Tatsuya
Does anyone actually use these?
I use it too, when clearance is an issue.
Don't use mine for busting fasteners loose though. Maybe I should because I do warranty quite a few 1/4" ratchet
I've used it as a nut driver. Break the bolt, then flip it straight and turn it like a screwdriver.
Scout Driver;1603045 I have found a 1/4" breaker bar is handy for small engine work too. If women are hanging out in the garage said:Scott - you read me like a book. +1.![]()
I've also used it with a screwdriver bit socket when working with wood.
Has anyone come across a 1/4" breaker with a handle longer than 6 inches?
I've got a couple of fasteners that need to be held in place while turning the other side with a ratchet and the long 3/8 ones won't fit, even with a shallow socket.
