12 drawer tool cart
why worry
So I posted the 12 drawer Armstrong truck box that I picked up from a local Craigs list and decided that it was going to become my new tool cart. So here goes. First the box support frame, went to the used metal supply next to the shop and found an old shelf frame that should do the trick.
W
why worry
Next up is the shelves. Decided to do two shelves. so went to the surplus metal behind the brake and found some 20 ga 304 stainless that should work out really well. LAyed them out notched em, and formed them up. Then spot welded the corners with my Miller 135. Added a support for the mid shelf.
Then the shelves with a few pop rivets.
W
why worry
A bit of regal red paint andsome plastic caps for the tube ends and wa la a 12 drawer tool cart.
W
why worry
Yes, very handy indeed and it freed up some space in my other boxes which are overflowing.
Dave
kbs2244
My only fear is that it is going to be top heavy.
Store some heavy stuff on those shelves
W
why worry
Put fixed wheels on one end, set to the long direction with swivel wheels on other. I have it loaded up and it is quite stable. Put my boxed items on lower shelves. So as long as I keep the speed under a 100mph and the drawers closed around the shop I don't think there is an issue.
Dave
W
why worry
Since there was a couple of concerns on stability I went ahead and attached a couple of pics showing the load on the cart.
kbs2244
I don't mind being wrong.
If it can be proven.
It looks like you have proof that I need not be concerned.
Congratulations.
It looks nice,
Ohmthis
Outside of Louisville KY
Why worry, my comments were more towards my own idea/design. Do you mind posting some dimensions of the box and of the cart? It definitely looks like it can handle whatever you throw at it. :thumbup:
W
why worry
The box is 33" wide by 16" deep by 20" tall. The cart is 33 1/4" ID wide with the depth at 16" . I set the box at 32" to the bottom. mid shelf is 12" wide. Bottom shelf 16". I had some old casters that were from the 70's also so it ended up being pretty much a vintage build. lol
Dave
Ohmthis
That box is larger than the boxes on the HF red cart. I can see it being sturdy. My box is 26w x 16d x 16 or 18 tall. Being so narrow makes me think of it being top heavy. My weight would be more towards the center where yours is spread out. Good job again!
W
why worry
Thanks to all who comment on the projects guys and gals build, as it has upped my game with all of the great ideas that this forum generates. It has been really nice to have the majority of the tools I need for working on tractors nearby instead of having to walk across the shop every time I need something.
Dave
