Not mine, but a friends.
He has an older house at the end of an industrial district, only house on the street. The main high voltage is huge 3 phase awesomeness powering these factories. His house is fed with one line from this to a small transformer and I don't think there is a neutral back up on the pole, just one wire crosses the street and the guy/tension wire a few feet down the pole.
Transformer looks small, only a single house application.
Weatherhead and mast, to the meter, then to a disconnect, then 50 feet of SER to the panel through the walls of the house.
The 60amp sub is in the garage and when he welds or does some things the lights will flicker a little. Two ground rods.
I thought open neutral or something like that, turned on a hot plate full bore on a few different recepts and it wasn't reproduceable.
Put my meter on each leg while doing this and it was 120v +- 2v and the other was 116v or so.
It doesn't seem to be a grounding issue or a neutral issue except at the meter or pole... not sure how it works.
What else can I check or confirm?
