1/2" Chuck for CDR761
nickersonau
Has anyone installed a half inch chuck on the 14.4 Snap On drill?
I would like to purchase one but hate to be limited to 3/8 bits. I know it is not enough drill to put 9/16 holes in 1/2" steel or anything stupid like that. I have a 1/2 air drill for heavy-duty drilling, but sometimes drill large holes in plastics where a small cordless drill would be nice.
I can't find a parts diagram or list for the CDR761, but I would think you could remove the chuck and install a large keyless chuck from say the large air drill snap on offers.
Any thoughts? Anyone with both tools that could see if a swap is possible?
Thanks
Austin
6PTsocket
Thanks
Austin
I can generalize but like many generalities it is sometimes wrong. Most 3/8 chucks have a 3/8-24 spindle thread. 1/2" chucks are usually 1/2-20 thread. However, 1/2" chucks with 3/8-24 spindle thread are available, both keyed an keyless. I own both. The selection is not as good as 1/2 with 1/2-20 and getting a single sleeve might be hard. I am not sure what you need. I had an old, all metal, low RPM 3/8 monster Craftsman corded drill made by Singer, that I converted. It had more power than a lot of 1/2s that I have used. I found a keyed Jacobs for it. I have an old Porter Cable 14.4 that was 3/8 and after checking the parts lists of mine and the 1/2" model, I found that all motor, gear and related parts,were the same. In fact, the 1/2 had a 3/8-24 spindle from the factory. I put a Jacobs chuck on it that was **** and later put the OEM 1/2" on it, that was a little better. Your challenge is findind a decent 1/2" chuck with a 3/8-24 thread.
Wamsutta
Amarillo, Texas
You need to first find out what the thread size is of the original chuck.
Then go to the Jacobs website and pick out a chuck.
N
nickersonau
Thanks for the info guys. I think I will probably get one regardless, I just like to overthink things first.
plinker
Northern Wi
Nothing much to add except the screw for the chuck is likely left hand thread. The chuck should be right hand threaded.
