0-10V dimming wiring color confirmation
shaggyant
North Idaho
I’m hanging and wiring some new LED UFO lights with 0-10V dimming and motion sensor capability. I don’t care about motion sensors but I want to hook up the dimming. I am running 12-2 NM-B pcs duo wire with the dimmer wires bundled into the Romex. The wire colors on the NM-B are what I thought was standard pink and violet but the dimming on the lamps have pink, violet, and grey. Judging by the label I think I actually should be using violet and grey and leaving the pink alone. Do you guys agree?
Here’s the link to the lights if it helps: https://www.1000bulbs.com/product/2...c_lcid=t5798278641573888lw5679436258959360li0
Denwood
Thunder Bay, Ontario, Canada
0-10v standard control wiring color has changed. Depending on the manufacture date, grey has been replaced by pink.
I ran into this issue on a recent automation project with fan control via 0-10V. On that pic though, you have purple (violet) and grey..so yep, I’d use those. My guess is that the wire is new, so is using pink and violet as per the new standard.
