110V vs. 220V
2001RedCoupeBandit
I just added a 2nd 220 volt outlet for an air compressor (I will buy soon!). have a BendPak 4 post lift arriving and added 220 Volt for the Lift, BUT thought, why not get a 2nd plug for anything in the future as long as he was in there already.
Now, the compressor thing I am not that concerned with, 110 will be just as good for running the AC, btu still glad I have a 2nd 220 volt on it's own seperate breaker just because.
Jarcese
Boston, MA
Wow this thread is brutal.
There is such thing as machinery that runs on 4kv, 3 phase though. You see it in old factories and I think some ships use it.
In MA state law is that you can rubber glove 35kv out of a tested insulated bucket. You won't turn to toast. In some places you can still bare hand 4kv out of a tested bucket. I saw once on the history channel that you can bare hand 75kv(against the law, but if it were to happen by accident) out of an insulated bucket, but I don't believe it. I think they only said that because that's what OSHA makes use use for voltage to test buckets. I bumped 7.9kv(13.8 phase to phase)above my rubber sleeves by accident out of a bucket and it hurt really bad. High voltage doesn't hurt birds because they are small and insulated. The Human body reads as load so it hurts like hell but can't kill you if insulated up to certain voltages, higher volates will burn you even if insulated because you are load. Sorry to add to the off topic-ness, but you will not turn to toast unless you're touching ground, neutral, or another phase. 13.8 voltage will blow your arms off if you happen to touch two phase and it will pass through a pin hole in rubber gloves. So you don't touch anything but the phase you work on and your bucket.
Bottom line is higher voltage is more efficient, but costs pretty much the same as far as your electric bill is concerned. Like someone said, even if you don't know anything about electricity, use a 240v saw next to a 120v saw and see which works best. It bet you'll go with the 240v saw. The only reason 120v is better is because you probably already have plenty of 120v outlets with nothing plugged into them. You're still getting 240v volts from the same single primary(or two if it's delta primary.) going into the transformer. They could put a meter on the primary side of a transformer feeding just your house and you will be charged the same as the meter on the side of your house house no matter how your house is wired.
SCWOOD
Motors draw a lot of amps at start up (lights flicker) switched to 220v cuts the draw in half.Leaves more amps for rest of shop(no affect on lights)This start up draw can damage sensitive equipment(lights,computers etc.)Hope this helps!
Jarcese
Boston, MA
Yes, all your lights flicker instead of half since everybody here seems to be working with an overloaded panel by the time they start to build their shop.
Jk, I agree. Good point.
foolishpride
Southwestern Ohio
True, but you must wear Class 4 gloves, and good luck doing much with those on besides gripping a hot stick.
The upper boom on the bucket trucks are tested at 100 KV. The lower booms are tested at 50 KV.
Jarcese
Boston, MA
Yeah I was pissed when our company changed glove vendors, Salisbury class twos feel like higher class gloves. I tried on the class 4's once, could't imagine using them. I think companies would rather hot stick then pay for arthritis claims. We still hot stick 25kv with class 2s since they changed the rubber glove law a few years ago.
The stickers on our trucks say 75kv on the tested sticker. I just assumed that was OHSA's rule.
