1/2 ton to 1 ton arbor press
gdpolk
I'm looking for a simple arbor press to do rivets, eyelets, and snaps in leather and kydex. Is there any major differences in quality between brands worth mentioning for my intended light use application?
My intentions were to simply use this to install sheath hardware primarily and occasionally use it to straighten the occasional knife blade after heat treat. For sheath hardware a 1/2 ton is more than adequate but to do the occasional knife blade straightening I think going up to a 1-ton option may be helpful and won't cost a significant more money. All things said, I'd want about 3.5-4" of throat and 2.5-3" of working height and could do anything I intend to use it for with that. It won't be used a lot or as a commercial machine. It also won't be subjected to heavy or abusive use or be left in poor weather. What I'd be most concerned with is that the base be flat, the ram be parallel to the base, and the ram not have a ton of deflection under load or runout due to loose tolerances. Below are the 4 that have caught my eye:
1) http://www.harborfreight.com/1-2-half-ton-arbor-press-3551.html
This is dirt cheap and likely adequate for sheath work as a hobbyist. I don't need anything more for sheaths, however it might be light on pressure for straightening thicker blades and as with all HF items quality may be a moot shot. Several manufacturers seem to share the same casted frame and design with different paint jobs and paper labels. It's likely the same as several other "brands" I've seen online.
2) http://www.harborfreight.com/1-ton-arbor-press-3552.html
This is the next size up and still affordable but still has questionable quality.
3) https://www.amazon.com/exec/obidos/ASIN/B00068U7QS/ezarborpresses-20
Only slightly more cash than the larger HF press, but likely better quality and rated to the same 2000lb pressure standards. This is one of the only ones I've seen with specific specifications for deflection and squareness listed. If the 0.002" can be believed it'll be more than tight enough tolerances for my needs.
4) https://www.amazon.com/exec/obidos/ASIN/B00068U7WM/ezarborpresses-20
I've never used one with a wheel feature. The wheel may be nice to ease down on some of the small and fragile eyelets or may be a completely unnecessary feature. Also, amazon lists this as having less force than the smaller unit. This could be a typo, I don't know. Either way it would likely have plenty of power for my needs and maybe the extra throat and height would be handy but not needed. Maybe the wheel would be handy.
LXCam
Not for your needs. I have a 1/2 ton dayton that works just fine for lite duty work
ttpete
Dearborn, MI
If you're doing tarps and covers, look for a dedicated press that has interchangeable dies for different types of fasteners. I had one but sold it.
tool_scrounge
Southern California
Schmidt is the best, but it may not have enough throat for you needs and the price is up there, even used on ebay.
http://www.schmidtpresses.com/products/presses/index.htm
Janesville is nice quality but not at the Schmitt price point. Larger throat though. I bought a used ILP-500 and have been happy with it.
https://www.janesvilletool.com
Otherwise find a nice used US made arbor press (Dake, Famco, Greenard, Pipan etc). Not as precise as the above but probably fine for your use. I find all the imports I have used are much lower quality.
1982fxr
Phoenix
I have a Janesville press. Got tool drunk!
Milton Shaw
I use a handheld unit to do eyelets and snaps. I would think it would be a lot easier to do with a handheld unit instead of trying to move everything to a press to do it on a bench. Mine is labeled "Press n Snap" and has several different sizes of snaps/grommets that it will work with. These are what places use to do boat covers, truck covers etc. I have even used it to repair jeans and jackets.
Milton Shaw
I use a portable hand held tool to do snaps and grommets. Amazon lists the one I have although I bought it before Amazon was around. Search for" Press and snap" and the Hoover press and snap was the first one that came up, it looks identical to mine and has worked great. These are what are used to make boat and truck covers. I have even used mine to repair jeans and jackets that snap. They have dies that come in different sizes for different style buttons and snaps. They also list a lot of different styles that resemble an arbor press. Look at the various styles and read reviews and see what meets your needs.
G
gdpolk
up with a little more info based off my needs and intended use
