1" auger flighting
jpitzh32
first post been reading for awhile looking for some 1" auger flighting for a kids project anyone know where to get any or any old machines to rob it from
Thanks
zkling
Would you elaborate a bit more on the dimensions and what you are wanting to do? Most of them flighted screws/augers I've seen are fully welded and would be a royal pain to salvage without much work. Do you have specs on thickness, desired helix?
J
jpitzh32
would like the flighting to fit in a 1" id tube, 1/4" diameter center shaft, will be used in a farm display to auger "corn" . I have seen what I'm looking for in a farm toy but been trying for a long time to get ahold of guy who made them but no luck, would like to have 18" long pieces
rkevins
Central Arkansas
where do you live? if there are poultry farms in your area check with equipment supply houses. The smallest flight auger I can think of is larger than you are looking for it is flex auger but you could add a center shaft.
joe49
Tonica, Il
Thanks
You making a Archimedes screw model? Might use a ship auger bit.
http://www.techtoolsupply.com/ProductDetails.asp?ProductCode=SA1.00018&source=googleps&gdffi=a2fd11e1880844dfbe0b89871fd6ef5c&gdfms=D7470DA6948E4553811D55C05904F59F&gclid=Cj0KEQiA4o3DBRCJsZqh8vWqt_8BEiQA2Fw0eXfK4MqUq3MQmbhSk-yC_zdUDQ310j94ixDa2fb7HskaAucp8P8HAQ
EdT
North Georgia
Since this is just for demonstration purposes, you might be able to take a dowel, say 5/8" dia., and wrap some i/8" diameter vinyl insulated wire around it and glue it in place with super glue. It's not the same a true flight, but it might demonstrate the idea. You would have to pay attention to the size of the "corn" you transfer with it. Too big and it'll jam. If some slips backwards, it's OK. It's just a demo. Piece of acme threaded rod might work too.
Milton Shaw
Electrician's auger bit comes in size you could use. Available at HD or Lowes or Amazon for not much money.
larry_g
oregon
How big are the augers in some of the pellet stoves or BBQ's ?
lg
no neat sig line
