack stands we have OTC stands with a Daytona Jack.
ajchien
Los Angeles, stuck on the 60 freeway.
I bought the 2 ton MVP set back around 2003. A few years later I got the 4 ton craftsman. Then I got the 6 ton US Jack around 2010.
IMHO, It’s not the capacity, but the extra height of a 6 ton (around 25”) stand that makes it the most versatile, which makes it most used. I have a full size van, and if I want to put the stands on to the vehicle frame rails and let the suspension hang, I’m maxing out the stand height.
Since the 4 and 2 ton are about the same height max fully extended, I will use those on smaller vehicles for tire rotations or times when I want all 4 wheels off the ground. I would think if you eventually got 4 of the same type it would make it easier to keep things all at the same height.
Highland
Oklahoma
Been buying Lincoln/Hein Warner stands as needed since about 1990 and haven't found any problems yet. They used to be made in USA, but now I think they're assembled here from parts from who knows where.
Think I have two pairs of the 3 tons and three or four pair of the 6 ton versions.
Six ton jack stands are more versatile, but sometimes are kinda overkill.
Not the cheapest but I like to think I'm paying for extra quality inspections!
