Winch Style ----------------Electric
Pull Rating (lbs)------------10,000 lbs.
Volts--12 V
Winch Fairlead Type--------Roller
Remote Included------------Yes
Remote---------------------12 ft. hand-held remote switch
Free-Spooling---------------Yes
Brake-----------------------Yes
Power Out------------------Yes
Drive Gear------------------3-stage planetary
Winch Line Included---------Yes
Winch Line Type-------------Cable
Winch Line Diameter---------21/64 in.
Winch Line Material----------Steel
Winch Line Length-----------94 ft.
No Load Line Speed----------29.53 fpm
Conforms to J706 Standards--Yes
Mounting Hole Quantity ------4 holes
Mounting Pattern Length------10.000 in.
Mounting Pattern Width-------4.500 in.
Weight-----------------------67.000 lbs.
Motor Horsepower------------5.50 hp
Gear Reduction Ratio----------218:1
When you're hitting the trails, running through mud, climbing boulders, or trekking through heavy snow, the last thing you want is to get stuck and not have the equipment to get yourself out. Smittybilt XRC winches have different features to match your needs and your vehicle, but they all have three things in common: reliability, power, and performance. XRC 10 winches deliver tough pulling power and extra muscle to get you out of a jam fast. These winches feature a 12 V, 5.5 HP Series wound motor and galvanized aircraft cable with a removable hook. Or, choose the XRC 10 Comp-Series with no-kink, no-curl synthetic rope with a protective sleeve to prevent overheating, and an aluminum fairlead. No matter which you choose, you can count on Smittybilt XRC 10 winches to pull you out of practically any situation.
