1 correct size heater, or 2 half sized?
davewest
Southeast Idaho
There seems to be an initial savings if I were to buy 2 half sized electric heaters as opposed to a single, correctly sized unit. Any disadvantages to doing that?
I need 40-50 btu to heat my space if that matters. This will be all electric, no gas at this time. Any opinions are appreciated.
matt_i
You should get better distribution with 2 heaters. I would think slightly higher electrical cost due to 2 breakers and up to double the wire albeit smaller gauge. More labor obviously installing electrical runs although your personal labor might be like mine: cheap :D
One concern I'd have is how to control them both...two thermostats? (Perhaps internally regulated with temp switch).
astroracer
Mid_Michigan
check the electrical usage also. Double heaters will mean double the amps used. If your shop can handle it fine. A bigger single can be more efficient though. A small fan or two can help with hot and cold zones.
Mark
It depends a lot on the size of the area AND how important it is to get the entire area UNIFORMLY heated.
ForceFed70
BC, Canada
If you need 40-50k BTU, I'm going to assume your garage is fairly large.
I'd go with 2 heaters. Better heat distribution, redundancy in case 1 fairls, and the flexibility to use just 1 of the 2 if you ever needed it. Also, while someone mentioned electrical wiring costs, It might turn out to be cheaper. 20A 240V circuits are cheap, 30A not too bad, but anything more gets expensive in a hurry. Plus, you never know when you may want to "borrow" the heater circuit to run a welder or whatever.
couch67
Ontario Canada
I have 3 small heaters in the garage, all under windows. They are all run from one circuit and controlled by a single T-stat on the interior wall. No hot / cold spots.
couch
