1/4 breaker bar
Do you use a 1/4 drive breaker bar
  • I use mine a lot
    Votes: 48 11.0%
  • No need for one
    Votes: 145 33.3%
  • Tool box filler
    Votes: 78 17.9%
  • Limited use
    Votes: 164 37.7%
  • Total voters
    435
plinker
Northern Wi
I've seen a few threads on these now and again debating about the need for them, from not needed at all, to filling a space, to actually being used.
I actually use the one I have (old unmarked S-K) as a 90* offset wrench when space is tight, kinda like a offset box wrench. I use all my breaker bars for this type of thing as well, I also prefer them over a combo wrench to "back up" a ratchet/impact.
So if you have one, do you use it? If so how?
beerdog
Buffalo Grove, IL
I rarely use mine but I can't resist buying them for a few bucks at the flea market of estate sales. I mean, how many times do you come accros a small bolt that is so tite you need a breaker bar. I guess you limit the risk of breaking a 1/4 ratchet if you use them.
lilredex
Toronto
My long time companion....that bar goes through the handle to make a "T" wrench. Have used it ocasionally.
toolmutt
Texas
I've never used one. I filled it's position in the blowmolded case with a locking extension.
rlitman
Long Island
I have that exact SK 1/4" breaker bar. Got it at the flea market for $1, because it was so darned cute. Had to have it, but I've never used it.
My SnapOn breaker bar came with the set. Never used it either.
My 3/8" breaker bar really only gets used when nothing else will fit. If I can't break it with a 3/8" ratchet, I'll just step up to 1/2".
My 1/2" breaker bar doesn't get used much either. The impact wrench does all the work with so much less effort.
In all three sizes, I use my slide T handle bar frequently with an extension. They spin nicely in the hand. I really like my speeder handles if I have the room, and I just want something hand tight. Breaker bars, not so much, but that's probably just me.
shoturtle
Frankfurt AM
Not worth the space in the tool box imho. Some like it as a filler though. Never ever needed a 1/4 breaker bar working on my motorcycles. with 10mm and smaller fastener.
transittech
I have one, but have never used it, (bought it cheap), so personally I don't understand the need for one, especially with long handle ratchets.
A t-handle is different in my book, they're great for tapping.
KinzeMech
handy for backing up an impact when a wrench won't reach.
makes me cringe when I see guys backing up an impact with a ratchet...Also makes me not lend them my ratchets...
Useless for instances when you need more torque than a ratchet...I don't think there's much difference in the break points of a ratchet or a breaker bar in 1/4"
shoturtle
Frankfurt AM
anything smaller the 10mm, even impact is not the hard to break with a box head, or a standard ratchet. Only abover 10mm, impact stuff gets tough, but I would use a 3/8 or 1/2 breaker with a step down.
pfbz
Have an SO 1/4" breaker, but I rarely use it.
Most of my work is on motorcycles. Lots of M6, M8 bolts and other smaller fasteners with torque specs just beyond hand tight. By far my go-to drive combination is this:
  • Snap-On T72 ratchet.
  • Snap-On SGT4 handle/extension.
  • Snap-On 1/4" drive 6pt deep socket.
I use the handle/extension without the ratchet for fast install and remove, and pop on the ratchet to break a bolt loose or put a final torque on a bolt.
If I didn't have this combo, I might use the breaker bar more as it can be flipped up to quickly spin a socket, and down to put torque on the fastener. Not as convenient as the handled extension, but better than spinning the socket with your fingers.
My go-to 1/4" combo, along side my rarely used Snap-On 1/4" breaker bar.
Unfortunately, I think SO has stopped making this version of the SGT4 and the latest versions may not have the 1/4" female on the top of the driver?
P
plinker
Northern Wi
I use the spinner handle & ratchet combination quite a bit as well. I never really liked them at first but then bought a Craftsman version with the drive square in the end.
I use it most of the time now.
maddawg308
Front Royal, VA
I don't have a use for things that small. My 3/8" and 1/2" ratchets and breaker bars get all the use. In fact, sometimes I wish I had bigger tools. The little stuff stays in the box. Everything small enough to need a 1/4 inch ratchet or breaker bar, for me, I end up using a nutdriver for.
RangerDaleXp
Commiefornia
I bought one at a swap-meet a long time ago and really never used it. It was more a novelty then anything else.....
mercman86
Chicago area, Illinois
My dad's craftsman set that he bought in 1980 came with one. I havent seen any sets lately that still include them. Still shines like brand new. Ive only used it a couple times when I couldn't find the 1/4" ratchet!
Jim85IROC
Some have mentioned that they use their 1/4" breaker in a method similar to a roto ratchet. Once you break it free, you use it like a nut driver to spin the fastener off. I like the idea, since that's what I use my flex head ratchet for.
bart1
Alabama the Beautiful
I have a new Wright contour grip. Cute lil thing, don't know if I've used it. I bought it because I thought I might need the angle feature and can turn it straight like a screwdriver. Also of note, and surprising to me, my 1/4" ratchets are thinner at te head.
richfinn
Leeds, Yorkshire, England
I would rather slip a cheater pipe over a cheap disposable breaker bar than a nice 1/4 drive ratchet any day.
I use 1/4 drive stuff more than 3/8 nowadays, Euro cars are getting very cramped for space.
First, I use my 1/4" sockets a fair amount because I do not have any nut drivers (they take up too much space in my toolbox). 1/4" sockets are perfect for working on home appliances and small engine. Most of the time I use them with a spinner/screwdriver handle like this
00943393000-1
except mine is the old clear and blue and has a 1/4" female socket in the handle (like the Snap On one in the other picture)[/I
I do NOT have a 1/4" ratchet, so when I can not get enough torque out of the handle, O break out the breaker bar.
I am putting together an extra 1/4" set from spares/leftovers. I was very happy I had a breaker bar to add in to that set.
Jason280
I have a couple of the Craftsman versions, and I don't think I've used them more than a couple of times.
rlitman
Long Island
If you're driving hex head screws and bolts, 1/4" sockets on a handle are just fine.
Nut drivers shine, when driving nuts. The act like a super deep socket, with their hollow handle, so you can run a nut down a threaded stud, long after a socket wouldn't be able to reach the nut any more.
RedFordTruck
I Have a Craftsman USA made 1/4'' drive breaker bar. Only got it cause it was $6.99 and seemed neat.
Like others have said I really only use it to take the torque off a nut then I flip it straight and use it like a nutdriver.
Kinda nifty and for $7 it has its uses.
firebox40dash5
does anybody have a model number for the SK 1/4 breaker bar. I searched and couldnt find anything.
40952
8" ratchet for me, I've got a 1/4" bar, but I don't think I've used it. Usually break stuff loose with the 8", switch to the flex head if I want to speeder-bar it out... just my preference though. I might switch if I could find an 8-10" 1/4" breaker bar.
ken w.
Western New York
I use my 1/4" drive stuff more now than anything else.I have a few 1/4" breakers bars,but tend not to use them.If the ratchet won't break it free,I will use the 3/8" drive if it will fit. I keep the 1/4" breaker bar in the tool box I keep in the car.
Gareth68
Missouri....West of Mexico
I've never had one, but I used to have one of the early craftsman 3/8 breaker bars with the hole in the handle like the 1/4 one shown in this thread.
I used to use it all the time. Of course, my choices back then were the good breaker bar, or ****** craftsman ratchet.
I would break the nut free, straighten the bar and slip a phillips screwdriver through the hole to use as a t handle.
