1/4" Torque Wrench help please
furbyj1
Miami, FL
Hello to my fellow brethren of the tool and shop realm,
Heed these words, for a fellow brother needs your assistance.
Alright everyone, here's the situation. I purchased a 1/4" torque wrench on eBay. After receiving it I realized the ratcheting mechanism in the head needs to be replaced. I was wondering if anyone could help me locate the repair kit or any repair kit that will fit for this torque wrench.
RichWolfson
New Jersey
Are you sure the mechanism is bad or not just dirty? Have you opened it? Torque wrenches don't get much ratcheting use so I would drop the internals in an Ultrasonic cleaner and then lubricate with Super Lube before I tried to find the parts.
///Rich
Zewnten
Pretty sure you're out of luck if you need parts, sorry. Might find a donor on eBay.
jayemm
up high down low
Looks like the head on my SK torque wrench. Which is the same JS Technologies torque wrench made for the KD, ATD, Craftsman and other (probably including this one)brands.
F
furbyj1
Miami, FL
All right, so i opened the head and seem to have found the problem during re-assembly.
cleaned up all the parts and re-assembled only to find the exact same problem from before, head/anvil just free spins, and there is also a decent amount of play.
I have taken more pics, the last pic shows that the pawl is not making contact with the teeth on the ratchet head, maybe a 1mm gap. Am i possibly missing a part?
DemoFly
Port Orchard, WA
That is one of the simplest and strongest ratchet designs. That's a block and pawl. Some call them a wedge pawl. Some call them a heartspring ratchet. The pawl spring bent or something. Just adjust it so the pawl wedges between the housing and the anvil block. Don't overtighten the bolt or it won't ratchet.
The play is inherent to the design. It's literally just wedging a block between two pieces of metal.
F
furbyj1
Miami, FL
I did exactly what you said, made a minor bend adjustment to that spring so it wedges a little more, and I am very happy to report that she is functioning beautifully!!!! Clicks so smooth now!!
I can’t thank you guys enough! I’m super happy with this purchase. I picked this up on eBay for $56 shipped. I dont know if thats a good deal or not for a 1/4” torque wrench but i love this thing!
