Hi all. I got great advice on the electrical so I though I'd try a framing question.
My garage is 10' w x 20' d with gables on the short end. I framed up the walls with 2x4 24" oc with double top plates. I know it's a bit light, but the structure is small, will have 1/2" CDX ply and roofing material is metal shingles so lightweight.
I was planning on using 2x4 rafters 24" oc with probably a 7/12 pitch and 2x6 ridge. I think it will be fine since I'm using a metal roof and would collar tie about 2/3 way up. I also plan to either block between each rafter or use Simpson ties.
Thought I'd run the idea past those that may have done the same or at least thought about it.
It's not too much more money to go 2x6 but I have a bunch of 2x4 material I'd like to use and it's not crappy either.
Many thanks.
Justin
Many thanks.
Justin
