1/2 drive cordless impack
Kenskip1
Missouri
OK here is what I have read.Rigid, Ryobe and Craftsman impact wrenches are all made by the same manufacturer. Rigid has the best warranted but Craftsman has the best price. Now I own a perfectly good Dewalt 1/2 drive model 059. This thing is a boat anchor.It works fine but does not have a variable speed. Not to mention a light and it is just plane heavy. The Craftsman heavy duty has 300 lbs of torque, comes with a 2 amp Lithium Ion battery, that will fit my skill saw.Plus the Craftsman has variable speed.$159.at my local Sears.This is the tool charger and battery. How can I go wrong with this? Ken
CNGsaves
KS and OK
Heavy duty 1/2" C3 cordless Craftsman impact is REDUCED pricing for Black Friday at $139.99
Not sure if Sears is going to allow SYW points/money reduce these prices further.
General Geoff
Allentown, Pennsylvania
If you use it often enough that weight is a major factor, the Cman HD is listed at 5.25lbs with battery. Just a bit over half the weight of your Dewalt. If the Dewalt busts loose everything you need it to, then the Cman should be just fine as well.
928'er
Wine Country, CA
I have the older single speed Ryobi 260 impact (which is, essentially, the same as the older version C3). I use it for automotive work and like you mainly on lug nuts. It does just fine (of course I have alloy lug nuts, so I break them loose with a breaker bar and do final tightening with a torque wrench).
You're, mainly, buying into a battery system with any of these tools made by TTI. If you can use the battery with other tools you have, I'd stick with CM.
Get a 4 amp battery, however, - makes a BIG difference with these things....
Tsquare
San Diego
Get the CM and invest in the Big Battery option, you won't be disappointed .:thumbup:
