edl
do you use one frequently?
if yes, ratchet style or pistol style?
good brand?
thanks!! ED
good brand?
thanks!! ED
I went with a 1/4" air ratchet since the biggest 1/4" socket I have is 13mm but actually 1/4" for me is just used for various 10mm bolts not torqued high at all,
I think a 1/4" impact gun would be novelty for most unless you deal with these small bolts that have corrosion.. Or maybe if you build alot of wood work which require driving alot of small 1/4" lag bolts the impact action might be useful.
For the other stuff valve cover and bumper cover I just zip it off with a 1/4" air ratchet it's easier to handle then a gun. A gun will also require 1/4" version impact sockets as well which is added expense.
For me, i'd go with an Ingersoll-rand Straight/Palm 3/8" impact and 3/8" compact ratchet. you can always put a step-down adapter on them, and they're hardly any bigger than the 1/4", in most cases the 1/4" and 3/8" impacts share the same bodies and only the anvils are different.
