A Herringbone Parquet Floor, From Scratch
A_Pmech
IL
I alluded to a big project coming up a while back in my Do-All saw thread. I hoped to get started on it over the winter, but other things got in the way. Now that it's finally nice and warm out, I'm ready to begin the next phase.
This project actually began in March of 2006 when I picked up about 12,000lbs of freshly cut hardwood from a nearby supplier. Previous to this, I had been to multiple flooring stores and big-box stores looking for a suitable floor for the house. What I found didn't impress me. It was then that I decided to build my own floor.
Here's the wood in a rented truck. Most of the hardwood is Sugar Maple, although some is Walnut which will be used for the floor border and window trim throughout the house:
Once back home, it was stacked, stickered and end painted in the driveway to begin the drying process. It is important that the drying process proceed slowly by remaining outside, especially when the wood is near the fiber saturation point. The surface of the wood can give up moisture to the atmosphere faster than the core can transport moisture to the surface. Thus, if the wood is dried too quickly the outer case of the board shrinks over the saturated core. The result is a massive number of cracks parallel to the grain structure, called "case hardening" or "honeycombing".
Wood also loses moisture significantly faster from the end grain. This is to be expected, after all the end grain is how the tree transports water up the trunk and through it's branches. End splitting is the result. To minimize end splitting, the ends of each board are painted.
After spending approximately 9 months outside in the weather, covered only by a tarp, the wood had reached an equillibrium moisture content of about 20%. At that time, it was brought inside for final drying. Last fall I tested several pieces of wood, including this piece of Walnut and found them to be at equillibrium. About 7% moisture content is to be expected for wood in unconditioned interior locations:
That brings us to today.
Why build a floor instead of buying?
In a word: Quality.
For the past 9 years I have been building my first and probably last house. The house, when complete, will have a hybrid radiant floor heating system. As a consequence, the floor temperature will change dramatically between seasons as the heating is turned on and off. This leads not only to thermal expansion and contraction, but expansion and contraction due to changes in the moisture content of the floor. Due to the possibility of cracking and buckling as a consequence of thermal and moisture expansion, standard 3/4" T&G floors are not recommended for installation over radiant floors.
Instead, most radiant installations are covered in click-together "floating" floors. These floors are not anchored to the subfloor, but "float" on a layer of foam, thus alleviating differential expansion issues by removing restraints on the individual components (nails) and providing the floor with room to expand.
However, "floating" floors are not necessarily the be-all and end-all of hardwood floors. Having installed several expensive "floating" floors for others, these floors do not impress me from any standpoint. A well-built hardwood floor should "click" under a woman's heels, a floating floor sounds like loose linoleum by comparison. Further, a "floating" floor has obvious seams which collect dirt, loosen over time and just lack the beauty of a traditional hardwood floor. To a discerning eye, a "floating" floor is obviously mass-produced.
My solution is a hand-built floor, which will be thermally stable, yet look and feel like a traditional hardwood floor rather than a mass-produced wooden Lego project. I'll be making all of this in the garage and installing it as time allows.
More to come!
:beer:
IndyGarage
Indy
My house is a bit unique - I have an entire main floor that is done in herringbone Teak 12x12 floor tiles - looks a bit like a ballroom, but it's sure striking. I don't think they were made on site, but it wouldn't surprise me much to find out they were - the guy that built my house was from old school Europe and the whole house was done in European style..
Good luck with the floor.
v12man
Johannesburg, South Africa
Are you going to be using traditional pitch/tar to glue them to a cement floor, or a more modern adhesive?
What do you intend to use as a finish on the wood - Polyurethane or oiled/waxed?
My folks have a Rhodesian teak parquet floor - installed in 1941 (from second hand blocks recovered from an ocean liner being refitted as a troop ship in the local harbour), and still going strong - gets waxed and polished once a week or so, and never been resanded in 70 years - done using a block about 3 inches by 9 inches, and laid in squares of 3 at 90 degrees to the adjacent 3.
fatrhino
Rochester
How many sq. feet are you planning on? Are you going to mill the pieces yourself? I hope you have a nice shaper with a power feed, thats a lot of wood!
A
A_Pmech
IL
I was kinda expecting an aluminium diamond plate floor! :lol:
Looks good, looking forward to updates. :)
:lol_hitti
Nah, not my style. :)
Indy Garage said:
My house is a bit unique - I have an entire main floor that is done in herringbone Teak 12x12 floor tiles...
Sounds very pretty, Indy!
Thanks.
V12man,
Sounds like a really nice salvaged floor!
Modern adhesives will be used throughout on this project.
Haven't really decided on the finish yet.
Hi Fatrhino,
I'll be making about about 800 square feet of flooring and border. What's left of the Walnut will become kitchen cabinets and window trim.
This floor will be built from the rough by me.
I got the stock feeder out of storage today, actually!
and mounted:
z28snksknr said:
Looking forward to following your progress here!! I am curious to see how you will allow for it to be "thermally stable".
Largely by the magic of geometry. :thumbup:
mjozefow
Lafayette, IN
I await with anticipation John.
Let me know if you need to use the Walker-Turner. You know, in case you need a REAL bandsaw! ;)
A
A_Pmech
IL
The past couple of evenings I've been setting up the machinery. After making a few more adjustments, I ran the first setup pieces of flooring:
I like it!
:thumbup:
mjozefow
Lafayette, IN
I like it!
:thumbup:
Sweet! Maple is my second favorite wood to work with after walnut. I think it ranks tops in looks for domestic hardwoods. Especially if it has some curliness or other figuring to it. :drool:
What kind of saw? Powermatic?
A
A_Pmech
IL
Walnut and Maple are my favorite woods as well, especially when used in combination!
This was one of several Walnut and Maple cutting boards I made as Christmas presents one year:
The saw is a Delta "hybrid" saw. Basically a Unisaw, but with table-mounted trunnions instead of cabinet-mounted trunnions. The best thing about it is the Biesemeyer fence. I'm going to copy the fence design for the Do-All.
The "hybrid saw is lighter than a Unisaw, which was an advantage when I took it on the road rebuilding the interiors of Victorian and Craftsman houses before the housing crash.
Eventually, I hope to compliment it with a nice Oliver or Northfield slider. :bounce:
Burgerkong said:
I'd saw a Delta/Rockwell Unisaw.
Very close! :)
v7guy said:
looks real classy, I'm anxiously awaiting more posts!
Thanks!
Coming right up!
s_ontario said:
In a Hundred life times i would never have the temperment for such a task
wood bah
I find woodworking quite relaxing. That may be partly because I approach woodworking from a metalworking background.
NUTTSGT said:
Holy cow, that looks like a lot of hard work.
Once everything is set up, you just get into a rhythm. It's a lot of work, but if it's hard work you're doing something wrong! :)
Major Ramifications said:
One hell of a project. I really like the look of the sample pieces you put together.
I am kind of wondering where you have been living for the past nine years, though.
Thanks. I'm looking forward to getting to the actual "putting down the floor" part!
In a rotten, falling down old farmhouse that will bring me great pleasure to drive a bulldozer though.
:beer:
A
A_Pmech
IL
OK, so you're probably wondering how the floor pieces are made from the rough. Here it is, step-by-step:
Step 1
Roughing
Final drying. The rough lumber is brought inside and allowed to continue drying until it reaches equilibrium with the interior humidity.
At this point, the lumber has a moisture content of approximately 7%. The most important thing is that all the lumber have the same moisture content. Otherwise, the pieces will contract at different rates once they go into the air-conditioned house.
Step 2
Roughing
Each piece of rough lumber is cut down to lengths between 10" and 48" long. This is to remove large obvious defects and makes the following steps easier.
Step 3
Roughing
Each section of rough lumber is jointed on one edge.
Step 4
Roughing
With one flat reference surface provided by the jointer, the rough lumber is ripped down to approximate width. The stock feeder makes this job much easier by eliminating the possibility of kickback.
Step 5
Roughing
The faces of the ripped pieces are jointed flat and one edge jointed 90 degrees to the face.
Step 6
Roughing
The blanks are planed to rough thickness.
Step 7
Roughing
The blanks are stacked up until there's a sufficient amount to proceed with finishing.
Step 8
Finishing
The first step to finishing is to size the blanks to width. This is done in the shaper with a straight shaper cutter and a shop-made fence. The width between the arc of the shaper cutter and the fence will become the final width of the flooring.
The target dimension for this operation is a width of 2.250" +- .003" Even though this floor will be filled, I don't like messy loose floor joints.
Step 9
Finishing
Now that the blanks area uniform thickness and width, they're re-sawed .030" over final dimension on the Do-All.
Step 10
Finishing
The re-sawed strips are sent though the planer to arrive at their final thickness.
Step 11
Finishing
The final step is sawing the individual pieces to length on the table saw. Minor defects are removed so only the best wood from each strip is turned into finished flooring.
The Result
1,440 pieces, roughly 202 square feet before grading:
The Scrap
Scrap is made for various reasons, including knots, grain defects, chip out, outside the tolerance window, etc.
1440 pieces down, a whole bunch to go!
Burgerkong
Markham, Ontario, Canada
I've always done it this way:
1) Joint one face
2) Joint one edge
3) Thickness plane to approximate thickness
4) Rip to (approximate) width on table saw
5) Rejoint ripped edge
6) Cut to length
7) Shape/route pieces
8) Finish sand faces either in a drum sander or by hand.
But as long as it all works out. :thumbup:
red92s
A_Pmech,
You should check out the Sauer and Steiner website. This guy builds custom handmade planes and just recently put in a Herringbone Parquet Floor in his house.
http://sauerandsteiner.blogspot.com/2009_10_01_archive.html (starting)
http://sauerandsteiner.blogspot.com/2010_05_01_archive.html (finished)
He really does some amazing work!
WOW! Cool details!
The bits of Ebony and maple are Morse code. It says “Konrad Jill Riley Lucas” on the top line, and “Sauer 2009” on the second line. At least... I hope that is what it says. If there is someone out there that can read Morse code and if I have a typo... please don’t tell me.
A
A_Pmech
IL
1) Joint one face
2) Joint one edge
6) Cut to length
That's one way to do it, but there's less waste if you joint the face of the blanks after ripping. :thumbup:
I did forgot to include the second jointing operation in the step-by-step. I'll have to go back and edit when I take more photos!
thk2c said:
A_Pmech,
Great link! He does some excellent work.
I'm going to have to spend some time there reading his blog. :)
red92s said:
How much saw dust does that generate?
This operation has generated about a cubic yard of sawdust and chips so far. The roughing operation produces about 3x that many chips.
A
A_Pmech
IL
The first 1,600 pieces of flooring had an uplifting experience today:
red92s
You have cameras??
The cameras are the surprising thing to see someone have on their property in those photos?! Not the enormous yellow forklift?!
Guess I'm just a city-dweller, where home security is common and backyard forklifts are not.
brockstar
Cincinnati
Do the wood pieces need to re-acclimate once they've been cut and do they need to acclimate to the humidity in the house?
I've always wondered what would be involved with making a hardwood floor.
Now when can we expect to see a thread detailing the shingles for the cedar roof? :)
A
A_Pmech
IL
That is cheating! You need to struggle and swear like the rest of us!
My current temporary stairs are not very good, so I try to avoid making a bunch of trips up and down whenever possible. The little stack there weighed about 100+- lbs and I wasn't relishing the thought of making a number of trips so I hit the Easy Button. :)
arkangel06 said:
You have cameras??
Yes.
It's a handy thing to have around.
Hi Brockstar,
Wood is in constant motion as the relative humidity changes. Different species move at different rates.
It is important to make sure that all the materials used in the floor have reached equilibrium moisture content with the interior environment. Otherwise, there will be differential expansion or contraction as the floor acclimates.
No Cedar shingles are planned, but there's lots of other work to do. :thumbup:
ZRX61
Solar Blight Valley, SoCal
My parents had a parquet floor in their last home, they rescued it from a govt building that was being demolished. Think it was about 800sqft....1in thick oak :)
amt
Maybe I missed it, but what exactly are you doing different (than a regular nail/staple in, finished in place solid floor) to prevent the problems you referred to about radiant heat? I have heard of some doing a finish in place floating floor, where one would start with 2 layers of 3/8" 4' x 8' plywood, overlapping each other, so that your underlayment is now one giant floating floor. The finish wood is then stapled to that, and then finally sand and seal. This allows the floor (the finish wood and new underlayment) to move in response to temp/humidity, but still provides that nice acoustic response as a traditional floor. Downside is that you now added 1.5" to your floor and need to plan for that. However, I have never actually seen this in person.
Sounds like your floor will be fantastic. A few years ago I installed a 1000 ft of Ipe in my house, and I have a concrete slab floor. In order to have a solid wood work well with the slab, I had to use a very tedious method that included these layers: glue, vapor barrier, more glue, plywood, tapcon screws, even more glue, Ipe, and finally staples. It's been about 3 years now, and it's solid as a rock with no humidity & moisture problems. However, if I had to do it again, I probably wouldn't! Good luck on you installation.
Adam McLaughlin
Santa Rosa, CA
I can read morse, it does Say what you think it does.
When I was a kid I spent a lot of time at RCA KPH. Google it and you'll see what I am talking about...
Adam
beelsr
NE PA, USA
don't know if it was just for the pics or not but I really get the heebie-jeebies when I face joint wood with my hands directly on the wood. That's why god invented push blocks. I don't mind it when my hands are above the fence but for facing, I just cringe when I see it....
A
A_Pmech
IL
Half of my machines the government bought new. They never spare any expense. :bounce:
Hi AMT,
The techniques and materials I'm using aren't really new. However, to my knowledge they are rarely, if ever, combined in the way I will be using them. That's the new part. :)
The effort to control expansion and contraction is tackled on several fronts:
First, is the pattern of the floor itself. Wood expands at different rates depending on the grain orientation. By building a 45 degree herringbone, the expansion and contraction forces are spread evenly in two directions. A traditional strip floor expands and contracts in only one direction at twice the rate of a herringbone pattern. Thus, strip floors by their very geometry are more sensitive to changes in humidity.
Second, the floor will have no nails. As a consequence, the stresses in the floor will spread out across each piece evenly and cupping will be minimized by gluing the pieces with the radial grain facing up. Any tendency for the piece to cup will require the center to rise rather than the edges, which takes significantly higher forces.
Third, the floor will be glued to a high-quality Baltic Birch cabinet plywood rather than BC or Luan plywood or directly to the subfloor. The cabinet plywood is expensive, but makes a very stable base which will help to restrain the motion of the floor.
Dmaxman said:
How many hours invested to produce 200sq feet?
I have no idea. I try not to keep track of time on my fun projects.
Good catch!
That was a staged photo just to show roughly how it was done. Until last week I was working with S4S lumber I made last fall. I started working with rough lumber from the pile by the DoAll yesterday and had to find my push blocks. I'll probably update that photo along with adding a few others in the next day or two.
I use flat rubber-coated push blocks for facing the flooring pieces as it's much faster than worrying about where my fingers are. Edge jointing is done by hand however.
red baron
Cherry was always my favorite with Maple and Walnut right behind. Oak was always way down the list as it gets done so much. My least favorite was Pecan, it looked amazing, but it would splinter easily, even from sanding. Pain in the ***.
