0 degree offset double box end wrenches
Cap'n
New Brunswick, Canada
Hi all,
Been looking for a quality set of these, and am not having any luck locally. I KNOW that Snap On and Mac make, or at least made, wrenches like this, but couldn't find anything on their websites. I found this set on ebay which is pretty much what I'm looking for, but I would like to know if anybody has any experience with this brand? I've never heard of it myself.
http://www.ebay.ca/itm/Metric-MM-Ex...132?pt=LH_DefaultDomain_0&hash=item3ccf66984c
For $100, they should be decent quality, but I wouldn't be opposed to forking out the extra quid for the more expensive brands if these are sub par. However, my problem is finding a set. Anyone know of where you can get them? I can find offset ones of various degrees till the cows come home. Not interested in those. I like these long, straight wrenches for a variety of reasons.
Any info would be appreciated. Unfortunately I do not have access to a Snap On truck to talk to the guy about them.
Thanks in advance
senor fozz
If you have access to Gearwrench I think you would be happier with the long 0* with ratcheting and box ends. If you are going to buy the style you linked to I would suggest the SO from personal experience as a long wrench can do a lot of damage to a fastener if broached wrong or snap itself in half.
C
Cap'n
Thanks. I have Gear Wrenches already...pretty much just looking for plain 12 point box ends. As for the SO...can't find any...this is kind of the issue. I would buy them if I could find them.
This is the nearest thing:
http://store.snapon.com/Standard-10...fset-12-Point-5-pcs-10-to-19-mm--P630676.aspx
I just want a set that isn't offset...unfortunately, can't find anything anywhere
Skin
Boston
You're having trouble finding them because Snap-On lists them under "High Performance/Spline" on their site instead of under the wrenches category where they should be. Sets are here
http://store.snapon.com/WRENCHES-FLANK-DRIVE-174--C629209.aspx
http://buy1.snapon.com/catalog/catalog2.asp?tool=all&Cat_ID=629007&Sub_Cat_ID=629209&store=canada (Canadian Site)
That said i'd second the recommendation for Gearwrench Gearbox wrenches. They're the same thing as what you're looking for except the other side is ratcheting. Snap-On also sells their own ratcheting/fixed ends as well in the above link. Obviously the Gearwrench versions are far cheaper. If the B1G1 package is still going you can get both Metric and Standard sets for ~$180.00. I find these versions immensely more handy in a real world setting.
http://www.gearwrench.com/gearwrenc...-double-box-ratcheting-wrench-set-metric.html
C
Cap'n
Try search on Snap On website for XDHFM1516 (or XDHFM1719 or whatever)
Nepros makes a wrench something like that but also pricey and my Nepros one is broached slightly offcenter.
XDHFM606 I believe is what you're looking for
Boom. Problem resolved. Funny, I couldn't find these by searching in the wrench section. Go figure.
Thanks a lot folks. 300 bucks is pricey, but IMO worth it. Nothing worse than wrecking fasteners, I live in rust country so it happens a lot.
amolaver
i've got those genius wrenches, and they are fantastic. the big advantage to them over the long double box gearwrenches is their much 'thinner' around the head; even vs the non-ratcheting end, the genius wrenches are much more compact. the genius also have a good design in how the beam of the wrench meets the head. look at the pics of them - the beam is basically flush with one side of the head, while the other side of the head gives you some knuckle clearance. depending on what you're working on, that can make a nice difference.
way cheaper on amazon too - http://www.amazon.com/dp/B002AIX502/?tag=atomicindus08-20
ahm
Wakefield
Arlington VA (but would like to get out to country
Is the Gearwrench set Taiwan or China? (China would be unacceptable to me)
btbsandman
Missouri
Hi all,
Thanks in advance
Those are genius tools. I have the same set. I like them.
neophyte
Pennsylvannia
Most European tool companies offer a non offset double ended ring style wrench, DIN 837. The wrenches aren't exactly the same but they would have a similar function.
The Facom wrench model number is 59.***
12pc. set.
http://www.ultimategarage.com/shop/part.php?cPath=35_61_734&products_id=4843
8pc. set.
http://www.ultimategarage.com/shop/part.php?cPath=35_61_734&products_id=4848
6pc. set
http://www.ultimategarage.com/shop/part.php?cPath=35_61_734&products_id=4888
Stahlwille offers the same style wrenches as model 21/**
http://www.amazon.com/dp/B00C139XNY/?tag=atomicindus08-20
http://www.stahlwille-online.de/ind...hid=&scmd=pdetail&pcid=1678&cid=2025&pid=2162
Elora offers them as model 120S ***
http://www.bloomertool.com/DIN-837-ISO-3318-Zero-Offset-Box-Wrench.html
It's a fairly standard European style wrench so pretty much every European manufacturer will offer them.
If you want the USA Snap-On style wrench, there's Snap-On, there's the Genius wrenches you linked to. I believe MAC may offers them as model BHFM or SBHFM for the sets, I'm not certain about the MAC wrenches since the MAC catalog doesn't have much of a description.
C
Cap'n
Wow, lots of replies, fast. I'm used to slower paced forums! Haha.
Anyways, lots of good information, thank you all. As for the gear wrenches, they look like a nice set, but I would rather have the two sizes in one wrench, personally. I was disappointed to see the SO set doesn't have the 13x15...those are two of the most common sizes on my personal vehicles (a '96 Chevy K2500, and a '94 GMC K2500). Probably building the set myself would make more sense, since you don't really save all that much in buying the entire set over buying the individual wrenches.
Skin
Boston
With anything Gearwrench these days expect Chinese though they do still seem to make plenty in Taiwan.
Snap-On Metric set of the same wrenches costs $600+ tax.
Gearwrench Metric and Standard set $170.00.
http://www.tooltopia.com/kd-tools-85988c.aspx
I like USA tools as much as anyone but that savings is too much to ignore. I suppose the Matco flex versions would fall in the middle-high side at $450. Those are made in Taiwan.
Skin
Boston
XDHFM1315. They make more styles than what they offer in their pre-packaged sets. You aren't saving a dime by getting a set so you could just piece your own together.
C
Cap'n
Yeah I was thinking about getting the 12x14, 13x15, 16x18 and 17x19. Total on the Canadian site comes to $262.40 +tax and shipping. Not bad really. As for the smaller sizes...meh. My regular wrenches are good enough.
To chime in on GearWrench...I've got a flex head set, and I'm really impressed with the quality for the price. I've used them to break free rusty bellhousing bolts without issue. However, they have a time and a place, and when I just want pure "umph", I usually grab something else when I can.
Thanks again everyone.
92integra
Those genius wrenchs look pretty awesome. why not grab them to try out before u spend a bunch on the Snap On ones?
nicksnothereman
In the Mojave
Some people seem to like genius tools. I have no opinion on them (never used them). Depends on the warranty with most off brands. Would I spend 100 bucks on them? Not a wrench guy so, no. They are long handle though. I'd just buy a couple of slugging wrenches for that much if I really needed them.
spacedoutbob
I was able to put a set of 6 together used off of Ebay for around $125.00. Good luck.
Bob
C
Cap'n
They do look good, I'm considering it. But I prefer to buy stuff once for the most part.
I hadn't heard of them before. I don't know if they're not normally available in Canada or what. I have 6 different sets of metric wrenches of different shapes and sizes...often times one design just doesn't cut it. I've used these long ones before and really liked them.
Another reason I want the ones with two sizes is to limit the number of tools I bring with me in a tight spot. I hate running back to the toolbox all the time, and also hate having piles of wrenches on fenderwells or wherever.
Bob
Darn. That's a steal!
rmsg0040
Toronto
Here's 2 mac wrenches 12x14 and 17x19, $50 USD to Canada:
http://www.ebay.com/itm/MAC-NEW-MET...42655801?pt=US_Hand_Tools&hash=item3a85309139
oldtools
I don't think you would be disappointed with the genius set, difference is the genius wrenches has sharp corners whereas SO had a rounded beam.
I think cornwell has the best double box wrench set, every wrench goes in order of size for the most part
http://www.cornwelltools.com/webcat...-Offset-Box-Wrench-Set,-12-Point,-8MM-to-22MM
I bought that Cornwell set used for $80 off of CL. It work fine, but I am not too impressed with the quality. The shank/beam is lumpy and the broaching is off center. SO quality is much better, but I think SO is shorter.
Danglerb
SoCal
One of my favorite wrenches is "like" what you are looking for, only I think much better.
Its various brands, EZred on trucks, SK even had them for awhile, double box end flex head ratcheting extended spline wrenches. Extended spline means they have the square teeth to grip any type of bolt head, and they stick out from the wrench like a zero degree offset.
mattygee
MA USA
+2 or 3 or whatever we're up to for endorsing the Genius wrench set pictured. I don't use them very often, but when you need one, you need one.
BearCuda
Martinsburg,WV
Examples of automotive situations needing them?
Just used my super long Matco spline ratcheting flex head 15mm with great effect today. Was trying to change alternator belt on a PT Cruiser. Keep in mind, nothing is easy to work on or get to on these cars. They're a serious pita, especially a timing belt or water pump. Well the upper alternator nut is super hard to get to about a foot below the top of the motor near the firewall. You can't really get a ratchet in there due to clearance of the timing cover and unibody frame. My long Matco wrench slid right down there and was able to ratchet that sucker loose. They're my new favorite wrenches.
At $443 for the ten piece set, they're probably the most expensive set you'll come across but they're awesome.
JTH
MO Ozarks
Best thing I've ever used them for is broken flex plate on Chevy 4X4. Pull the rear mount slide trans and transfer case back, slip in and R&R flywheel bolts. Flat rate money in my pocket!
