100 lb cylinder
vwscott
Missouri
Im looking to run a Big Maxx 45000 on a 100lb cylinder... also interested to see what others have done...
cork
Central PA
I run my 75,000 Big Max on a 100lb cylinder. It works fine but they are heavy to handle when full. I may look into a larger tank next season and try to lock in a lower rate.
jimp
oo
Run 225,000 on 100lb, only problem is runs out fast.
toyotadriver
I run my 80k btu Big Maxx on a 100 lb cylinder and it works fine. Been as cold as 5 degrees and it flowed plenty of propane. Works fine.
toyotadriver
The first one you list isn't big enough. I have one of those and it's not rated to flow enough BTUs. I had to buy a bigger capacity one. I think the one I have is rated for 200k btus.
F
fitch
Perry, MIchigan
When I look at these at Tractor Supply, the F273767 didn't have the nozzle like F276136. Did you have to purchase the nozzle for the tank seperate?
Reg1952
Ontario Canada
If you call a rental place that rents propane tanks and heaters they can sell you a pigtail ( that's what they called it) so you can connect 2 or 3 small tanks together. I just got one last week for $32 and I hooked 3 20lb tanks together and it has ran my tube heater all week no problem. Tanks are out side and its been -15c here at night. Propane price delivered was $1.21 last week. Propane in a 20lb bottle has not gone up for some reason 70 cents a litre. Mr. Heater sells one that will do 2 tanks. F273737
Chetter
Northern Ohio
I run a 45000 btu Mr Heater with 2 40lb bottles with an auto switching regulator and it's been cold here in Ohio this winter, runs fine with temp set at 48*.
