1/4 inch sockets...
rick carpenter
Huntsville, East Texas
I have a decent set of 3/8 inch sockets. For working on my car I am getting 1/2 inch sockets as I need them but I need a set of small 1/4 inch metric sockets. If I only wanted one set, would std length or deep sockets be better all around?
d.mcfarland
Western PA
In the past, the general consensus around here was that 1/4 drive deep sockets are rarely needed. I have both lengths just because they came in sets.
sk farmer
nd
standard first, then deep, then mid.:lol:
if they were not so hard to come by i might recommend mid before deep.
i have all three in metric and just standard and deep in sae. i use the mid more than the deep and almost as much as the standard depth if that makes sense.
Mister Laugh
I may be the odd duck here, but I can't remember the last time I used my standard length 1/4" drives, just my deeps.
MattPersman
Indiana
I use deep and standard you run across lots of valve cover bolts that have a stud type thread going up for wire harness securing
cburnscrx
Indianapolis
I've got both, and I use both. I was a little surprised how often I used the deep sockets around the house. Who knew?
Applesauce
Canada, eh
I only use my metric deeps, because I find them easier to hold onto (i.e., holding both the socket and ratchet). In fact, I glued cut-off metric allen wrenches in all my shallows, and these are among my favourite tools.
bonneyman
Desert SW
In 1/4" drive, I have both. In my line of work I always seem to need both. Alot of times, though, I can use either, and I usually switch off between them so to even out the wear.
I also find 6 point to be more useful in 1/4" than 12 point. JMHO.
03protege
Louisiana
Probably use the deeps more than standard, but when you need the standard you really need it.
You can both from craftsman so cheap it's a no brainer.
Gmonkee
I found that moving from heavy machinery to auto work I was breaking bolts off with 3/8" stuff. The 1/4" set I changed to was all standard short sockets and a low profile ratchet became my go-to set for those 6mm metric bolts in everything. Prevented a lot of damaged bolts over time.
Just recently I have started accumulating a deep 1/4 set of SAE and metrics but have not used them yet. Now back to working on yellow tractors there is little call for 1/4" in general. I keep them around for the occasional auto related use all the same.
FiveFinger
I use my deeps unless there is a clearance issue. I use the extra length to grip with my fingers to spin the nut off after it is free enough or hold the socket while to prevent the ratchet's drag from rotating the socket.
wise
Ontario. In Canada.
I use both, I use shorts more though. Most of the time either will do the job I think, but there are times only one will do.
blacK20
I always reach for my deep sockets first no matter what. Unless the situation calls for a short socket.
I haven't needed a deep 1/4" drive socket in the 45 years I have been acquiring tools !
wannab20hatch
Gainesville, Ga
I use my deeps way more than standard. They seem to just collect dust. I bought my matco sets on ebay super cheap and practically new.
My next set to buy is 1/4 deep magnetic
dirtydogintex
inner looper-3rd Div Houston w & n
likewise on breaking bolts w/ 3/8" stuff
my 1/4"drv 'go-to' stuff is a set of CM 6pt deeps w/a CM low profile & Mac mr5f flex ratchet
+1, +2.... +however many
very rarely do I run into clearance issues
knurled deeps would be cool - anyone make 'em?
amlv20
CEN-CAL
I use deep 1/4 always, I have a few magnetic deep sockets.i want the whole set.but shallow magnetic sockets **** as they don't go over the entire head and can strip a bolt.
neonnblack
Reno, NV
If you do alot of interior stuff, deep sockets are nice. Lots of studs on headlights/tailights need it, but not the force of a 3/8. lots of interior bolts that are set in, etc.
Fedwrench
Valley of the sun
Who the hell on this board only wants one set of anything?:wtf::lol:
Seriously though, if you're only working on your car then, just buy what you need for your car. Take a late model GM car for example, you'd use 7, 8, 10, and 13mm alot. 5.5mm once in awhile. You could tailor a set just of needed sizes on the cheap.
However, this is the Garage Journal so, you'll need shallow, semi deep, and deep sockets in chrome and impact versions along with swivel sockets too. :lol: and don't forget an assortment of extensions in locking, wobble, and regular versions. I'll leave the various types, lengths, and handle type ratchets to your own descretion. :beer:
pendragon1998
NE Georgia
Heck, if you buy a handful of sockets individually, you'll end up paying about as much as you would for a set. This craftsman set has the a nice array of socket sizes that are the same as the 1/4 module includes, minus the ratchet and extensions. The module is apparently mostly made in China. I don't know if the set I linked is still USA, but I suspect it may be. Maybe someone can chime in?
kc-steve
Kansas City
Since I do a lot of household electronic repairs I tend to use the standard height a lot, and thinking about getting deep sockets.
But recently I ran across the pass-thru sockets from Armstrong (closeouts) and thought what great idea, especially for those situations where a nut is locked down on a long screw found typically in some electronics applications.
I haven't posted the set on my website yet. It is just SAE also. But message me if you want to buy a set. Includes pass-thru ratchet, 6" ext, 2" ext., a 1/4" adapter, and 9 sockets. See attached photos.
Steve
atwageman
NC
I've got standard, deep, and semi-deep in 1/4 drive. I have standard and deep sets in both 6pt and 12pt.
