oldschoolcraft
I know GJ is all about maximizing the number of tools you have. But I've been thinking about a portable "do alot" toolkit lately and came across the idea that it's not really necessary to have 3/8" sockets to cover all sizes and you can do it with 1/4 and 1/2.
The obvious downside to skipping 3/8 and going up to 1/2 is that the socket wrench size is usually much bigger so you'll run into clearance issues on some tighter confined areas.
So I did some reading of old posts and found an old Snap On wrench, long discontinued, that is 1/2" head in a 3/8" body. So I'm wondering, could the following be a do most things tool set, with the fewest number of sockets and wrenches:
Semi-Deep 1/4 and 1/2 set in metric and standard
Flex Adapter in 1/4 and 1/2
1/4" standard size ratchet
1/4" long flex ratchet
1/2" in 3/8" body ratchet
1/2" breaker bar in 18" length
I'm not saying you'll enjoy using these tools versus the proper 3/8 and also shallow/deep, but I wonder if you could finagle those 4 ratchets (3 plus a breaker bar) to do almost any socket-based job when you're away from your garage and main tool cart?
