CUSTOMMANCAVES.COM
I have a large HF 8" bench-mounted grinder/buffer combo (p/n 92425, no longer made...wimpy replacement pictured below). It has a 3/4" arbor. With the grinding wheel and buffing pad in place, the thing runs perfectly smooth...I can set my martini on top without spilling a drop.
However...when I remove the buffer wheel and install a wire wheel, all hell breaks loose. The thing vibrates like Katherine Hepburn's head in a helicopter.
So, question is, does anyone make a balanced wire wheel? I've seen some very expensive wire wheels at Grainger (some exceeding $400), but none of the descriptions indicate the wheel is balanced. I don't mind spending a few $$$ for a good wheel, but I'd like to know it's not going to shake/rattle/roll when installed.
