1" Drop in Anchors?
600SL
Connecticut
Anyone know of any 1" drop in anchors suitable for installing a 4 post lift. So far I have only seen 3/4" but my Bend Pak lift came with 1" stud type anchors. I would like to bolt down my lift with anchors I can remove and leave the floor flat. I guess I could use 3/4" with washers but would prefer to use 1".
c39er
Seattle, Washington
You don't need 1" thread size drop in anchors.
Really no load on a 4 post anchor stud or drop in anchors.
The 3/4"" bolt size drop in anchors do require a 1" hole in the concrete.
I used them on my HD 14 4 post lift.
matt_i
When you remove the lift, cut the studs off flush with the floor, or, drill all the way into the subgrade, and you can drive the anchor flush when you are done.
