This is a project that's been brewing in my head for a while and I figure it's about time to get started.
What is a radius attachment?
Have you ever wondered how to turn a perfect sphere with a lathe? Well, that's just one of the many things a radius attachment can do. There are many different designs of radius attachment but they're all designed to perform one particular function: Turn a sphere on a lathe.
However, a sphere is actually not a commonly needed object outside of the occasional machine knob. More common applications of the radius attachment might include making rolls for an English Wheel or a ring roller or blending two diameters together by cutting a radius on a shoulder.
Why make a radius attachment based on the Holdridge design?
In a word: Elegance. It is my opinion that the basic design of the Holdridge attachment is the most elegant and versatile radius attachment design. It is capable of turning near complete spheres to almost the throat depth of the swing frame. In addition, they can form concave and convex shapes of all kinds and also make concave spherical surfaces. While other attachments can do some or all of these things, it is the sheer range over which the attachment will operate that makes it most appealing.
History of the Holdridge design
Before I get into the construction details I'll start with a little history.
The original Holdridge radius attachment was invented by Warren B. Holdridge, who was granted US Patent #2,452,757 on Nov. 2, 1948. Mr. Holdridge claimed the basic design of a C-shaped radius cutting attachment for a lathe. Additionally, he claimed a novel method of clamping the swing frame to the handle shaft to transmit torque from the handle to the swing frame without backlash. The shape of the illustration in the patent suggests the attachment is milled from solid.
On June 3, 1969, Mr. Holdridge was granted a second US Patent, #3,447,245. In this patent a much more developed radius attachment is disclosed. This attachment is cast rather than machined. In this patent Mr. Holdridge claims a method of setting the cutting radius of the tool bit by use of a setting bar and depth micrometer. This allows accurate setting of the radius attachment rather than relying on the "try and measure" method most other attachments demand - a desirable feature!
Why not buy a Holdridge radius attachment and spend my free time watching TV?
1) A new Holdridge radius attachment to fit my lathe is over $2,500. I certainly hope to build mine for less.
2) Using the Holdridge radius attachment requires bolting it directly to the compound slide. My radius attachment will eliminate this requirement.
3) The Holdridge radius attachment uses a single set screw to secure the toolbit. This is prone to slipping due to cutting forces and makes accurately setting the tool difficult as it tends to move as the set screw is secured. My radius attachment will use a much improved tool securing method.
4) It's better than watching TV.
We had a Hodridge set-up at a shop I worked at in the beginnings of my trade career. It was a nice piece of equipment. Cheers
