BikeRider
I have a decent selection of 1/4", 3/8" & 1/2" socket sets in shallow & deep, impact & non-impact, 6 & 12 pt, just not in every single combination. I also have both a 1/2" & 3/8" impact wrench, with both shallow and deep impact socket sets for each.
I don't have a 1/4" impact wrench, per se, but I do have the M12 Fuel Gen 2 impact driver, which with a short square anvil adapter turns into a 1/4" impact wrench, which is handy to have as a second impact (I rarely break out the 1/2" impact as it's heavy and bulky) so I don't have to keep swapping sockets on the 3/8" one.
What I'm wondering is whether at this size and level of impact power I really need a 1/4" impact socket set or can make do with a non-impact set and not risk the typical hazards of using non-impact sockets on an impact wrench. I'd mainly use it with 8mm & 10mm fasteners and maybe the occasional 12mm & 14mm, all torqued to no higher than say 30 ft-lb.
The obvious alternative setup of course would be to put a 3/8" square anvil adapter on the impact driver and just use my 3/8" impact sockets, but 1/4" sockets are a bit smaller which along with the shorter 1/4" square anvil adapter gets me into tighter spots better so it's the preferred setup.
Do folks here use such a setup, or have an actual 1/4" impact wrench and if so what kinds of sockets do you use with either, impact or non-impact? 1/4" impact socket sets exist but they're not nearly as common as 3/8" & 1/2" ones and seem a bit pricey for light occasional use. HF doesn't even carry one in any of its lines, nor Tekton.
