The drill chucks on the drills Monte linked to are all very good.
The keyless chuck on the Fein drill is a Rohm 141 Supra SK-E. I don't believe these chucks are cheap though.
http://us.roehm.biz/products/produc...d=7855&cHash=9279730dbe6f3fde935ca4229b225a2e
Rohm also manufactures a model 141 Supra SK chuck. The design is older, but there may be other advantages. Hilti sells these chucks on an adapter to convert their rotary hammers to accept regular drill bits.
http://us.roehm.biz/products/produc...d=7854&cHash=1f32817fdf08f70405c4ed4dcc8ca0ea
The drill chuck on the first Metabo drill is a Metabo Futuro Top chuck. These drill chucks are manufactured by Metabo. These chucks still aren't cheap, but they tend to be more affordable than the Rohm Supra chucks. The bodies on these like on the Rohm Supra chucks are machined out of a solid piece of steel which makes them durable, but also a bit heavy.
https://www.metabo.com/com/en/acces...roof/quick-action-keyless-chuck-futuro-top-r/
http://www.amazon.com/dp/B00069LBM6/?tag=atomicindus08-20
The drill chuck on the second Metabo drill is a Metabo Futuro Plus model chuck. These chucks like the Rohm Supra chucks, and the Metabo Futuro Top chucks use a ratcheting mechanism to hold the bit securely. The outer shell on the Futuro Plus chucks is also steel, but is formed plate instead of milled from a block like the previous Rohm and Metabo chucks. The advantage to the Futuro Plus chucks is they're lighter in weight which is better for a smaller lighter corded drill. They're also somewhat affordable.
https://www.metabo.com/com/en/acces...ck-action-keyless-chuck-futuro-plus-s2-m-r-l/
http://www.amazon.com/dp/B0002YYZ8C/?tag=atomicindus08-20
Rohm manufactures an almost identical chuck called the 104-61 Extra-RV.
http://us.roehm.biz/products/produc...d=8719&cHash=5f2b485e46ef9d9017854c8d57f18dd1
Its possible the Rohm Extra-RV and Metabo Futuro Plus chucks come of the same manufacturing line. I think Monte in a past thread mentioned that Metabo may be the OEM.
Bosch and other tool companies also offer the same chuck rebranded.
Milwaukee also sold a very good chuck that was used on some of their older drills. The chucks were all steel, with a heavy formed steel shell, and a ratcheting mechanism to securely hold the bit. The chucks were manufactured in Japan by Yukiwa. Unfortunately Yukiwa seems to have redesigned the chucks. The current Yukiwa chucks are the same ones used on a number of current Milwaukee drills and I've seen complaints about them.
