1.5 to 2 HP motor
micromind
Fernley, Nevada, about 30 miles east of Reno.
With all the motors I've worked with over the years, I've never seen that. True enough though, most of them were 3Ø and some were 2,000HP or so.
Note also that then low voltage current is not twice the high voltage and the service factor is different at the 2 voltages. Also, the KVA code (starting current ) is different.
Stuart in MN
Minneapolis
I don't think that's saying different HP at different voltages, otherwise it would have a slash between the numbers instead of a dash.
D
dave*99
Coastal NJ
Nope. It's a special motor used on the Delta Contractors Saw years ago. See post #3. It really did run at higher HP on the higher voltage.
