0-10 dimmer suggestions
yeldogt
I'm getting closer to needing to order some for my new house.
For those in the lighting world ...anything new?
My house has a mix of fixtures and light types. All of the 1-10 controlled LEDs are made by BEGA and most are in the bathrooms. So, I need an easy to use dimmer.
I typically use Lutron and they have come down in price (nice) .... but, they don't seem to make the 0-10 in my favorite dimmer (Maestro). The only one they sell has an occupancy sensor that I don't need.
The Diva line has a big rocker and a small slide for the dimming ....
Y
yeldogt
Can't a line voltage dimmer be used on 10v?
No. 0-10v is the control. The fixtures have 120 going to them and two low volt wires for the control. They make romex now to do this.
The dimmer sends the LED driver a signal on what output to the LED.
pbon
I have 7 of those Eaton rocker/slide dimmers and they have been good so far — 2 or 3 years.
cybrdyke
USA
Eaton SF10P or DF10P work great. They have both the switch part and the dimmer part in one device. Makes it easy to run everything to one box.
Good luck,
CD
BIG-BRO
New Hampshire
I used the Eaton dimmer recommended here - nice rocker switch and slider dimmer in one unit. And available in colors (my garage electrical is in gray). I had to research a lot on what 18/2 wire to use. My first pass I used unshielded and ran it parallel to the 120VAC lines. Lights dimmed even without dimmer connected - AC lines must have “induced enough voltage” onto the dimmer wire. Re-ran it with shielded 18/2 and separated the run away from the 120VC. Works great now !
Y
yeldogt
The Eaton is a better price point .... $35 vs $75. I'm going to order a couple and see how they match up to the Lutron. I have many multi ganged situation and sometimes the color is off. My OCD will go nuts.
nadogail
Coronado, CA
I only buy Lutron dimmers.
There are others that maybe as good, but I got started with Lutron and have seen no need to try another brand.
cybrdyke
USA
I agree that Lutron makes great products, but they only make 3 wallbox dimmers that are 0-10V. One of those has a built-in sensor, and one is an ancient configuration that's now unpopular. That leaves only one, the DVSTV, that's a normal looking dimmer/switch. It works great.
Lutron also makes the best wireless system for controlling 0-10V lighting. What initially seems expensive really isn't when you consider the features and the ease of installation that it offers.
Here's their brochure on 0-10 products. https://www.lutron.com/TechnicalDocumentLibrary/3672532_0_10V_Solutions%20Brochure.pdf
cybrdyke
USA
Mesozoic
Tucson, AZ
I've got a couple of these 0-10V dimmers in my garage now. These parts also support Bluetooth and so I can control them with my phone and/or home automation server. They're essentially computer controlled, but look just like standard dimmers.
Y
yeldogt
Is that a slide to dim on the side?
