11/32, how often?
shotgunfatcat
I am the Wanderer
So, I don't think I have ever used an 11/32 wrench or socket, yet I have them. They make my sets more complete in my eyes.
So what have you used them for? Am I using a metric size instead and maybe I shouldn't?
Bruce Lancaster
That is a very common size for electrical fasteners on old cars, stuff like coil primaries, connections on switches, and so on...the days of ring terminals with studs, nuts, and lockwashers. You could probably determine the age of a guy's car by the wear on his 11/32" open end...
S
shotgunfatcat
I am the Wanderer
AH, Well I kinda figured for ignition systems, my set of ignition wrenches (I just got them a month or two back) has two of them. But I haven't gotten around to my ignition on my car yet (as usual no money to work on it).
Any other uses out there?
Sterff
PA
Ive used them on electric motors and on a starter for a tractor. All of the #/32 wrenches are common on old equipment.
kerryt1
Oklahoma
If I'm remembering correctly, that's the size for the inboard end of the flexible brake lines on my C5 Corvette.
S
shotgunfatcat
I am the Wanderer
Thanks for the input guys. Not that I would get rid of them, but I know where to look to use em!
I don't work on planes, or AN fittings of that size, so I will have to look into my electrical arsenal to see what I can do. I have a few cars to work on in the future here where I will probably need them.
jpilgrim
Standard pattern hex nuts for 8-32 machine screws are 11/32.
I use my 11/32 all the time since I use a lot of 8-32 screws and nuts in the equipment I build.
ecotec
as an electrician, i use the 11/32 some. electrician nut driver sets (klein, greenlee and such) have 11/32 in the set.
fordbroncodave
small nuts on electrical systems on old cars, trucks, tractors, lawn mowers is very common.
my wrench has alot of use on it and i know why. my jd model A has them on the coil and distributor
crewchief888
NW indiana
i find them on older construction eq, starters, guages ect.
i use a nut driver a lot times, and have a SO comb wrench that has the open end ground down to a taper to get to the jam nut under the terminal
:beer:
DaleK
East-Central Ontario
Had one for an oil drain plug on an old Honda engine I had. Would have thought it should have been metric but 11/32 was the only thing that would fit.
north
Norway
Got this 11/32" ratcheting handle yesterday. It was a 'freebie' thrown in with some other tools. And I thought this was a dust collector size, lol.
Edit: No name or coo.
bonneyman
Desert SW
:thumbup: Electric motors on blowers and such in HVAC have thru-bolts that are 1/4" and the end nuts are typically 11/32". The green handle driver comes in handy daily for hanging and mounting said motors.
Lump
Jamestown, Ohio
This one is easy for me to remember...I'm a Chevy guy, focused on V8's from the fifties to the seventies. Back in the day I ran a lot of hot rod big blocks, and they used to be notorious for starter problems (especially with extra-high compression engines), so we were often rebuilding and/or replacing, and/or shimming these starters. I kept several 11/32 sockets and wrenches in my tool boxes for this reason. The small wire lead to the starter solenoid (the terminal which is closest to the engine block wall when the starter is installed) used an 11/32 nut. This was the terminal that you needed to jump across the battery cable lead to bump the starter from underneath, if the ignition switch failed, etc. So, that 11/32 nut was often melted and distorted on big blocks. I kept several spares in my box.
Gary S
Bismarck, ND
I don't worry about the wrenches I haven't used yet, because I don't waste time keeping track of things like this.
My SAE wrenches have all "probably" been used at one time or another. If not, who cares.
What irritates me is the crappy metric sets that are incomplete and I can never find the one I need.
Maybe the answer it to blow up everything with metric fasteners.....................or, like my Son says, "A Crescent wrench and a Vise Grip can be a full set of metric wrenches."
