12x24' Shed build---
bigblue02hd
Landenberg, PA
After moving into our house in 2006 and trying to store most of our "lawn" related items in the 1 car house garage I decided we needed a shed. So I started planning on the construction of a 12x24' shed. This is the progress:
Ground breaking, Fall 2006-
Framing floor joists (2x4 TYP on 12" centers)-
Plywood subfloor (3/4")-
Walls starting to go up (2x4's on 16" centers)-
Smartside sheathing and roof rafters-
Roofing and Doors, 36" walk-in, 8'x7' Garage, January 2007-
Trim-
Ramp built, Summer 2008-
The pic above was the final pic I had saved on the computer and it is from the Summer 2008. I'll get some updated shots now as its all landscaped.
rockchucker
Seattle WA
Looks great! Just curious though...Why not pour a pad? Are you planning on moving it at some point in time? You might want to tie your Truss System together also. You will lose a little height in the Peak but it will help over time to not push the sides of your building out.
3cyltrbo
agree with tying the trusses together, (trusses rarely fail vertically, they usuallly fail horizontally)
nice build
hoping to do the exact same thing in my backyard.
W
51rider
London, England.
That shed will be about the same size as my final garage space:shocking::shocking:
You guys are so lucky to have the space available to build decent 'shops & garages.
bigblue02hd
Landenberg, PA
Thanks everyone!
You can't see it in the pics because the angle of the shot, but before the roof sheathing went on I did collar ties on the rafters. I agree and wouldn't do it without them!
The reason I didn't pour a pad was b/c I may have to move it someday. Its close to property line on that side of my yard. My dad currently owns the adjoining property and someday, unfortunately, it might come up that it would be too close.
Finally, just this past winter I ran conduit out there and wired it. I only have a few receptacles and two flourescent lights, but it'll do!
I just built the shed from scratch. I'm a self employed general contractor and love doing these sort of projects.
Thanks again for the compliments!!!
sgarver
Looks pretty good from here!
What do you think it cost you to build it?
I was just looking for a spot in my yard to do the same thing.
also looking for some plans as i am not a contractor.
your descriptions as you go are almost enough to build from
thanks for your pictures and information
nate379
Palmer, AK
Do you think 2x4s are going to be enough? I am planning on using 2x8s for my 16x20 shed, supporting it in on the edges and in the center, so roughly an 8ft span
rockchucker
Seattle WA
Thanks everyone!
Good show! I figured you would with the rest of the project looking spot on just making sure though!
Very good reason to not pour a Pad! Excellent work man.
bigblue02hd
Landenberg, PA
Thanks. I remember adding up receipts at one time and coming to around $2500.00. I can't find that list/paper now, of course. Glad I could help and give you visual assistance.
Mine 12' wide, with 2x4's on 12" centers. They are supported on each end, a quarter, half, and three-quarters of the way throughout. It is definitely enough. And I've used 3/4" plywood for the flooring. It doesn't give at all and is very sturdy.
Most "store" bought buildings use much less material. Sometimes 2x4's on 16" centers and 1/2" or 5/8" plywood.
Thanks man! :)
nate379
Palmer, AK
Was wondering cause my Dad had a small shed, around 8x10 and it had a 2x4 floor. Was supported on teh sides and the middle and after a few years it was getting really flimsy. Pull the 4 wheeler in there and it would noticeably drop.
I figure the cost of a 2x8 vs a 2x4 isn't too much, I want to say around $5 vs $7 and replacing the floor means tearing the whole shed apart so may as well overkill it a bit.
I may even support mine every 4 ft instead of 8. The 4x6 beams are $40 for a 16fter though.
Thanks man! :)
bigblue02hd
Landenberg, PA
ok ill ask how much to build
do you save a lot over buying one
and you did a great job
Thanks... yeah like I said in the post above... I remember only spending around $2500 for all the materials. So it was definitely alot cheaper to build this one then buy one (in my area). Plus I know mine is better built compared to the "store" bought ones.
Yeah we typically build everything overkill. :)
So I'd go with the 2x8s if you can get them now. Better to build it overkill, then regret it later!
bigblue02hd
Landenberg, PA
Yup... born and raised, and I'll probably die here too!!! lol....
Definitely a small world... my grandparents used to live right near Little Britain. They lived right off 272 near Little Britain Store.
nate379
Palmer, AK
Dunno if 2x8s are overkill or not. Decks are normally framed with 2x8s so I figure if you go that large on just a deck I should as well on a shed that will have several thousand lbs in it. If I had my lawn tractor, an ATV and a snowmobile in there, that is roughly 1800lbs just in those machines.
I may even support it every 4 feet instead of 8.
PurdueSD
Indiana
What is smartside siding??
Fiber cement?
Masonite?
Where did you buy it and how much?
Thx
hicketts
Lancaster County Pa
Fiber cement?
Masonite?
Thx
Around here you can buy it from the many Amish shed building firms, it is supposed to be rated for exterior use. It's not much more than regular T1-11, I think last project I used it for 5/8" was around $23 at Stolzfus in Atglen Pa.
hicketts
Lancaster County Pa
I live right off Green Lane. If you don't mind me asking whats your name. I am Ricketts
bigblue02hd
Landenberg, PA
Yeah, I've gotten that Smartside from Lowe's.... its about $20-$25 a sheet. It is OSB based with a wood-grain finish on the outside. Its primed (tan) already and is supposed to be resistant to bugs/rot.
Wow, I was gonna write that in my last post to you... but my grandparents (Griffith's) lived at 80 Green Lane. The lighter-colored brick rancher on the right after the new lane that goes back in there. My grandmother sold the house years ago and moved to a townhouse in Quarryville.
SyTyJim
Pooler, GA.
Nice build! I'm going to build one myself too this summer. Just curious what spacing are the rafters? 16" oc?
Jimmy
hicketts
Lancaster County Pa
I am neighbors with Grandparents old house. I am the house they built behind them through the pine trees, the yellow two story. Your grandparents old house now has a 30x40 metal building off the garage. Did you have a younger cousin that went to Avon Grove about two years ago, but he lived in Oxford. If so I had him as a student.
bigblue02hd
Landenberg, PA
Here are a couple more recent shots... Don't mind the mess, its driving me crazy!!! I'll get it all organized as the weather warms up here and get some new shots. I can't wait for things to "green" up around here:
collar ties & loft:
small bench:
outside:
Jack Olsen
Los Angeles
That angled corner on the bench is one of those details that -- for me -- really elevates a basic piece of equipment.
thomask
Sunshine State
bigblue:
A really nice build up there in PA.
Great idea to be able to move her if ever needed.
Did it require permits or was it considered a farm building?
I agree with Jack Olsen on that cool bench detail.
bigblue02hd
Landenberg, PA
Thanks guys!
I did the same "clipped-corner" detail on my bench in my 6x12' enclosed trailer. Keeps you from bumping your hip on a sharp corner when moving around too.
The only thing they'd be picky about is how close it is to the property line, but currently its owned by family so there isn't an issue right now. Someday when we have a chance I'd like to buy alittle more property on the other side of the building from the family and then I wouldn't ever have to consider moving it.
bigblue02hd
Landenberg, PA
Thanks..
I can get you an exact measurement tomorrow in the daylight... but just looking back at the pictures I'm gonna say they are about 91" tall (stud, bottom plate, double top plate).
I didn't want to cut all the exterior wall sheathing down from 96". And, I wanted the sheathing to cover the end grain of the 3/4" plywood flooring and the 2x4 treated band boards. Plus it covers alittle bit of the 4x4 main flooring beams as shown in the siding pics on page 1.
SyTyJim
Pooler, GA.
I have another quick question for ya!
Is the roof a "6-12" if not, could you tell me what it is.
Thanks again,
:bowdown:
Jimmy
bigblue02hd
Landenberg, PA
Wow... slacking on my part! I haven't been on in awhile to update.
SyTyJim-- No problem. Yeah its a 6/12 pitch.
Finally got some of my wiring done inside the building. I recently just had the fluorescent light plugged into a wall outlet. So I finally cut a box into the gable wall so I could mount my motion detector and wired it up to a wall switch. And, while everything was out, it made sense to hard wire up the fluorescent light as well. I'm going to add another 4' light soon.
Also I got some exterior trim painting done and finally installed my garage door seals. It'll feel nice soon to have finally "finished" a project! Haha.
I'll post up some recent pics when I get a chance.
bigblue02hd
Landenberg, PA
Wow.. forgot to update this...haha!
Outside:
Inside: (generally looks like this, except the bench is cleaned off now. And, the fourwheeler and dirtbike aren't in the pic)
bigblue02hd
Landenberg, PA
Thanks...
1958 Farmall Cub Lo-boy
My dad and I have a few of them.... this one was my grandfathers and I still mow with occasionally.
