Grease Gun Recommendations
Climb On!
So somehow I've managed this long without one. I need a gun for maintenance on my '70 Scout and '08 FJ. I'm drooling over the battery powered ones...one-handed pumping would be a luxury, though they're a little pricey.
Anyway, I'm interested in a solid, quality tool that's easy on the pocketbook as well.
Chuck
Wood County, WV, USA, NA
This. :bounce:
ElasDray
Idaho
I have a lincoln battery powered one at work and I have not one bad thing to say about it. It's been getting heavy daily use for four years now. It's the best "shop supplied tool" I have.
dodge610
North Canton Ohio
I know that craftsman isnt lookin very good on here anymore. But i just bought the pistol grip Craftsman professional one also pneumatic and this thing works like a champ do not know how i did without air power before this> All i had was the pistol grip and the pump style hand operated ones and yes still got them two of them were my dads. Keeping those because of sentimental value and because they are so old im guessin 30 to 50 years old.
Toolhorder
Montana
Nice, though might do more damage than good to the FJ.
I dunno the new FJ's are pretty tough. Mine may be bulletproof.:bowdown:
SO wierd this thread popped up because I need one too. I used a cheapo grease gun from O'reilly's and it leaks the grease out all over my cart. Same with the lincoln one I have too. I was asking SO dealer about it last week. I wanted to get a cordless one. He claims you can shoot a stream of grease across a shop with the cordless one. :D
Kurn
Ravenna, Oh
Lincoln 14.4 volt,hands down.Pricey,but the first time you use it,it's worth every penny.
Arne73
I know that craftsman isnt lookin very good on here anymore. But i just bought the pistol grip Craftsman ...
I've got a pistol grip Craftsman that is almost 40 years old AND I AM THE ORIGINAL OWNER :shocking: !
I replaced it with a Plewes because it seemed like every time I have used it for the past 4-5 years (not many fitting on newer cars :headscrat ) air is trapped in the pump section and I send too much time fiddling around getting it pumping again.
I'm keeping it for sentimental reason (part of my mobile lube operations when I was working my way through college).
Anyone have any tips on how to prevent air locks in a grease gun ? The vent is a simple screw that does work for SH!T .
aidank
Ireland
I have a mcnaught pistol grip
it never gets airlocked but is totally useless how could that be you may ask?
well when using grease tubes in it the spring isn't good enough to push the grease into the head of the machine, the plunger seems to get stuck in the tube
http://www.macnaught.com.au/persistent/catalogue_files/products/K32_Flexigun_IM.pdf
anyone got any solutions, and yes I do have the follower turned the correct way
C
Climb On!
Great help folks I think I'm going with the Lincoln and the PVC holder. What about recommended tips, hoses, and others?
airbatica
I've got the Lincoln Pistol grip... no issues to date. I could never get the HF lever action one to pump reliably, so into the trash it went. The stock hoses that come with the Lincolns are quite serviceable. If yours will see a lot of use, maybe get a couple of replacement tips for it. A 90 degree tip is probably handy to have as well.
justanengineer
Motor City
Years in the military and working on equipment around the farm taught me that over-greasing is a very common and very damaging problem. Stay away from the powered variety if you want the best life expectancy out of your joints.
That being said, my favorite grease guns are the pump variety that come in bundles of 3 or 5 for $1 at an auction.
fordbroncodave
same as snap on's without the name. piece for piece, size for size, weight for weight. its the same.
W650Mike
North Central Texas
The casters on my 3-point finish mower take a lot of grease so I went with a Lincoln pneumatic and it has served me well. I keep a lever gun for more sensitive fittings where blasting a bunch of grease may blow out a seal.
matthew
John Deere
I'll second that. We used 'em a lot at my grandfathers farm, and they were well made and fairly reasonably priced. Which isn't entirely surprising - farm equipment is one place where there's still lots of zerks to grease...
I've heard good things about Alamite, as well, but never used one.
johnsdeere850j
Oklahoma
how does it cause damage? On heavy equipment I see waaay more damage from undergreasing.
fflintstone
MOFnowhere Mi.
