f150skidoo
I'm looking to buy a bandsaw that has a 1hp 230 volt 3 phase motor that I would need to run off of 240 single phase. Has anyone bought the inexpensive VFD off of Amazon/ Ebay or suggestions on better quality VFD's?
There is a thread (sticky)dedicated to this subject in the "General tool discussion"
General too discussion : VFD's link
read what some of the other experiences have been. It seems the "Teco" brand is priced well, popular and favored for ease of set up and general use.
I have a Teco 120v input 240v 3 phase output for my Clausing drill press 1hp.
YT House Work has some videos on cheaper VFDs for 2x72 knife grinder kits:
And demonstrates absolutely ****** wiring methods. His sander is cool, the electrical not so much.
What's so bad about his wiring? Definitely seen worse![]()
Only problem is VFD's do not play well with GFCI's, which are required for 15 & 20A 120V receptacles, in shops, garages, outbuildings.
But not 240 Vac?
Did you post your comments to his YT channel? I'd like to see how he responds.
Some YTers don't like any comments that are negative in any way towards them or criticize their methods (e.g. Ask Tractor Mike, outdoor with the morons etc.). You can tell a lot about a so-called "expert" on how they handle criticism.
While I generally think the wiring police over do things, I do think that this guy could have done a bit better, especially with the cord entering the motor housing. As for the crimps, I have removed the insulation many times because there were no uninsulated crimps available when I needed them. I have also had to modify the terminal end on more than one occasion. You have to admit he tried, I wouldn't have even used terminals in the plug, just the wire.
Another happy TECO drive user here. 120v to 240v 3ph driving a 1 HP metal working lathe motor.
This is very true. In my basement, I have a circuit in the ceiling that is not GFCI, and I have to use that for the VFD.
If you already have a 240v 1ph circuit, I'd go with the 240v to 240v 3ph version.
I like the invertek IP66 drives. no enclosure needed (just wire your whips to the built-in junction box), and glove friendly controls on the front:
1P 110-220 3P model https://www.driveswarehouse.com/ode-3-210058-104b
1P 220-220 3P model: https://www.driveswarehouse.com/ode-3-120043-1f1b
i scrolled through the videos but mustve missed the wiring.
what time stamp does the crappy wiring begin at?
Should have mentioned it was another of his videos, my fault.
i left some comments
no strain relief or cable clamp on the peckerhead
grinded the plating off of the terminal connectors smh
shouldve soldered the connectors as his crimping was not that good
