steveo2155
- Joined
- Jan 12, 2014
- Messages
- 79
Looking at a 10 gallon craftsman oil lube compressor. 135 psi. cfm ratings are 3.7 cfm at 40 psi, 2.6 cfm at 90 psi. I am looking for a small portable compressor. Do not want or need a large one. Will be used for blowing off parts, filling tires and occasional impact wrench to rotate tires. It is between this and a 20 gallon oil less with 3.8 cfm at 40 and 5.1 cfm at 90 psi for one hundred dollars more. I am leaning towards the smaller oil lubed one. I know the cfms aren't the greatest but it has good reviews and a couple of the reviewers have said they rotate tires with it and use 600 lb prof. impact wrench with it. Any advice between these two compressors?
