kngkong
Can I get some GJ advice on how to refinish my floor. I would be happy with a cement floor but am open to other ideas. I work on motorcycles and do a lot of metal work, welding, spill oil gas etc.
As you can see in the photos the outer garage where all the bikes are is the worst offender. I think the PO cut in a drain pipe into the slab, which is the diagonal patch you can see in the photo below. Then there are what looks like filled in expansion joints or just joints in the slab which form a cross in the center of the floor. Overall, I dont really see any settling or cracks which are getting worse. I would just like to visually clean things up and make cleaning up spills easier.
reverse angle
close up of joints in floor center
close up of aggregate
this is the back room in the garage where I have most of the machine tools. The floor here is in really good shape but would love to improve the finish and coat it with something so its easier to clean up oil spills etc. I would imagine this floor would be simple to use a self levelling plasticised cement to finish? Hardest part about doing this floor is moving out the bridgeport and lathe.
Do you think I could get away with a self levelling plasticised cement on the outer garage? (the worser of the two floors). The cement may need to be a 1/4 to 1/2 inch thick in some places to fill in the low spots. I could then paint or epoxy or tile over to finish. I have never done such a large cement project and doubt whether I can do a good job on this but I usual can pick things up pretty quick. If it turns out my cement finish isnt so good I could grind and paint or grind and epoxy or just lay tile over the top?
Though biggest question is what is the best way to build up and level off this uneven floor.
Once I get this floor done I can start moving my way up and start on the walls.
reverse angle
