115 Piece Jobber Drill sets - Clearance
MJB24
Minnesota
I got in a MSC order today and there is a flyer with some clearance items.
A really good deal on USA made drill bit sets. There appears to be a few hundred in stock on both items
MSC# IJ01187707 for $139.00 (Black Oxide)
http://www.mscdirect.com/product/01187707?orderedAs=IJ01187707&pxno=38558845&rItem=01187707
MSC# IJ01176700 for $139.00 (Bright)
http://www.mscdirect.com/product/01176700?orderedAs=IJ01176700&pxno=38558844&rItem=01176700
These appear to be the same as these ones at HJE
http://store.harryepstein.com/cp/DrillBitSets/J-115.html
MJB24
Minnesota
I am fairly certain they are Norseman. MSC would probably tell you if you call them.
gtermini
Amity, OR
I have always had good luck with MSC "Made in USA" branded items. They are always top notch quality.
Greyson
Zrexxer
Pflugerville, TX
If they're the same generic "Made in USA" twist drills that their sister company Enco sells, the ones I got were ****. They weren't hardened properly, some were soft, some were brittle, they'd either roll the cutting edge or chip and break. And I'm just talking drilling mild low-carbon steel, not hard metals or bed frames.
MJB24
Minnesota
There are some other items on here as well. Photobucket wont allow me to add pdf. and this site says my pdf. are too large so if someone wants to see it send me your email and I can email out the clearance scans. Or maybe someone else can post it here from my pdf.
There is also
Cross Line laser level
Fire Vulcan Rechargeable Lantern
Vane pump
Half round smooth american pattern file
6" stainless dial caliper
7 x 12" bench lathe among other things.
MN4x4
Minnesnowta
I'm sure this is gonna turn out to be a stupid question but i'll ask anyway - is there any functional difference between the bright ones and the black oxide, or is it just appearance?
Bigblue&Goldie
Anyone have any input on this? I might pick one of these sets up.
zeekh
Upstate NY
Really depends what you are drilling. Bright is better on Alum. Black oxide steel. I Have prefer bright. I think they clog less but if you're not deep drilling it really doesn't matter. Deep drill in Alum, bright is way better at least I think so. YMMV. I really have no input regarding how they work on wood.
