You ****!
I agree, well deserved and I'll say it again.
YOU ****
You ****!
I have one, they work pretty well for an adjustable.
Its far from garbage.
What is the info on the FLUKE METER?
That could be used to hold a chisel also.
Fluke Model 73 Series II Meter
The ad could have simply been $10 Fluke Meter and it still would have been a good deal.
The Model 73 appears to be a basic meter (AC/DC Voltage, Amperage, Resistance, Continuity). It has been replaced by a Series III version but I haven't stopped to see what the differences are yet. At first glance, this one appears to be in good shape. The leads are new Klein replacements. Not sure if someone bought a new Klein meter but preferred the Fluke leads or what. I took a rag and cleaned it up a bit, the display is a little scratched but the actual meter itself is in great shape. I still need to put it through it's paces and make sure it is as accurate and dependable as a Fluke should be. If the theory proves out, it will be a nice replacement both for my digital Harbor Freight and my old analog Tandy. There is something to be said for analog though. That Tandy doesn't have to worry about finding a new home any time soon.
If anyone knows where I could find an electronic copy of the user's guide for the Series II version of the meter I would appreciate the lead. Google turns up the Series III User's Guide or the Series II Repair Guide.
I did a search and found this PDF file. You can save it to you computer. Good luck with it, that is a very nice meter.
http://transmille.net/ProCal/Procedure%20Library/Fluke%20Digital%20Multimeter%2023%20MKII%20%5B1.10%5D/Technical%20Data/Fluke%2070%20Series%20MKII%20(PN%20896204%20July%201991%20Rev%201,%2009-92)%20Service%20Manual.pdf
I remember when I first starting playing with electronics back in the 80's, wishing I could have a meter like this.Have that same ratchet.
Military issue. The same ratchet was sold to the public but the M at the end of the part number stands for military..
