TheEquineFencer
I just got around to finishing installing the two VFDs for the BP and the LeBlond lathe. The BP VFD powers up but that's it. It has a LU code blinking. I have 240V 1ph power to it and cannot get it to show the voltage like the quick start guide says it should. The other one doesn't even power up. Suggestions?
The 3HP, 230V , NEMA 1, Teco, N3-203-CS-U Doesn't power up.
The 2 HP, 230 Volts, NEMA 1, Teco, N3-202-CS-U powers up but keeps blinking the LU code.
Is there something missing from the picture I'm not seeing?
I have all the wires landed where they should be.
I just went back and checked, I have 246V going to each on it's own 20A double pole breaker, I checked the grounds on each VFD and they are grounded. The one that powers up, the only thing I can get to work through the touch pad is to move from FWD to REV LEDs changing state. I have 3 "hots" and a ground going out to the 20A twistlock receptacle and have not tried hooking the BP to it yet. Is there a connection or jumper I missed somewhere?
