1/4" automotive torque
rick carpenter
Huntsville, East Texas
How much torque do I typically need for 1/4" automotive applications? If I need more than the 30-40 ft/lbs ratchet wrenches deliver, I'll stick with the impact driver I have and use adapter extensions. The design of ratchet wrenches is better for tight quarters tho.
CGarage
United States/Switzerland
It’s rare to need an impact driver that is 1/4” unless you are removing corroded fasteners in something like an exhaust system.....and you live in an area where road salt is used. I’d stick to a low tooth count ratchet or get a long ratchet that is 1/4”.
And before I would use a ratchet, invest in a breaker bar. I use a 1/4” drive breaker bar from time to time. All are better choices than an impact and you should use less tool than you need to start- *always*
2ndGearRubber
Pittsburgh
Typical torque values are 60-140 in/lb, so like 13 ft/lbs. In context, that's about the average spark plug torque, and a little less than a drain plug. For instance on a modern GM "LS" style V8, drain plug torque is 18ft/lb, spark plugs are 13 IIRC.
What it takes to remove, is an entirely different story. My m12 fuel ratchet is reliable for basically all m6 fasteners, and a good percentage of m8 that aren't rotted or corroded. The M12 fuel impact driver loses to m6 fasteners from time to time.
Badgerstate
Columbus, OH
Id say it really depends upon the bolt and the application. I cant imagine needing to use an impact for anything that falls in the 1/4" range. I mean, Ive got a 3/8 impact and sometimes I think its quite silly for the drive size but its nice to have when you need it and when the 1/2 is either way too much power or simply too big to fit.
