1.5 story garage insulation - advice for ceiling
MN GOLD
I have a 1.5 story (detached, unheated) garage located in climate zone 6. The previous owner designed the garage to have the second level loft space as a usable workshop area and I have been using it as such but the Minnesota climate limits this use to maybe a few months out of the year. After taking down a wall of damaged sheetrock on the main level and finding some poorly installed batt insulation (R-11), I decided to put together a game plan for improving the overall insulation of the entire garage starting from the top.
I can't decide the best approach for insulating the loft space ceiling. The pictures will show that I could insulate between the ceiling joists (24" OC), but as it stands now there is only 7' height. I think finishing off the ceiling would make it feel even more cramped up there. I would prefer to keep the ceiling open and insulate between the rafters but I am not sure how to approach that with 1) the rafters are only 2x4, and 2) it is a gambrel roof so dealing with 2 slopes.
This will be a DIY project and unfortunately spray foam is NOT in the budget. I really appreciate any insight and suggestions that can be shared. Along with current pictures I have also included to original plans to help answer any questions about the construction.
duneslider
Riverton, Utah
Cut and cobble rigid foam will be your best bang for the buck. It is a lot of work but is totally a diy option. Cut the pieces to fit in tight and seal all joints with foam in a can, and/or caulk. Obviously, the thicker you can go the better it will insulate. But the reality is, if you aren't going to try and condition the space it will eventually just drop to a low temp no matter how much insulation it has.
